Old 04-23-2012, 12:55 PM   #1
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Front Strut Tower Bar Question
I am considering the front strut tower bar option for the new FRS. It appears to have 2 fairly rudimentary angled bars from the towers to the middle of the engine bay. I was wondering if anyone has experience with strut tower bars in other cars and if it would be worth the investment. I do not plan on autocrossing. Thanks
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 04-23-2012, 01:02 PM   #2
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
If you don't plan on competitive driving you likely won't notice a difference. The stock one should more than suffice.
MmmHamSandwich is offline   Reply With Quote
Old 04-23-2012, 01:15 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
^Yup, pretty much. Keep it stock
Old 04-23-2012, 02:52 PM   #4
Racecomp Engineering
Agreed. You would feel a much larger improvement from a good alignment (which would require some cheap camber bolts). You could do this without excessive or uneven wear on your tires as well.
- drew
Old 04-23-2012, 05:29 PM   #5
bneale
bneale's Avatar
Drives: Scion FR-S
As everyone has already mentioned, keep it stock if your not heavy into Road Racing or Autocross. It's not worth the extra cash unless your just trying to show off.
Even if you are a serious racer or want to get into it, a upper strut mount is probably the last upgrade you'd want to make. You'll get a way bigger performance increase from upgrading the swaybars (aka roll bars) then you would the strut mount.
I plan on Autocrossing and the first upgrades for me will be Rims and Tires followed by swaybars.
bneale
bneale is offline   Reply With Quote
Old 04-23-2012, 05:48 PM   #6
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
But that carbon fiber TRD strut tower bar, looks way cool.
tripjammer is offline   Reply With Quote
Old 04-23-2012, 06:32 PM   #7
russv
First 86
russv's Avatar
Yes!
Old 04-23-2012, 06:33 PM   #8
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
The bars connecting to the center are the most effective. That's how all the WRC cars I've seen have it.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 04-23-2012, 06:36 PM   #9
bneale
bneale's Avatar
Drives: Scion FR-S
I saw that this morning. Yeah it does look nice. But thats about it for me. The extra weight it adds for me though wouldn't outweigh its performance increase. So for me its still not worth it.
If and when I decide to go that route, I think I prefer the cusco one! This is the one I like.
But to be honest, I'd rather get a smaller battery and shave weight before spending money on the strut mount.
bneale
Old 04-23-2012, 06:43 PM   #10
bneale
bneale's Avatar
Drives: Scion FR-S
Don't take this the wrong way, but just because you can see it, doesn't mean its better.
Trust me, the Rollbars / Swaybars are way more important then an upper strut mount. The sturt mount is only going to stop very small movements between the 2 mounting points. Can you imagine how much force has to be applied before the 2 mounting points actually start to move closer together? Or moving at all?
Again, you can see an upper strut mount (Which is probably why you guys are so interested in them) but the rollbars will make a bigger difference in handling.
Photo for reference. The black bar which runs underneath the transmission and connects to the lower part of the spring is what I'm talking about. This is the "Front Rollbar"
bneale
Old 04-23-2012, 06:47 PM   #11
tlp
Drives: Supra
Do both. Add the struts and get a new battery. That way you offset any increase in weight with a lighter battery. Best of both worlds.
Only downside is money
tlp is offline   Reply With Quote
Old 04-23-2012, 06:49 PM   #12
bneale
bneale's Avatar
Drives: Scion FR-S
Which is why an upper strut mount is the last thing on my mod list when it comes to buying parts for Autocrossing.
Seriously, its like part number 101 on my list of 100 parts. Number 1 being tires, 2 being wheels, and 3 being rollbars.
bneale
Old 04-23-2012, 06:50 PM   #13
Turbowned
Turbowned's Avatar
Even a thicker sway bar (or anti-roll bar to some) probably won't be necessary on a car that's not raced. The whole purpose of this chassis design is to reduce body roll from having a low center of gravity. Keep in mind the BRZ also has very neutral handling, so that could turn into a more understeer-prone car if the rest of the suspension isn't adjusted accordingly along with it.
Old 04-23-2012, 06:53 PM   #14
bneale
bneale's Avatar
Drives: Scion FR-S
Turbowned makes a good point. I'm probably going to consider a good set of coilover springs before I get into rollbars. Unless of course I think the car REALLY needs them badly.
bneale
BRZ front grille mod bloomy116 Cosmetic Modification (Interior/Exterior/Lighting) 255 06-13-2021 08:58 PM
swap brz front end with fr-s? koyv90 Scion FR-S / Toyota 86 GT86 General Forum 17 02-07-2012 03:23 AM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 02:08 PM
Comparing front end of the FR-S/FT-86 to BRZ DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 66 11-21-2011 05:26 PM
strut tower braces made out of bamboo?!? aspera Scion FR-S / Toyota 86 GT86 General Forum 26 04-02-2010 01:27 PM
