Old 08-12-2014, 12:28 AM   #155
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Looking at the pictures it seems it might be possible to use the 210 intake casting and maybe have an "extension" machined that would put the throttle body in the correct location. That is just a rough idea though. Kind of hard to confirm without having everything here in front of me.
Dustin is offline   Reply With Quote
Old 08-12-2014, 12:30 AM   #156
Dustin
Twin Screw You
Dustin's Avatar
Originally Posted by alexisfire02 View Post
I've never seen a 210 but i the reason they decided to try the 335 is it fit.
Yes the blower fits on the manifold but the intake casting is different. If you look at the pictures on the first page you can see the differences.
Old 08-12-2014, 12:33 AM   #157
Dustin
Twin Screw You
Dustin's Avatar
Because the blower is larger, it sits further back. Therefore the intake casting has to be longer to put the throttle body in the correct location for the intake tube to connect to. I wish I could park my car next to yours so I could find out what I could do with the 210 casting to make it work.
Old 08-12-2014, 03:25 AM   #158
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by jet86 View Post
I got my 335 upgrade
Sent from my SM-N9005 using Tapatalk
Pics please
brianhj is offline   Reply With Quote
Old 08-12-2014, 03:45 AM   #159
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
https://www.facebook.com/forgedperfo...type=1&theater
jet86 is offline   Reply With Quote
Old 08-12-2014, 03:46 AM   #160
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
https://www.facebook.com/forgedperfo...type=3&theater
Old 08-12-2014, 06:58 PM   #161
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
If your aim is to order just a blower separately to save money I can see where you are going with this idea. The castings bolt spacing seems to be the same...
However to try and make something your self to perhaps weld on to the casting you have would be pretty tough to do my friend. I am sure the company wont sell just the casting either. So If I were you I would have a plate milled and drilled to mount onto the blower and then...mandrel bend a tube...weld that to the plate...then weld on another plate to mount throttle body to.
This is coming from a machinist.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 08-13-2014, 01:08 AM   #162
Dustin
Twin Screw You
Dustin's Avatar
Yeah I wasn't thinking about welding anything. I was talking about machining an extension or spacer of sorts to go between the 210 casting and throttle body. I made a post referring to it earlier but it could be easily missed with all the posts I made, lol.
Old 08-15-2014, 12:50 PM   #163
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
So... this 210+ kit. Any new information as to 1. Pricing 2. Release date 3. Specifications (CARB Exempt, Dyno #s on a base map, ETC)?
-Jack Burton
Old 08-15-2014, 05:27 PM   #164
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
1. Nope
2. Nope
3. The only change in the 210+ is the coating of the louvers increasing the continuous redline exactly how much of an increase is still unknown but the 69mm pulley is now below the continuous redline of the blower. I'm sure straight away people will put even smaller pulleys on as well.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
The Following User Says Thank You to Khorne For This Useful Post:
tahdizzle (08-15-2014)
Old 08-15-2014, 06:58 PM   #165
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Khorne View Post
1. Nope
Actually the 210+ has been on the price list for a while, whether that is still valid though....??
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-15-2014, 07:33 PM   #166
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Well yes you are right for the full charger to the Hub but each reseller may offer a trade in on the current blower and sprintex have said it is possible to swap out just the louves in the blower.
And even then that price is directly from sprintex in AUD, so no idea what it will be in USD as nothing is ever a direct conversion.
Build thread
Old 08-15-2014, 07:55 PM   #167
pandora
Can you just order it from the vendors with the 210+ now ?
pandora is offline   Reply With Quote
Old 08-15-2014, 08:03 PM   #168
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
If a vendor can get ahold of one then go for it. Sprintex have not started mass production of the unit yet so finding one will probably prove difficult.
Build thread
pandora (08-15-2014)
Abbey Motorsport Sprintex SC updated Dyno plots Mark@Abbey m/s Forced Induction 49 02-15-2017 11:13 PM
Khorne's - AUDM Red 86 GTS Sprintex Khorne Member's Car Journals 53 08-31-2014 09:44 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
Abbey Motorpsort GT86 Sprintex installation Mark@Abbey m/s Forced Induction 18 09-07-2013 04:11 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
