Old 08-12-2014, 04:29 PM   #757
Frogamazog
Drives: Soon to be a BRZ
OK thanks for the quick reply. JDL has some good pics with a removed engine that show the layout exactly. I will take a look at them with this info.
Frogamazog is offline   Reply With Quote
Old 08-12-2014, 04:32 PM   #758
CSG Mike
CSG Mike's Avatar
Can you link me the exact pics? I'll make an educated guess based on them.
Old 08-12-2014, 04:42 PM   #759
Frogamazog
These are the best I could find. The removed engine ones only show from the bottom.
http://www.ft86club.com/forums/showt...t=52907&page=4
Old 08-12-2014, 04:48 PM   #760
CSG Mike
CSG Mike's Avatar
I'm 95% sure it'll clear
Old 08-13-2014, 03:55 AM   #761
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Originally Posted by The Slow One View Post
A few if us are including myself. I am very satisfied with his tune. I'm considering going with his flex fuel setup since e85 is more readily available here in Houston.
Anyway checking back in from my track event. I now need new brakes. The new found speed has me overheating them in less then a lap lol!
If you're in Houston would you mind meeting up someone so I can see/hear how the sc feels and sounds?
ScionOfHorus is offline   Reply With Quote
Old 08-13-2014, 03:57 AM   #762
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Originally Posted by CSG David View Post
We are a one stop shop for all your needs. HAHAHA
Saving my pennies for my brake upgrade next
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 08-13-2014, 10:28 AM   #763
enivid
enivid's Avatar
Drives: WRB JR BRZED
Hey guys I'm definitely interested in the JR SC, but have been looking everywhere for header compatibility. I will be doing a full exhaust mod and really like the JDL EL header but have seen a couple posts warning that it may not fit with Rotrex SCs like JR or KW. Anyone have or know someone who has a JDL or other EL headers that pipe up by the pulley system?
Just get the HKS EL
enivid is offline   Reply With Quote
Old 08-13-2014, 11:44 AM   #764
Frogamazog
Don't really like the sound of the HKS or any UEL I've heard
"My other ride is a 175mph bus"
Old 08-13-2014, 01:06 PM   #765
CSG David
CSG David's Avatar
EL = what OEM piece is
UEL = Subaru burble...sounds rough, but it's not quite necessary for the SC guys since the torque dip is already eliminated with the SC.
Old 08-14-2014, 01:48 AM   #766
Poodles
You keep telling yourself that and that it isn't for emissions reasons.
This. Like I told him, it is his decision to make whether he wants to run a vented or a non a non vented/check valve to keep from pressurizing the crankcase when in boost.
Yes, it originally was designed for emissions, but just like EGR, it was found to have other benefits.
Reroute the PCV system like a normal turbo car and you won't pressurize the crankcase
Old 08-14-2014, 08:52 AM   #767
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
PCV valves close at wide open throttle, the "benefit" you're talking about isn't quite what you're making it sound like.
There are a whole lot of turbo cars out there that have functional PCV systems and still blow dip-sticks out under wide open throttle.
Actually preventing pressure build-up in the crankcase requires a whole lot more venting than you're going to get from either one of the catch cans you guys are talking about.
Sellout is offline   Reply With Quote
Old 08-14-2014, 10:46 AM   #768
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This car doesn't come with a PCV valve though. It just comes with a hose barb threaded into the crankcase, a rubber line, and a nipple on the back of the intake manifold. You either install a check valve to prevent the crankcase from being pressurized while still allowing the crankcase to vent during vacuum situations or you install a VTA catch can and don't allow the crankcase to see any boost or vacuum. I am fine with either solution, but I prefer the VTA so that no hot oily air has the chance to go back through my intake manifold and engine.
Old 08-14-2014, 11:49 AM   #769
Sellout
Mr. Cranky Pants
Sellout's Avatar
I agree with you on that. Didn't realize these cars (or any for that matter) don't actually have PCV valves.
For turbo applications especially I'd rather have it VTA than give it a chance to coat the inside of my intercooler with oil. (No oil separator is 100% efficient)
Old 08-14-2014, 11:30 PM   #770
Poodles
Look at a Supra and say that all again No PCV valve, but the system runs to before the turbo and to the throttle body and effectively switches over whenever it's needed.
If you're blowing the dipstick out, you either have a clogged system or massive blowby (all the dumb kiddies putting filters on their valve covers because it happens on their 200K+ mile motors and saying PCV sucks)
You're ignoring the third solution (and a fourth, but using venturis in the exhaust is dirty as hell and would destroy a cat and fail any kind of inspection).
The small amount isn't going to cause any issues. When I pulled off my intercooler and cleaned it after 20+ years nothing drained out, I had to use solvent to get anything out and even then it was minor.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
