Old 08-12-2014, 01:27 PM   #1
evomike
Drives: frs
Anyone else's car get musty after it rains
I have tired searching for a leak everywhere but cannot find it but after it rains my car smells mega musty, I think I'm just gonna set it on fire if I can't find the leak.
evomike is offline   Reply With Quote
Old 08-12-2014, 01:29 PM   #2
Imrac
Drives: 13 SWP BRZ Prem
Are you driving it when it rains and it smells musty? Or is the car just sitting and when you get in it that is smells musty?
If its raining a good thing is to turn on the heat, cabin recirculate the air and turn on the AC.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 08-12-2014, 01:31 PM   #3
evomike
Drives: frs
The car is sitting it rains and the car smells musty no car I have ever owned has done this not even my 72 nova
Old 08-12-2014, 01:37 PM   #4
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
I had this happen, check to make sure you PDI grommets are installed, located near the jack points,.. in the rear. if not,... order them... smell went away for me
http://www.ft86club.com/forums/showthread.php?t=7204
microbionic is offline   Reply With Quote
Old 08-12-2014, 04:10 PM   #5
J-Money
J-Money's Avatar
Drives: GT-86
Mine smell and is really humind ish. :/ disappointing. my 98 civic used to smell similar
J-Money is offline   Reply With Quote
Old 08-12-2014, 07:55 PM   #6
kodyo
Drives: Scion FR-S
Yeah, mine does this too. But to be fair, so does my GFs camry. Generally just recirculate hot air when I smell it. Goes away pretty quickly. Wouldn't be surprised if it's moisture from the vents.
kodyo is offline   Reply With Quote
Old 08-14-2014, 07:50 AM   #7
Maritime Storm
Maritime Storm's Avatar
Drives: 2013 Scion FR-S 6spd, Whiteout
Check your cabin filter, it's probably dirty.
Maritime Storm is offline   Reply With Quote
Old 08-15-2014, 03:39 AM   #8
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
I feel like my car is also a little musty when the AC is off. It's not even humid where I am either lol.. There are a few "car bomb" air freshners that you can try which will circulate through all the vents.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 08-15-2014, 11:31 AM   #9
extrashaky
Drives: 2014 BRZ Limited
As an alternate solution if you can't find the leak, you can buy reusable dessicant packs that will collect moisture in your car to a single location so you can remove it. You can get a little dessicant tub that actually traps water in it, which you dump out when it gets full. They also make a metal dessicant pack that collects moisture in the material, which you then get rid of by putting the pack in the oven to bake it out. They work pretty well to control humidity, which in turn will help keep the fungus you're smelling out of your car.
You can get them from Amazon, WalMart or the gun department of any decent sporting goods store.
Old 08-15-2014, 12:20 PM   #10
FRiSson
Drives: FR-S MT
It is probably not something in the interior, but in the air delivery system. I would avoid the horrible scented cleaners, but perhaps spray ozone into the air intake area. Another choice is lysol which will kill any fungus. However, you want to make sure to flush out the system after using it for several hours. Another safer fix is to go to a hardware store. They sell containers of crystals that effectively absorb odors. Again, avoid the scented ones, the best kinds give off no scent at all. I believe they can be refreshed in a microwave after a few months.
FRiSson is offline   Reply With Quote
Old 09-12-2014, 11:15 AM   #11
evomike
Drives: frs
finally got around to putting it on the lift and it was body plugs that were never put in
When it rains, it pours and I'm not talking Weather Xerious Scion FR-S / Toyota 86 GT86 General Forum 6 04-02-2014 05:49 PM
Musty smell from A/C gatorbushmen Issues | Warranty | Recalls / TSB 2 06-21-2013 12:51 AM
Musty smell in the interior.. InstinctRacer Scion FR-S / Toyota 86 GT86 General Forum 10 12-04-2012 09:43 AM
