Old 08-12-2014, 09:56 AM   #15
Foobar
SLO NO MO
Foobar's Avatar
Yeah we're specifically talking about pulling the side lever or the rear strap to allow a passenger access to the back seat.
The front bar pulled up does allow you to latch in several places, but that's a different bar.
Old 08-12-2014, 10:16 AM   #16
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Have to lift the bar for each point or hold it up all the way back. So ... the free sliding must be just a BRZ thing. Odd that would be different.
don't touch the bar in front of the seat; only the side lever to tilt the seat back to pivot forward and slide forward to allow passengers to get into the back.
shiumai is offline   Reply With Quote
Old 08-12-2014, 10:30 AM   #17
It is the side lever I am talking about. I pull it up, the seat back leans forward and the whole thing slides forward and locks at the end of the track. Have to release the front bar to make it go back again (the side lever will not release it when locked forward) Wasn't joking when I said maybe mine was broke. Has been that way since day one so always though that was how it was supposed to work. If it is broke I am going to leave it that way as it sounds like a pain if it slides back on it's own. Will compare against another at the dealer and see if I can figure out what is different with mine. May have just discovered a new DIY mod!
Old 08-12-2014, 10:45 AM   #18
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
If yours does work as you say, I wonder if there's a way to switch modes, I can't imagine they used 2 different seat mechanisms, these cars were built with the same parts in the same factories.
Deathalo is offline   Reply With Quote
Old 08-12-2014, 11:05 AM   #19
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by Deathalo View Post
Hey, I tried searching for a solution to this but came up with nothing. Is there a way to stop the passenger seat from sliding back when pushing it forward to get into the back? Whenever I have someone getting into the back (especially parked on an incline ever so slight) the seat keeps hitting them if I'm not holding it and makes it extremely difficult, annoying, and embarrassing to get into the car. Also a pain when trying to put something that requires 2 hands to hold in the back, cause then I have no hands to hold the seat up with and the seat just comes back and smacks whatever is in my hands. Why wouldn't they just design it to hold up at the front of the track when the seat is pulled forward like that, then release when you push the seatback back, like every other coupe? Has anyone figured out a way to achieve this? Is there some sort of trick to it I have yet to figure out?
park facing downhill, problem solved, thread should now be closed...
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following 2 Users Say Thank You to carbonBLUE For This Useful Post:
finch1750 (01-29-2019), Koa (02-01-2019)
Old 08-12-2014, 11:17 AM   #20
Foobar
SLO NO MO
Foobar's Avatar
Hmm I'm gonna see if I can break mine tonight. LOL
The Following 2 Users Say Thank You to Foobar For This Useful Post:
Deathalo (08-12-2014), Koa (02-01-2019)
Old 08-12-2014, 11:18 AM   #21
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Have the same behavior... the passenger seat tends to slide back into my doughters face when she tries to get in or out.... and yes, you can get people behind (see the thumbnail bottom left, ready to go to the field with heli and familly aboard):
Harvey is offline   Reply With Quote
Old 08-12-2014, 12:47 PM   #22
This just may be the differences we are seeing.
On my FR-S, if I pull the front bar to move the seat up, it will latch in a forward position.
If I use the side lever (which tilts the back) to move the seat up, it will NOT latch in a forward position.
I reckon they designed it this way so a back seat passenger can get into the back seat, "pull the tab" and pull the seat back into a rearward position.
Old 08-12-2014, 12:55 PM   #23
I doubt there is a way to switch modes or the manual should say so. Probably something just bent or out of place on mine. It was the dealer showroom car and had god only knows how many people climbing through it for a few months. I watched 6 people climb in and out (not all at once of course) in the 1/2 hour it took to sign the papers alone. So not inconceivable that somebody got overly rough with the mech and broke or twisted something.
As I said before I will see if I can figure out what is different. Hopefully I don't accidently "fix" it while doing that though.
Old 08-12-2014, 01:52 PM   #24
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
I drive a 13' FRS and my passenger seat just slides back I have to hold it while i buckle my daughter in..kind of annoying. Also my Doors do the same they rarely stay in place and usually swing back in hit me if I don't actually hold the door open when I get out especially inclined (or is it declined) you know what i mean lol
I've kind of gotten used to it athough it is very frustrating lol
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 08-12-2014, 01:56 PM   #25
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
With mine it slides freely if I either pull the tab or if the seat reclines all the way to its forward most position by pulling the side lever(lever to recline the seat) . I wish it worked more like the way vw does with the 2 door golfs but oh well. Basically seems that the free movement mode is linked directly to having the seat reclined forward as far as it can be.
00NissanNinja is offline   Reply With Quote
Old 08-12-2014, 02:01 PM   #26
tennisfreak
Drives: 2018 BMW M240i
Mine slides freely
BUT
when I slide the seat forward if I reach under and push down on the bar underneath the front of the seat then I can get it to stay in place.
Old 08-12-2014, 02:23 PM   #27
wheelhaus
wheelhaus's Avatar
This is interesting, my daughter is now riding in a forward facing seat, and getting her in/out is fristrating when the car is constantly trying to hug me.
My BRZ seat release doesn't lock forward. I was considering adding a tension spring somewhere under the seat to help pull it forward.
BTW @Harvey that's a nice lookin' TRex700. How long have you been flying?
Old 08-12-2014, 02:36 PM   #28
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
This is how mine is. HIGHLY annoying when a passenger pulls the strap, the seat back folds forward and they push the seat forward(so they can get out). Then, when they least expect it, the whole thing slides back...I dont understand why it doesnt "lock" in place. The only time it locks in place is when you use the bar on the front. But what the hell is purpose of that, when they cant reach it.
Scion/Toyota/Subaru screwed up on this one. Huge, no. But definitely annoying.
Passenger Seat Belt Warning Chime goes on even though there's no passenger. idreamofdrifting Issues | Warranty | Recalls / TSB 58 10-11-2017 10:31 AM
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
Passenger seat belt warning when I put phone on seat!??? Kayzer Soze BRZ First-Gen (2012+) — General Topics 20 09-13-2013 11:29 AM
passenger seat gusbarragan Scion FR-S / Toyota 86 GT86 General Forum 4 04-23-2013 05:57 PM
Passenger seat not sliding to let people out.. wparsons Issues | Warranty | Recalls / TSB 9 10-01-2012 07:28 AM
