Old 08-11-2014, 07:58 PM   #1
GA_Dave
Drives: 2014 Dark Gray Metallic BRZ Limited
What to do to my engine?
Hello, all. I'm in a bit of a predicament, and I'm coming here for some advice. I drive a 2014 BRZ. Through a variety of events, I ended up hydrolocking my engine this past weekend while I was out of town. Luckily, Subaru roadside paid to get it towed to the nearest dealer. I then drove back home (200 miles away) in my wife's car. Dealer called today and confirmed my suspicion that the engine was hydrolocked. I asked if they had removed the spark plugs and tried to turn it over to blow the water out of the block, but they informed me that it would not work. That sounded weird to me, but they advised that I call my insurance and file a claim. The claim is now filed, and they will be sending an adjuster to look at the car.
The dealer says that their next course of action is to throw in a completely new shortblock. That sounds a bit extreme to me, so I'm trying to think of options I have.
1. Pay the $500 deductible and get the insurance to pay for a whole new engine installed by Subaru
2. Decline work and blow the water out myself.
3. Decline the work, get the car towed back to my house, and build the engine in a few months/
What do you guys think? I wanted to build the engine anyway, as I want to go FI and run more than 6 pounds of boost. Would it be stupid to turn down a new engine for $500? Or is my best bet trying to fix it myself, and building later if a rod is bent? Thanks in advance for any input!
GA_Dave is offline   Reply With Quote
Old 08-11-2014, 08:11 PM   #2
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Pay the 500 to get a new engine and ask to keep the hydrolocked engine so that you can rebuild it
ToyoburuBRZ is offline   Reply With Quote
The Following 5 Users Say Thank You to ToyoburuBRZ For This Useful Post:
akahenry (08-15-2014), Basket Case (08-15-2014), cdrazic93 (08-11-2014), FRSBRZGT86FAN (08-24-2014), NWFRS (08-14-2014)
Old 08-11-2014, 08:14 PM   #3
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
^What he said. Hands down the best idea.
AVodka14 is offline   Reply With Quote
Old 08-11-2014, 08:17 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
alternate route, keep the money you would have used for a built FA20 and research about swaps. Tons of stuff will fit this engine bay. you could even try and get your hands on a H6 from one of the newer legacy's at a junkyard and build that.
Old 08-11-2014, 08:18 PM   #5
sam69
Drives: GT 86
X3 build the locked motor
sam69 is offline   Reply With Quote
Old 08-11-2014, 09:57 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
Depending on how the engine ended up hydrolocked you may have damaged things internally.
As said above: Pay the $500 and rebuild your old block without any time pressures to get it back in the car.
1974 TA22 Celica
2013 86 GT
Old 08-11-2014, 10:12 PM   #7
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Of the 3 options you gave this is the one you do not want to go with. You might have bent con rods,damaged cylinders who knows what else. First option looks the simplest and drama free.
JohnJuan (08-12-2014)
Old 08-14-2014, 02:33 PM   #8
Pat.Thornton
Pat.Thornton's Avatar
Drives: 2014' 86
Sounds like it's time for a 2jz swap
Pat.Thornton is offline   Reply With Quote
Old 08-15-2014, 03:33 PM   #9
GA_Dave
Thanks for the advice guys. I'm still waiting for a quote from Subaru for a new shortblock, but my adjuster is willing to let me pay my deductible, and then cut me a check for the quoted amount, made out the shop of my choice. I guess I'm building the engine sooner than I thought
Old 08-15-2014, 03:44 PM   #10
Basket Case
Drives: 2013 Raven fr-s
How did you manage to hydrolock the motor?
Basket Case is offline   Reply With Quote
Old 08-15-2014, 04:16 PM   #11
GA_Dave
Extremely heavy rainstorm, and my car is lowered. Apparently, to much water coming off the road can get into the CAI.
Old 08-15-2014, 05:48 PM   #12
skuts?
skuts?'s Avatar
Drives: 2013 6spd Argento FRS/1995 BMW 325i
Soooo.... it sounds like you drove through a river then? If pratically impossible to hydro lock a motor unless your drive into a lake or try to drive through knee high water, especially with the placement of the intake snorkel/CAI intake placement
skuts? is offline   Reply With Quote
Old 08-15-2014, 05:59 PM   #13
stugray
Drives: 2013 GBS BRZ Limited
In these engines it is not so easy to just remove the spark plugs to blow out the water.
You have to lift the engine to pull the plugs.
It would be easier to pull the DI injectors than the plugs.
Old 08-15-2014, 06:51 PM   #14
mike the snake
Umm, I'm not so sure this is true.
I've read it's pretty easy to simply lift the engine by loosening the motor mounts. I've also read that with the right tools (short universal socket I think) you can do the job without raising the engine at all.
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 02:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 08:12 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
