Drives: 2010 Scion xD
Loud window pop
It only happens when the driverside door is closed and windows all the way up. When I push the roll window down button it makes a loud pop on its initial startup, if I open the door and do it it makes no sound, I feel as if the window regulator is off and causing it to pop from the pressure against the vehicle.
#2 |
You might try wiping a bit of silicone on the rubber molding at the top of the window. Maybe it's sticking to the glass.
Or, the old fashioned way ..... put a bit of soap on the molding.... ![]() humfrz |
#3 |
Mine does it too. Happens when I roll down the window, or open the door. Will also happen when the window closes.
But, it doesn't do it every time. I've tried a little armor all type lube but it doesn't do anything. |
#4 |
Drives: Firestorm FR-S (MT)
Mine does this very occasionally. I can't even remember the last time it happened, but i've had the car for 2 years and my window seals still look great, no leaking either. Seems like it's just an annoyance.
| perrin catback resonated - loud enough or too loud? | theflathead | Engine, Exhaust, Transmission | 33 | 01-22-2018 06:46 PM |
| Window Shatter / Fracture - passenger small triangular window | btune | Issues | Warranty | Recalls / TSB | 5 | 12-25-2016 03:14 PM |
| Window Scratched by Window Motor / Lifter? | tomkozski | Issues | Warranty | Recalls / TSB | 22 | 05-31-2014 08:25 AM |
| Bad Hail Damage, loud window; About ready to give up on the FR-S | SkitterSkotter | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 09-16-2013 08:25 PM |
| squeaky window due to window rubbing against rubber at the top | tracerit | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 08-10-2013 06:34 AM |
