Old 08-08-2014, 03:32 AM   #15
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by unsurety View Post
Dat clearance between the bellhousing, collector, and underbody. Free with purchase: driver and passenger side footwell warmers!
No really though, that T56 is a tight fit!
It will be fully shielded for heat and the transmission is a Tremec Magnum XL specially ordered for this project , the T56 would of required a lot of sheet metal work and still would of required a remote shifter, the XL is a direct shifter (for a much better feel) and fits the OEM shifter placement almost perfect.
cf6mech is offline
Old 08-08-2014, 03:43 AM   #16
s2d4
s2d4's Avatar
This guy is so cool.
s2d4 is offline
Old 08-08-2014, 03:45 AM   #17
cf6mech
Originally Posted by Dephective View Post
^ I recently came across a 20b Cosmo rotary and considered it for a swap. Initially was going to purchase another FD chassis. Who knows what I'm gonna do with it lol.
OP what motor are you gonna end up with? Also, are they going to be reproducing the swap parts and if so what would the price on something like this be?
For my goals right now a stock fully rebuilt LS1 is going in, I'm looking for long term reliability in strictly NA form, I'm sure some will want to up the anti with a LS3......and yes this whole project is for Vorshlag to use my car for development of a LSX swap kit for the twins.......price wise I'm not sure as I'm the test bunny customer.
cf6mech is offline
Old 08-08-2014, 03:48 AM   #18
cf6mech
Originally Posted by Jyn View Post
Up in Plano, eh?
When's the estimated completion date? May have to make a trip to see this in person
I was told by the end of August.
cf6mech is offline
Old 08-08-2014, 06:25 AM   #19
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by cf6mech View Post
A solution has already been figured out where as the GM engine is fully integrated using the stock ECU and all factory gauges / power steering / air-conditioning (a must in Texas) etc. are fully functional.....so yes all gauges work using the Toyota ECU.
Damn, that's impressive! Please keep the updates rolling as you can. I'd love to know how that was accomplished.
Calum is offline
Old 08-08-2014, 10:39 AM   #20
Griever423
Drives: 2020 BRZ PP
Price I heard was gonna be close to 20k. Maybe more.
Griever423 is offline
Old 08-08-2014, 11:19 AM   #21
FR-S Matt
Loved my LS1 in my '02 Camaro SS. Beast of an engine and a torque monster. That wasn't even a built engine... that's the scary part.
FR-S Matt is offline
Old 08-08-2014, 03:49 PM   #22
Food
Drives: ...saving up for FRS/BRZ still
Is Vorshlag going to offer a plug-n-play wiring/engine/ecu/can-bus harness with their kit?? ...or is the swap kit customer going to be expected to do all the wiring harness modifications? If the latter, will instructions be provided to the swap-kit customer?
Food is offline
Old 08-08-2014, 09:00 PM   #23
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
Motor mounts solid or is there some nvh control?
DoctorNick is offline
Old 08-08-2014, 10:00 PM   #24
Calum
That Guy
Take a look through the pictures linked. The engine mounts aren't solid, though their not terribly far off. The transmission mount is essentially solid. One side has poly, but the other side is metal to metal.
Calum is offline
Old 08-09-2014, 03:14 AM   #25
cf6mech
From what I have been told it will be plug and play and be part of the swap kit,.......this Kit is, and will be, designed for owners to accomplish in their own garage at their own pace, the complete conversion. They have gone to great lengths with countless trial and error with many different parts they have on hand and also ones they have had to order for trial to make this a kit for the masses and not just a one off build that requires copious compromises and major hacking of sheet metal. It will truly be a bolt on solution for what most of us crave and this car needs,.. more power and torque in a natural state. I went the FI route with this car (turbo), and after a ton of money with a forged short block Ferrea race valve set pushing 18lbs. of boost felt like it was a ticking time bomb even though I only put 100 miles on that engine with no issues, but there is so much that could go wrong in an instant that I didn't want to have to keep my eyes glued to the boost and AFR gauge constantly or else POP!..(As a note I did have a problem on my first build, and because so had it built stronger the second time)...btw that engine is for sale and someone is going to get a swinging deal on it. I gotta have 20k wrapped up in that thing over the cost of the engine itself.
cf6mech is offline
Old 08-09-2014, 03:33 PM   #26
SrtWtF
Drives: stock
I needs more info and update :-)
SrtWtF is offline
Old 08-10-2014, 08:50 PM   #27
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
I hope they can get the price down below Weapons Grade Performances complete swap kit ($9k + engine and trans). The two companies seem to have taken considerably different routes for mounting options. Love seeing more LSx swap options. WGP has also tapped the OEM ECU to get all the normal functions of the twins. I just started stripping mine down today for an LSx swap too.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline
Old 08-11-2014, 06:17 AM   #28
s2d4
s2d4's Avatar
They have? Do you have any video of it?
s2d4 is offline
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 09:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 10:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 08:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 05:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 01:19 PM
