Old 08-10-2014, 05:36 AM   #15
boonFRS
Drives: 2013 Scion FRS whiteout
I'm running ichiba v2 25mm spacers front and rear on eibach sportline. No rubbing.
boonFRS is offline   Reply With Quote
The Following User Says Thank You to boonFRS For This Useful Post:
Astroboy (09-13-2015)
Old 08-10-2014, 09:52 AM   #16
wparsons
wparsons's Avatar
Originally Posted by K-NoMs View Post
I was looking at the Eibach pro spacers, im new to all this so would the Eibachs work since they come with extended lugs? Thank you for all the advice so far.
IMO, at 20-25mm, you're better off buying bolt on spacers than running extended lugs. The spacer bolts to the existing studs, and has new studs in the spacer that the wheel bolts to.
flickr
Old 08-10-2014, 10:29 AM   #17
gramicci101
Off Topic
Originally Posted by trinxified View Post
Hmm I'm thinking about it... Springs, spacers, alignment and install is going to cost me near $1000...
Is it really worth it just for the looks?
Yes.
RCE yellows - 300
Spacer/camber bolt combo from corner3garage - 130
Alignment - 100
Install - do it yourself. The DIY forum has some great walkthroughs.
For $530 you've got springs that actually work with the OEM struts and handle much better, and a nice aggressive stance that makes it look like your car didn't forget leg day.
Old 08-11-2014, 12:42 AM   #18
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
@b2autodesigns is a vendor here with a quality spacer kit for an affordable price. Get a set of eibach pro springs from @rallysportdirect and you are talking $350. Install yourself, this is a basic process...
Jman1759 is offline   Reply With Quote
The Following User Says Thank You to Jman1759 For This Useful Post:
Old 08-12-2014, 12:50 PM   #19
K-NoMs
Drives: 2015 BRZ Series.Blue in WRB
Any brands you would recommend?
K-NoMs is offline   Reply With Quote
Old 08-12-2014, 01:11 PM   #20
DAEMANO
Time Traveller
Agreed with @wparsons, if you're going 25-30mm, get bolt on spacers. I contacted H&R and they said they don't recommend 25-30mm on extended lugs.
When I had my stockies I went with the B2Autodesigns set, loved the look. Just like installing any lugs make sure that they're started on the stud by hand and not an impact gun. This can cause a cross thread.
My order of preference (when I shopped for them)
H&R Track+ DRM
- German made, Aluminum Alloy, TUV approved
Eibach -German made, Aluminum Alloy, Good Service
B2 Autodesigns - Taiwanese made, Aluminum, Great service
http://www.ft86club.com/forums/showt...2+Auto+spacers
Project Kics - Japanese made - They make good conversion spacers, so I assume that their standard bolt-on's to be just as good.
Corner3 Garage V3 Spacers - Billet Aluminum, they have a running special that includes camber bolts (to add - camber to your front end)
http://www.ft86club.com/forums/showthread.php?t=46901
Ichiba - Have heard about stud issues, choose another option.
The Following User Says Thank You to DAEMANO For This Useful Post:
chaoskaze (10-12-2014)
Old 10-12-2014, 02:59 PM   #21
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Just found this thread today, was thinking wut to do to keep my Sti wheel with a more flush look. Great help, thanks\
How about tires thou? Any of you recommend a different tire size that can go on the stock size sti wheel? like 225/45/17 or 205/50/17 or 215/50/17..?
The Following User Says Thank You to chaoskaze For This Useful Post:
DAEMANO (10-12-2014)
New Here Need Ideas FRStrent Scion FR-S / Toyota 86 GT86 General Forum 30 07-10-2014 10:22 PM
iv got 12's and need ideas Top-Secret Electronics | Audio | NAV | Infotainment 10 05-05-2014 10:15 PM
Lowering Springs and Wheel Spacers... Size?? cjhopkins Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 03-14-2014 12:16 PM
WTB: Spacers and lowering spring Swabe Want-To-Buy Requests 0 05-16-2013 09:06 AM
Need ideas for possible (new-to-me) used car suprachica79 Other Vehicles & General Automotive Discussions 66 02-20-2012 06:42 PM
