Old 04-22-2012, 02:20 PM   #71
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by Calum View Post
What I find really funny is that things like the band aid fix for the rack and pinion that's too short (as mentioned in the moto iq write up) didn't get a single post, let alone a thread. That rack length is going to cause bump steer issues if anyone replaces the front control arm bushings with either urethane or bearings. The band aid fix was to use bushings that will deflect to offset the bump steer.
That's not a band-aid fix and it won't do anything to correct for bumpsteer. I suggest you re-read the article.
old greg is offline   Reply With Quote
Old 04-22-2012, 04:15 PM   #72
Sasquachulator
Pavement Grey
Double facepalm; one for the fact that this thread was created, the other for the fact that it made it past two posts.
But two square feet of carpet in a place that most people would never notice it and will make absolutely zero difference to the driving experience or the safety of the car is enough to warrant four pages of bickering.
Sad guys.
Thats because this thread is a crucial dealbreaker thread, while that one you mentioned is just....meh, nothing important.
Old 04-22-2012, 05:40 PM   #73
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by MotoIQ article
The tie rod inner pivot is inboard of the lower control arm pivot and at a flatter angle, this will cause toe in under suspension compression. the front of the lower control arm has this rubber bushing with a cutout....Perhaps this subtlety counters the toe in under roll that the tie rod location produces.
I have no association with Moto IQ and I have no idea how accurate they are. But this is what piqued my attention and I was surprised was never mentioned on here. It's on the second page of the article, near the top if you want to confirm the context.
I was surprised that more people weren't speculating about the effects this may or may not have. Personally, I've never driven a car that had the inner tie rod pivot in the ideal location to prevent toe change, I doubt I'll care much. I was just trying to make the point that there's bigger things to worry about in life and in this car, than the trunk lid liner.
Old 04-22-2012, 07:12 PM   #74
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Fair enough. But while roll-steer and bump-steer are related, they are not the same thing.
Old 04-22-2012, 08:18 PM   #75
Calum
That Guy
While this is getting off topic, at this point I don't think it matters.
Wouldn't the same toe changes cause steering angle changes, and thus bump steer, when the car goes over a bump. Or have I misunderstood the terminology?
Honest question, by the way. I know things can come across differently in text.
Old 04-22-2012, 09:01 PM   #76
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
If you actually post in another thread that ISN'T called "no trunk liner" you might actually get answers from some pretty smart suspension people.
As for this thread... I had Arby's for lunch and it was delicious.
Khyron686 is offline   Reply With Quote
Old 04-22-2012, 09:31 PM   #77
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Arby's is delicious. I really wish they would build more around here. I think bump steer refers to changes in vehicle attitude caused by the bump stops. I thought the motoiq article did a pretty thorough job of explaining the suspension geometry issue so there wasn't much more to discuss about it. And I'm not seeing what it has to do with the rack and pinion?
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Unlockable trunk? Kage FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 10-12-2013 12:57 PM
Trunk swap with my WRB premium? GMU-BRZ Mid-Atlantic 11 03-05-2012 03:53 PM
What's in your trunk/car thread? S2kphile Off-Topic Lounge [WARNING: NO POLITICS] 40 02-23-2012 03:07 PM
So is it a hatch or regular trunk? xantonin Scion FR-S / Toyota 86 GT86 General Forum 5 12-09-2011 07:26 PM
Trunk space? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 34 04-13-2011 12:29 PM
