Old 08-08-2014, 12:38 PM   #1
Firestorm_86
Drives: FRS
ST or B14's?
I'm trying to decide between the ST by KW's or Bilstein B14's (or some combo spring+damper).
Budget is around $1000. I would like to lower very little (.5" - 1") if possible; I drive on some crap roads. My use will be daily driving (on crap roads), mountains during the weekends, and a track day or two during the year. Dampers are probably highest on the list since I feel like an improvement over stock can be had. And since all springs are stiffer than stock, I'm not too worried unless it's overly stiff.
Other suggestions/combinations are welcome, but you'll have to sell your case.
Firestorm_86 is offline   Reply With Quote
Old 08-08-2014, 02:27 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
*takes a deep breath*
Hey there fellow 86 owner!! Might I suggest a lovely combo of Bilstein dampers preferrably the B8's, paired with a nice firm touch of the top of the line RCE Tarmac springs!!
hows that for a 'sell your case'?
I few users have this combo, lowers right in the middle of your drop range, superb bilstein dampers and awesome springs. search for the combo if your interested.
Only problem is that this combo is out of your budget range, comes in at $1250.
Old 08-09-2014, 07:33 AM   #3
Firestorm_86
Drives: FRS
This was a consideration. Whats your case against the B14 springs/damper combo?
Old 08-09-2014, 11:54 AM   #4
Createddeleted
Drives: 2014 BRZ - 2004 GLI
I would also like to hear why the b6/b8 and spring combo are held I higher regard than the b14's
Createddeleted is offline   Reply With Quote
Old 08-09-2014, 12:02 PM   #5
BrandonB
Drives: 2014 Whiteout Monogram Frs
I think its because b14 uses progressive springs
BrandonB is offline   Reply With Quote
Old 08-09-2014, 12:21 PM   #6
Createddeleted
RCE yellows are progressive as well and they are not frowned upon.
Old 08-09-2014, 12:51 PM   #7
BrandonB
i dont believe rce yellows are progressive
Old 08-09-2014, 12:53 PM   #8
BrandonB
You should get rce yellow with koni shocks because at the softest setting its actually smoother than stock
Old 08-09-2014, 04:31 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Progressive springs suck. Other than that they are top notch for the price. Corrosion resistant and lowering capabilities. The B8 damper from Bilstein is the B14 damper if im not mistaken.
Old 08-09-2014, 04:34 PM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Correct, they are not.
Old 08-09-2014, 05:14 PM   #11
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
+1
Old 08-09-2014, 05:24 PM   #12
Createddeleted
I did a bit more research. I was thrown off by the coil winding. http://www.ft86club.com/forums/showp...1&postcount=12
The Following User Says Thank You to Createddeleted For This Useful Post:
Racecomp Engineering (08-10-2014)
Old 08-09-2014, 05:40 PM   #13
Createddeleted
+1
Just want to discuss why you guys believe progressive springs suck. Is it because linear springs are more predictable and easier to match to a dampener? For performance, I completely 100% agree that progressive springs should not be used.
But if we take the case of the street driven car that is lowered, do progressive springs still suck in this application? Where ride quality may be improved by progressive springs and still achieve a better driving experience by tightening up the ride, reducing the COG, and reducing a certain amount of body roll. In this application do progressive springs suck, and if so why?
Firestorm_86 (08-09-2014)
Old 08-09-2014, 05:49 PM   #14
Firestorm_86
Drives: FRS
As a DD, isn't progressive better, if not desirable? I won't be tracking it all that often, so the progressive handling change at limit shouldn't be too big to deal with. But that could be my limited understanding of how progressive vs static spring rates work.
EDIT: @Createddeleted asked exactly what I meant to ask...
