Old 08-07-2014, 02:36 PM   #729
CSG Mike
CSG Mike's Avatar
Look elsewhere.
Nothing wrong with the Cusco AOS...
Old 08-07-2014, 02:38 PM   #730
Parikh1234
Drives: Subaru BRZ Limited
Originally Posted by *LongFella View Post
Depends on your current mods, gas, how hard you drive...
totally get it, but was just looking for some real world experience. What mods do you have and what kind of mileage are you getting. I just have the Jackson Racing SC and a custom tune. Not sure why its so terrible. I own a couple evos that are very highly modified and tuned and they get better mileage.
Originally Posted by dp1 View Post
Custom tune?
Yeah Custom tune. Was just wondering what the standard tune should be giving.
Parikh1234 is offline   Reply With Quote
Old 08-07-2014, 02:42 PM   #731
Parikh1234
Originally Posted by Xerious View Post
Anyone install an AOS yet? Looking at the Cusco solution.
I have the crawford AOS Installed.
Old 08-07-2014, 02:42 PM   #732
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Perrin 2.5 non-resonated CBE is really the only "performance" mod I have in addition to the JR SC Kit and JR Oil Cooler kit.
I'm running the CARB Legal Kit and Tune from JR... I'm a commuter, so I'm mostly freeway driving averaging about 28-29 mpg on the best CA 91 Octane money can buy... LOL! Our gas sucks... Just saying...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 08-07-2014, 02:44 PM   #733
*LongFella
*LongFella's Avatar
Jackson Racing Supercharger Owners Thread
I do have a coil over suspension and gram lights 57xtreme on Hankook V12's... I know certain tires and rims can play with mpg too... Plus aero dynamics, wind tunnel sh@& I have no idea about...
I guess it all adds or takes away mpg...
Don't listen me... I'm just board...
The Following User Says Thank You to *LongFella For This Useful Post:
sklimo (08-07-2014)
Old 08-07-2014, 02:45 PM   #734
CSG Mike
CSG Mike's Avatar
Unless you only drive WOT or off throttle, it sounds like you may have a questionable tune.
10 MPG is something we see at the track, or running REALLY hard in the canyons. Street driving is always in the 20's, unless you're in stop and go traffic.
This is assuming you have a set of sticky tires; expect higher with the stock tires.
Old 08-07-2014, 02:57 PM   #735
Dezoris
Dezoris's Avatar
Exactly.
Fuel trims, probably maxed out post up the cruising logs showing short and long term.
Old 08-07-2014, 03:38 PM   #736
Parikh1234
Originally Posted by Dezoris View Post
Exactly.
I do have lighter weight Enkei RC-t4 in 17 x 8 and I have 225 michelin super sport tires on there. So there is a change in the equipment. The driving I do is about 20 miles a day mixed highway / city. Nothing crazy in terms of acceleration / WOT. I put in gas this morning so I wrote down the amount of gas to the click and zero'ed the ODO. Lets see in a couple days when I fill up how much gas i've used.
Also I am going off the display in the dash, so it might be inaccurate because of all the modifications, but I am losing gas substantially faster. I have to fill my tank every 4 days instead of every 6 or 7.
Old 08-07-2014, 03:47 PM   #737
Dezoris
Dezoris's Avatar
Drive 50 MPH steady cruising speed and log your short term fuel trims or post up what you are seeing.
Old 08-07-2014, 03:50 PM   #738
Parikh1234
Yeah probably a good idea. Ill get some 50 mph in 6th gear calculations after I finish this experiment.
Old 08-07-2014, 03:53 PM   #739
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
I'm getting about 28mpg mixed street and fwy miles.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 08-07-2014, 04:15 PM   #740
CSG Mike
CSG Mike's Avatar
The majority of us here are running at least tires in the PSS range, if not stickier. Time to do some diagnostics, and perhaps a retune.
Old 08-07-2014, 04:17 PM   #741
sklimo
My guess would be the tune
Old 08-09-2014, 03:03 AM   #742
Poodles
Drives: 2015 Series.Blue
Keep looking. First thing you need to decide is if you want a vented or a non vented catch can. I recommend vented catch cans for boosted applications, and there are multiple vendors that sell them on here including @FullBlown .
Catch cans are part of the PCV system. Positive Crankcase Ventilation cannot occur with a vented system as it relies on the vacuum supplied by the engine.
Keep in mind this actually helps your rings seal, and also reduces pumping losses.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
