Old 08-07-2014, 12:42 PM   #1
Dezoris
Dezoris's Avatar
More Overpriced Junk | Tom's Tails
The deal is I had OEM tails leak twice. Had them replaced and most recent TSB done and they did not leak after.
So, you know I had to screw around and replace them with the USDM Toms.
Followed TSB and made sure they were tightened properly (basically not tightened.)
Well just look at them. Junk @FT-86 SpeedFactory
The Following User Says Thank You to Dezoris For This Useful Post:
aakash (08-07-2014)
Old 08-07-2014, 01:16 PM   #2
RFB
RFB's Avatar
Drives: FRS
They are NOT junk. ALL tails are subject to leaking due to the cars design flaw.
Fix the flaw for 99 cents and all is well.
CERBERUS
RFB is offline   Reply With Quote
Old 08-07-2014, 01:39 PM   #3
Dezoris
Dezoris's Avatar
CERBERUS
Come fix my car then, whats the problem?
Old 08-07-2014, 02:09 PM   #4
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
The gaskets suck.
Chen is offline   Reply With Quote
Old 08-07-2014, 02:32 PM   #5
Dezoris
Dezoris's Avatar
Originally Posted by Chen View Post
The gaskets suck.
Tom's came with new gaskets, is there some secret to installing foam gaskets and tail lights for this car that don't apply to every other car on earth?
Old 08-07-2014, 02:47 PM   #6
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
get some of that sticky spray from the infomercials and wahla, fixed! If it can make a screen door as the bottom of the boat work, I'm sure it can keep some condensation out of some tail lights
JesseE is offline   Reply With Quote
The Following 3 Users Say Thank You to JesseE For This Useful Post:
DAEMANO (08-07-2014), Dezoris (08-07-2014), sprintertrueno86 (08-08-2014)
Old 08-07-2014, 02:48 PM   #7
CSG Mike
CSG Mike's Avatar
Hmmm I've actually not seen very many leaky taillights lately, but California is also in a drought, so I'm useless here
continuecrushing (08-07-2014)
Old 08-07-2014, 02:54 PM   #8
Dezoris
Dezoris's Avatar
The answer then is to move to California or should I bottle the water and send it to you?
The Following 3 Users Say Thank You to Dezoris For This Useful Post:
aaronglass (08-08-2014), hmong337 (08-07-2014), JesseE (08-07-2014)
Old 08-07-2014, 03:08 PM   #9
DarkestBuddha
Drives: BRZ limited GBS
i think all tail gaskets for this car need to be glued to the tails with 3m weather adhesive or whatever you can find
DarkestBuddha is offline   Reply With Quote
Old 08-07-2014, 03:15 PM   #10
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
I would gladly take buy them off of you if you are fed up
gatorbushmen is offline   Reply With Quote
Old 08-07-2014, 03:17 PM   #11
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Well, for what it is worth, I have had the EU spec TOMs on my car for about six months now, and there is absolutely no condensation / leak issue. This is despite the lovely weather we have here in the UK, and the fact I wash my car at least once a week, very often with a pressure washer.
Having said that, I had absolutely no problems with my OEM lights either.
Pitman is offline   Reply With Quote
The Following User Says Thank You to Pitman For This Useful Post:
Sideways? (08-07-2014)
Old 08-07-2014, 03:24 PM   #12
Dezoris
Dezoris's Avatar
Its very possible its related to the rear frame of the car, or needs extra gasket or extra goo to attach gaskets. I don't know, but things that should be easy aint.
Old 08-07-2014, 04:05 PM   #13
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
no issues on my TOM's and I have had them on the car for a year in Nebraska. I knew the OEM gaskets sucked and the TOM's ones looked better than the OEM, proved correct. I have the USDM wired JDM ones though with the amber turn signals.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 08-07-2014, 04:11 PM   #14
DJCarbine
Thupercharged
DJCarbine's Avatar
When I took my OEM tails off I remember doing some metal bending, very minor... I think it was around the bolt holes, the tightening done during the build at the factory deformed the metal slightly and it needed some tweaking
I'm going to check mine right now actually, there was a pretty bad rain storm a few days ago
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
jdm condensation, op has downs
Junk in the Trunk Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 347 04-29-2022 05:25 PM
Does the Audi S3 make the WRX STI look overpriced? WolfpackS2k Other Vehicles & General Automotive Discussions 90 09-09-2014 09:37 AM
Trade: Black Spyder V1 Tails for Tom's Tails Cross Exterior Parts (Aero, Lighting, Etc.) 3 07-05-2014 04:19 PM
Junk in the Trunk: nataku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-04-2013 06:17 PM
How much junk in that trunk? Tobz Scion FR-S / Toyota 86 GT86 General Forum 8 07-21-2012 10:13 PM
