Old 08-07-2014, 11:56 AM   #1
ppbiggums
ppbiggums's Avatar
Drives: '14 BRZ Limited
Question Noob question about exhaust
Do i need to get a catback before i turbo? Because i want to get the nameless axleback but someone told me in order to turbo you need a catback
ppbiggums is offline   Reply With Quote
Old 08-07-2014, 12:00 PM   #2
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
You should read a lot lot lot more about turbochargers before you consider one, if this is your question.
But to answer it straightforward, with an aftermarket exhaust system, you normally want to increase the diameter of the pipe (ex. - from 2.25" to 3"). This allows you to push more exhaust gases through the pipe, which gives more room for moar powah.
But really, read up on the forced induction subsection on this forum. Learn more. You will not regret it in the end.
Jyn is offline   Reply With Quote
Old 08-07-2014, 12:06 PM   #3
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Can't tell if serious or trolling.
Axlebacks do nothing but change tone.
If you're thinking or going turbo for the most power you want to remove as much restriction as possible so that would be a full turbo back catless exhaust.
However, catless exhausts have their drawbacks (i.e. May be too loud for most, catless may be illegal for emission and smog tests, etc.)
To answer your question you don't "need" to have a catback but it will help.
To prevent yourself from buying multiple exhausts I suggest you take a long look at what goals you have for the car and go from there.
It won't be cost effective for you to buy an axleback then realize that you're losing power and increasing your EGT by not having a larger diameter exhaust. Then you buy a catback but realize your 2.25" catback is also a bottleneck and costing you spool time and increasing lag before you finally get a 3" turbo back that had you gotten it all along you would've saved some money over buying interim exhausts
If at all possible, you only want to buy components once and the first step to minimize the chance of you buying something a 2nd time because the 1st didn't work is to lay out your goals.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 08-07-2014, 12:14 PM   #4
ppbiggums
ppbiggums's Avatar
i really should have thought about this for a second before i posted
Old 08-07-2014, 01:22 PM   #5
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
You can turbo your car on the stock exhaust and make good base tune power.
If you're chasing large power numbers, you'll see benefits in upgrading your catback but not until you open up the exhaust further up-stream. (Downpipe, overpipe, front pipe)
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
axleback, catback exhaust, exhaust, nameless
noob question here about f.I.... zimzum Forced Induction 7 03-06-2014 04:24 AM
noob question regarding after market exhaust Cyau Engine, Exhaust, Transmission 7 06-09-2013 02:16 AM
NOOB Exhaust Question N_I_N Engine, Exhaust, Transmission 2 05-07-2013 09:11 PM
Noob Question.. wWaldo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 02-21-2013 08:04 PM
Noob question fitcious Cosmetic Modification (Interior/Exterior/Lighting) 2 05-02-2012 11:18 PM
