Old 08-06-2014, 02:33 PM   #1
Xti
Drives: Fast, Cool, New
How many of you Swapped your 86 for 15 WRX ?
As 15 WRX has FA20 DIT. The exact same engine in the 86....just different Direct Injection system, and a turbo.
I just wonder
Xti is offline   Reply With Quote
Old 08-06-2014, 02:35 PM   #2
ModBargains
ModBargains's Avatar
Drives: FRS, M3
How did I miss this fact. Thank you for bringing it to my attention.
ModBargains is offline   Reply With Quote
The Following 10 Users Say Thank You to ModBargains For This Useful Post:
8R6 (08-08-2014), Ammonia (08-06-2014), chas3wba0 (08-06-2014), continuecrushing (08-06-2014), JohnJuan (08-06-2014), pcporo (08-06-2014), Redlinedfrs86 (08-06-2014), TJ3000 (08-09-2014), tomato86 (08-07-2014), Turbo95eg6 (08-06-2014)
Old 08-06-2014, 02:37 PM   #3
Xti
It was an honest question. The dealers here rarely has any WRX or STI on the lot, at all....I talked to the sale rep, and he said they have been flying out of the lot
Old 08-06-2014, 02:47 PM   #4
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
You are one curious fellow, Xti.
Old 08-06-2014, 02:48 PM   #5
Ingen
Drives: Ultramarine FR-S 6MT
So I decided to take a peek, since it seems like it'd raise the fuel economy.
1: Not really, 6MT is 21/28
2: LMFAO the CVT gets 19/25! What was the point of that, again?
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 08-06-2014, 02:53 PM   #6
DarkSunrise
DarkSunrise's Avatar
I saw the other day that Car and Driver measured the CG height on the new WRX at 19.5". Weight distribution at 60/40. Curb weight at ~3300 lbs. So it's not exactly a turbo BRZ with AWD, as you might think.
I know @thill made the switch so he can probably comment on the differences first-hand.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
DAEMANO (08-06-2014)
Old 08-06-2014, 02:56 PM   #7
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Rather buy an S3. Yeah no manual, but why own one car?
Old 08-06-2014, 02:57 PM   #8
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
the STI...
The STI still uses the FJ25...
Jaden
Jaden is offline   Reply With Quote
Old 08-06-2014, 02:59 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I definitely wont.
My wife had a 2011 Corolla, and we don't want another corolla. Granted, the new subaru corolla has a scoop on the hood, but otherwise I see no appeal.
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
chas3wba0 (08-06-2014), ML (08-06-2014)
Old 08-06-2014, 03:05 PM   #10
ML
ML's Avatar
Drives: 13 White MT FR-S
I wonder when we will see people doing a OEM turbo swap from the fa20dit? its probably already happened hasn't it?
Old 08-06-2014, 03:05 PM   #11
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
I just wonder
So has anybody done a build with stock WRX turbo and Direct Injection Sytem in the Twins yet???
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 08-06-2014, 03:16 PM   #12
thill
My thoughts from another thread on the two cars:
Owned a BRZ and now a 15 WRX. Just some of my thoughts:
Pros for the BRZ:
- Even though both cars have the same ground clearance, the BRZ has a much lower feeling center of gravity. You sit low in the car and you really feel more connected to the road. The seats in the new WRX are higher. You get great visibility, but you lose the sports car feeling. BRZ cockpit is more drivers focused. Seats are better in the BRZ. WRX has more amenities and some nicer feeling materials.
- Light and RWD. Don't get me wrong, I love AWD in the winter, but BRZ is a more fun car to drive if you enjoy sliding the rear end out from time to time. For me light and RWD is the perfect recipe for a sports car.
- Handling is better. Steering feel is better. I just felt more connected to the road and the car feels slightly more intuitive to drive than the WRX.
Pros for the WRX
- Power. The new WRX has a twin scroll turbo and a direct injection engine. Lots more torque down low than the BRZ and more linear response.
- AWD in the winter. If you put snow tires on these cars they are very confidence inspiring in inclimate weather. It also helps with launching the car.
- A backseat you can put real humans in.
- WRX has amazing resale value.
Make no mistake. The new WRX is a much better handling car than the previous gen WRX. Much stiffer chassis. Sharper steering. No bodyroll. I like the newer engine better and MPG's are very close to my BRZ.
It just comes down to if you are willing to give up the true sports car for the sporty sedan that has more power and is more practical if you haul people.
The Following 7 Users Say Thank You to thill For This Useful Post:
Braces (08-06-2014), DAEMANO (08-06-2014), DarkSunrise (08-06-2014), m.wood0213 (08-06-2014), Rampage (08-08-2014), RussianNinja (08-06-2014), Xti (08-07-2014)
Old 08-06-2014, 03:17 PM   #13
CoupedUpSubie
Drives: 2013 BRZ Limited
The FA20 and the FA20DIT are just as different as the BRZ and the WRX are. The FA20 is a high compression engine where the FA20DIT Is low compression. Not to mention that where the DI systems are different you can't put FA20DIT heads on a FA20. These are the old EJ series engines like all the Subaru people are used to seeing.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
Astroboy (08-08-2014)
Old 08-06-2014, 03:18 PM   #14
thill
Huh? The FA20DIT is nothing like the EJ series engines..
BRZ with LS2 V8 swapped in video SnapOv3st3r BRZ Photos, Videos, Wallpapers, Gallery Forum 14 11-14-2013 05:04 PM
BRZ Swapped with LS2 weedtank FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 09-05-2013 05:02 PM
Swapped badges JesseE Northwest 7 03-13-2013 05:20 AM
has anyone actually swapped the brz front bumper for an frs? fiveoneoh Cosmetic Modification (Interior/Exterior/Lighting) 1 02-27-2013 05:09 PM
EJ25 has already been swapped Tad_07 Engine, Exhaust, Transmission 3 03-25-2012 05:10 PM
