Old 08-06-2014, 01:13 AM   #1
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
Exclamation tranny problem, really freaked out
so i am getting alittle scared, because every time i down shift it grinds in 4th gear. I'm not trying to be a little pr*ck or anything but i am pretty good at down shifting :burn rubber: and in every gear its fine except 4th i have a kartboy short shifter, white line shifter bushing and kartboy rear bushing (or whatever it is) and i don't think any of these would cause this. WTF DO I DO?!?!?! I'm scared to drive it. I've been trying not to down shift but it suxxx
sweetfrs is offline   Reply With Quote
Old 08-06-2014, 02:35 AM   #2
Fastbrew
Drives: 2014 Pearl White BRZ
Well, you could be scared or take it to the dealer. If you have modded it, you could take it to the shop. Just a thought.
Fastbrew is offline   Reply With Quote
Old 08-06-2014, 04:05 AM   #3
kALMIGHTY
Drives: TRD Ultramarine '13
I thought this was a thread about Thailand....
Old 08-06-2014, 04:32 AM   #4
JB86'd
JB86'd's Avatar
Drives: JAWS
What fluid are you using? I would either A. Go back to stock setup and see if it still does it. If it does, your synchro is probably shot and you should visit the dealer.
Or B. If you're still on stock fluid, try Motul 300. Seems lots of people have problems with 4th grinding.
JB86'd is offline   Reply With Quote
Old 08-06-2014, 06:03 AM   #5
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I have the same issue and you have a bad transmission. A lot of people have this issue. Take it to the dealer and get your new transmission on order and all will be right in the world.
It's become such a common issue now I didn't have to take my car in to the dealer to get a new transmission on order just me name and vin number over the phone.
Sent from my Q10
Old 08-06-2014, 08:08 AM   #6
Ingen
Drives: Ultramarine FR-S 6MT
Sent from my Q10
is this a problem with fifth gear too? I've been having a crunchy-grind every 2 weeks or so while shifting up in to 5th. Not readily repeatable at this time. The clutch pedal is on the floor and it just grinds anyway
Obviously no dealer yet, as I can't get it to repeat. But when it does repeat I will definitely hit them up... This is stopping me from modding the car because I don't want to be blamed for their bad trans
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 08-06-2014, 08:36 AM   #7
Accurate Race Shop
Drives: Scion FR-S
I think the dealer said it was an issue with the syncros so it could happen in any gear. I have heard of it happening to 2nd and 6th (6th caused catastrophic failure) as well like mine and op (4th). So it sounds like it can happen to any gear.
Sent from my Q10
Old 08-06-2014, 10:27 AM   #8
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
Alright i will be taking it to them, i hate goin to dealers they dont know about jack when it comes to our cars!
Old 08-06-2014, 10:34 AM   #9
stugray
Drives: 2013 GBS BRZ Limited
I would return it to stock first.
Otherwise you are asking for a denial of warranty service because you modified the shifter.
They could easily make the case that it was your shifter mods that caused the problem (even if it didnt)
Old 08-06-2014, 10:37 AM   #10
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
Fml @stugray
Im still on stock fluid
Old 08-06-2014, 12:23 PM   #11
Dezoris
Dezoris's Avatar
Bite the bullet remove your mods on trans and go to dealer. Trans fluid is not going to fix that.
Old 08-06-2014, 12:46 PM   #12
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
Yea it's not fluid, do you think I should really take mods off just for the check up like to figure out what it is? They aren't going to take the center console apart to see if I have a sts @Dezoris
Old 08-06-2014, 01:14 PM   #13
JB86'd
JB86'd's Avatar
Drives: JAWS
You should definitely take the mods off.
Old 08-06-2014, 02:22 PM   #14
wheelhaus
wheelhaus's Avatar
I agree remove the shifter mods. They will only be triggers for the dealer to point fingers and deny the claim.
Some might argue that it's fraudulent to return a car to stock to get warranty work done, but in this case its virtually impossible for an internal problem to be caused by bushings and a SS.
If it was a known mod-friendly dealer then I'd say leave them because they clearly don't modify how the transmission itself works internally, only how your input feels.
Tranny problems? ayephoe Engine, Exhaust, Transmission 15 06-25-2014 10:39 PM
manual tranny bjun BRZ First-Gen (2012+) — General Topics 19 01-29-2013 05:57 PM
Confirm Tranny Oil Mac1235 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-31-2012 02:37 PM
How strong is tranny? theaero Engine, Exhaust, Transmission 14 04-27-2012 07:51 AM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 06:08 PM
