Old 08-05-2014, 02:53 PM   #1
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Red face Is there a need for 400$ lower control arms ?
Planning to drop my car on Prokit and wanted to gets some LCA's and camber bolts to adjust everything when it's done, might aswell go for it while everything is on the jack being worked on. After looking around, I've seen LCAs go for a huge range. SPC seems to be sold for a reasonnable 200$, Buddy Club look to be the next option at 400$ and then you have Agency Power that go for like 650$...
What's the real deal with all this. Is it the coating ? The brand ? The adjustability ? The JDMness ?
What justify the 200$ upgrade for the Buddy Club in such a situation ?
Because in my opinion, especially on a lowered car, lower control arms couldn't even be seen unless you're laying down on the pavement.
Side question
: Is there an advantage to Whiteline camber bolts over OEM crash bolts ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 08-05-2014, 02:56 PM   #2
kALMIGHTY
Drives: TRD Ultramarine '13
I just dropped my car on TRD springs, which are rebranded Prokits and no, you don't need LCA's for a 1 inch drop that these springs give. Just get an alignment and everything should be back to optimal specs without any camber bolts or LCA's.
The Following User Says Thank You to kALMIGHTY For This Useful Post:
SkAsphalt (08-06-2014)
Old 08-05-2014, 02:58 PM   #3
jvincent
jvincent's Avatar
I remember seeing here some posts that questioned the durability of SPC stuff, especially if you are going to track it. We have the extra worry about winter.
Regarding camber bolts, unless you want to run bolts in both upper and lower holes to get more camber, then probably not.
Old 08-05-2014, 03:19 PM   #4
Simon99
Simon99's Avatar
I mean for the price of oem crash bolts might aswell get them but yeah wondering if LCAs are needed for my rear
I am indeed lightly tracking it (so far) but I am not taking it out during the winter time so I am not really afraid of the rust. I was just really wondering why there was such a big margins in products realizing a similar goal
Old 08-05-2014, 03:24 PM   #5
Griever423
Drives: 2020 BRZ PP
There is usually a difference when it comes to build quality and customer service with bigger name brands. There are; however, always exceptions to the rule.
Griever423 is offline   Reply With Quote
Old 08-05-2014, 03:26 PM   #6
Simon99
Simon99's Avatar
I agree with that, and I though buddy club were designing quality parta, hence why I wonder why they are priced so low compared to other brands..
Old 08-05-2014, 03:29 PM   #7
wparsons
wparsons's Avatar
How are you adjusting camber back to factory spec without camber bolts or LCA's? There is no camber adjustment stock, at all.
flickr
Old 08-05-2014, 03:33 PM   #8
CSG Mike
CSG Mike's Avatar
SPC LCAs are normally priced per arm, not as a pair.
The question you should be asking, is it worth going from a $400 SPC/Buddy Club set to a $600 Cusco/SPL set.
Our opinion is that you're better off getting a high grade component for a rather critical component of your rear suspension. We've seen enough SPC and Buddy Club failures where we cannot recommend the brands as a whole.
OEM Crash bolts are cheaper. Whiteline camber bolts are just SPC bolts in a Whiteline bag.
DustinS (09-11-2015), Simon99 (08-05-2014)
Old 08-05-2014, 03:40 PM   #9
Griever423
Drives: 2020 BRZ PP
I'd go with SPL myself personally. There are guys running those and a simple entry level coilover around here locally and they are putting down smoking times at the track.
Old 08-05-2014, 04:18 PM   #10
Simon99
Simon99's Avatar
Which one would you recommend for light tracking and daily driving on rough roads full of potholes ?
Old 08-05-2014, 04:40 PM   #11
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Ive had SPC arms for nearly 10000km now including 6 auto x days and 2 lapping days with no issues or slippage.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 08-05-2014, 07:26 PM   #12
CSG Mike
CSG Mike's Avatar
You won't get slippage. You *probably* won't have any issues, but if you do, it'll be a catastrophic one. We've had enough customers have them that we will not sell SPC arms anymore.
SPL.
funwheeldrive (02-28-2015)
Old 08-05-2014, 07:32 PM   #13
themajesticone
themajesticone's Avatar
Drives: '13 UM86
SPL.
In that case, this package: http://www.ft86speedfactory.com/ft-8...-rce-1082.html is not even worth including the SPC's? What LCA would you recommend? or would it be fine to stick with stock even for track use?
themajesticone is offline   Reply With Quote
Old 08-05-2014, 07:35 PM   #14
CSG Mike
CSG Mike's Avatar
We recommend the SPL.
Stock will not fail, but it also has no camber adjustment.
SPL part next to a failed SPC part on one of our sponsored driver's cars.
themajesticone (08-05-2014)
DME Lower Control Arms and DME Toe Arms - Review FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-24-2015 11:53 AM
Lower Control Arms DriftEightSix AUSTRALIA 18 05-03-2014 10:56 PM
PSM Lower Control Arms Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-26-2014 02:04 PM
Wtb: lower control arms natesparxxx Brakes, Suspension, Chassis 3 04-07-2014 07:29 PM
WTB: SPC LCA (Lower Control Arms) AG3NT_5CARFAC3 Want-To-Buy Requests 9 02-19-2014 01:30 PM
