#295 |
formerly Dixie Normous
Drives: The ladies wild!
#296 | |
Kuruma Otaku
Toyota is putting their stamp on this engine, don't worry.
Because titanium. |
#297 |
Drives: Accord Coupe
though i would love a turbo option if this na motor is built right..(8k ish redline) 200 0r more hp im on it.
#298 |
Only problem I see with a NA 200ish hp is it will be like the f20/22c in the s2000. What I mean is it will be difficult to get extra power out of them (with out going forced induction) because the motor is already almost as good as it can get NA. You know what i mean?
#299 | |
Site Moderator
Drives: ichi 86 Project
#300 |
#301 | |
Kuruma Otaku
Cut rotational mass. Light wheels and tires, aluminum hat brakes, carbon or aluminum driveshaft, remove unnecessary drains on the motor like AC and power-steering (no prob with a FMR layout I hope, bloody workout with a Supra), light flywheel and clutch, light crank damper and pulleys, etc... Then unsprung weight, then any extra weight. I'm currently even looking into doing an electric water pump, controller and thermostat delete on my Supra which should be apparently good for 10-15 wheel HP at high rpm.
Because titanium. |
#302 | |
Site Moderator
#303 | |
RaggedEdge Autosports
Drives: 97 APU Supra
Red JZA80 APU Supra 800whp
White 07 Turbo Si 411whp *RIP* ![]() |
#304 | ||
hashiryu
Drives: Mk4 Supra
Direct injection is the key to unlock this door. Remember also that the S2000 is 240hp, so there will still be a couple ponies I think you can pull out of a 200hp 2.0l NA without going "crazyracecamsstallingatthelightsbuiltforarallysta ge" kind of mods. Formula Atlantic 4AGE = 240hp out of a 1.6L engine. Can we see 300hp out of the FT-86's motor in race trim? An S2000 spec BEAMS 3S pushes 270hp give or take. |
#305 | |
#306 | |
Kuruma Otaku
VVT-i I've got to figure out but apparently it can really help with spool. And I haven't decided on upgrading twins or going single. Also having weird fantasies about running a boxed individual throttle body setup. (One of the local tuners did this with a turbo AE86.) I'm looking for as much response as possible from 2.5L
Because titanium. |
#307 |
Kuruma Otaku
I'm thinking this will allow for more aggressive (lean) AFR's safely, right?
Because titanium. |
#308 |
hashiryu
Drives: Mk4 Supra
| FT-86 Concept to be unveiled at Toyota Metapolis on 10/23 ahead of Tokyo Motor Show! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 12-15-2011 11:19 PM |
| Live pics and videos of Toyota FT-86 from Tokyo Motor Show (compilation)! | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 67 | 10-31-2011 08:09 PM |
