Old 07-29-2014, 02:14 PM   #1821
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Hey guys. I was just curious to see if anything might be wrong in the way I have my coilovers dialed in (tarmac 2) the ride is a bit bouncy. They are set to your recommended settings but I softened the rear 1-2 clicks after this track event. Here is a video from the event. Thank You
[ame]http://youtu.be/-2MmKPtJZ1M[/ame]
Rocket.BRZ is offline   Reply With Quote
Old 07-29-2014, 04:12 PM   #1822
Racecomp Engineering
Give me a call tomorrow ( WED ) I will be driving out to Mid Ohio and have 8 hrs to burn in the car. We can go over a few changes to make etc.
Myles
443 370 9000
Old 07-30-2014, 02:05 AM   #1823
cjcoupe
Drives: White GTS
Been thinking of the TWS T-66F in 18x8.5. What would be the advantages of going with 17x8 with regards to handling given it is already a light wheel. I like the aesthetic advantages of a big wheel but is it worth it? At this stage, no forced induction. I want to fit the ap sprint kit and 18x8 does not fit putting it out of contention.
Also if I go with 17x8 will I be able to continue to use the stock suspension without disadvantage in handling given the wider width compared to stock?
cjcoupe is offline   Reply With Quote
Old 07-31-2014, 03:01 PM   #1824
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Bobblehead View Post
What are the "staples" for making the car handle even better, bracing included. For Fox body Mustangs it was sub frame connectors, front strut tower brace and better springs.
What's this car's secret to "slot car" handling?
A good alignment is something that should be done off the showroom floor IMO.
Tires of course make a huge difference. Emphasis should be on tire compound, not just wider tires.
The rest of it depends on how you plan to use the car.
For a "fun" daily driver I personally would do:
1. alignment (camber bolts at the least, possibly rear LCAs to get it perfect)
2. good summer tires (michelin PSS are a good option for a DD)
3. good springs (perhaps RCE Yellows)
4. good dampers (Bilstein HD or Koni Yellow)
5. rear subframe bushings and MAYBE a few others
That's really it. For a more track focused car I'd look into good quality coilovers with camber plates and as many bushings as I can. Then track time.
With regards to springs...there's a lot of talk about them negatively impacting handling and I think that's true most of time. But they're not all the same. Naturally I like our RCE Yellow and Tarmac springs, but Swifts and Eibach Pro-kit are okay too.
- Andy
I couldn't agree with Andy enough. This is my DD/canyon car which I am hoping to get competative locally in STX eventually., just need tires and power mods, lol. I currently have RCE yellows on 225/45/17 Potenza S-04 (similar to the PSS, but cheaper). Just installed crash and camber bolts in the front to get just over -2 camber and holy cow is it amazing. I have a set of Koni Yellows I got basically for free but am waiting to replace one that is blown. Those along with the Whiteline rear UCA camber bushings I am installing next week and I think I am set for a while. I also have the rear subframe bushings and they are a killer addition, expecially for the price.
If I didn't get a deal on the Konis I porbably would have saved for the Bilsteins. If you like a more neutral car (it will rotate but just not as easy as stock, which is too easy IMO) go with RCE springs. If you want more tail happy rotation then I would say go with swifts as they are stil a staggered rate. Those were my choices and a 20 minute phone call to RCE had me confidant in ordering and I don't regret it one bit.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Bobblehead (07-31-2014), Racecomp Engineering (07-31-2014)
Old 08-03-2014, 11:00 PM   #1825
knipple
Drives: 2013 Ultramarine Scion FR-S
When tuning a double adjustable shock (e.g. RCE Tarmac 2 coilovers), how do the adjustments affect the behavior of the vehicle?
knipple is offline   Reply With Quote
Old 08-03-2014, 11:10 PM   #1826
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Totally overlooked this thread...
I made my own earlier today, perhaps you can give you me your thoughts?
I want to upgrade my suspension so that I can run my car as a somewhat comfortable daily driver, but also be able to take it to track days every month or two and have it perform well. I think many of you would agree, keeping stock shocks and doing an upgrade like this: http://www.ft86speedfactory.com/ft-8...-kit-1152.html won't cut it for track at least. I have a few options in mind (see below) and I would really appreciate some constructive responses.
*I understand that yes it is non-adjustable vs. adjustable. Keeping that in mind I really have no idea how often I would actually adjust ride height realistically. If there is a better option than the ones I have listed below please offer the suggestion so I can take it into account. Thank you.
Would really like to hear from @Racecomp Engineering @CSG David @CSG Mike and @FT-86 SpeedFactory
1) Bilstein B8 Package(RCE Yellow) - http://www.ft86speedfactory.com/bils...llow-1421.html
2) Bilstein B8 Package(RCE Tarmac) - http://www.ft86speedfactory.com/bils...rmac-1422.html
3) Bilstein B8 Package(Pro-Kit) - http://www.ft86speedfactory.com/bils...-kit-1424.html
4) Bilstein B8 Package(Sportline) - http://www.ft86speedfactory.com/bils...line-1423.html
5) Bilstein B14 PSS Coilovers - http://www.ft86speedfactory.com/bils...vers-1216.html
6) Skunk2 Pro-C Coilovers - http://www.ft86speedfactory.com/skun...vers-1725.html
7) KW V1 Coilovers - http://www.ft86speedfactory.com/kw-v...vers-1001.html
8) Fortune Auto V5 500 Series- http://www.ft86speedfactory.com/fort...lover-206.html
What should I go with?
themajesticone is offline   Reply With Quote
Old 08-04-2014, 02:56 AM   #1827
finch1750
finch1750's Avatar
In that budget i would say option 2. It will be a fantastic setup handling wise while keeping a good amount of DD comfort. If you track just to learn and have fun it will should be perfectly capable.
themajesticone (08-04-2014)
Old 08-04-2014, 03:11 AM   #1828
themajesticone
Drives: '13 UM86
In that respect would option 2, Bilstein B8 Package(RCE Tarmac) be a better performer than the Bilstein B14 PSS Coilovers? I just don't see myself adjusting or wanting to adjust. Plus the B14 can only adjust right height, not dampening, so in that instance getting a complete package with the tarmacs,b8 and lca's is a better overall option, right?
And yes, I would be tracking to learn more, have fun, and get better at track driving with the semi-comfort of daily driving.
Old 08-04-2014, 10:30 AM   #1829
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
In about a month or so, I'll be in a financial position to pull the trigger on the Raceseng cascam plates (unless the RCE plates suddenly become available). My question is, what are the cons (if any) to maxing out caster?
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 08-04-2014, 11:24 AM   #1830
posted in your other thread.
B14 vs. B8+RCE Tarmac is a tough call honestly. B14 use progressive springs and I much prefer linear springs at the track. They are firmer at their final rate (at least for the rear) but you may find the B8+RCE Tarmac combo to more consistent and easier to drive fast.
- Andy
Old 08-04-2014, 11:27 AM   #1831
Do it. When you get reeeeally far up there steering feels a little funny, but we don't get up to that point.
- Andy
Turkish (08-04-2014)
Old 08-04-2014, 11:28 AM   #1832
I've got a write-up on my home compy that I'll post tonight.
- Andy
Old 08-05-2014, 09:04 AM   #1833
Plagiarizing myself:
"Compression, also known as bump, controls how the damper compresses over bumps and during body roll. Adding compression damping can improve the stability, feel, and feedback of the car. Too much compression can cause the car to skip or skate over bumps and feel unstable.
Rebound controls how the damper extends back over bumps and during body roll. Adding rebound reduces excessive movement of the chassis and improves stability. Too much rebound can reduce overall grip in cornering and transitions. Too much rebound can also reduce traction coming out of slow speed corners. Too little rebound will feel make the car feel floaty or bouncy."
From Penske:
Track Tuning (GENERAL):
Compression Adjuster:
This adjuster is typically used when looking to improve the car over bumps. If your vehicle is hitting a certain bump that is causing the vehicle to “unload” the tire, simply soften the compression adjustment.This will allow the shock to absorb the bump, there keeping the vehicle more stable and making the car more controllable. You can also use this adjuster to help in controlling the “platform” of the car, or the body roll. Example‐ If you are entering a corner and under braking the front of the car is diving to quickly or the weight being transferred from the back to the front is too much, simply close the compression adjuster on the front to slow that weight transfer down.
Rebound Adjuster:
The rebound adjuster is a great tool for tuning body roll. This is a much more driver sensitive adjustment than the compression. If you want to slow the pitch of your car from the back to the front, simply close the rebound off, this will slow the weight transfer.
When you are accelerating off a corner, getting weight transfer to the rear tires is very important for grip or “forward bite” as its reffered to sometime. By softening the front rebound, this will allow for quicker weight transfer to the rear tires, resulting is better rear grip. Be careful though, by allowing to much weight transfer to the rear, you may cause a loss of front grip, resulting in an “understeer” or “tight” condition.
There are other guides floating around out there.
It's important to note that the damper does not control how much body roll you have, but rather the rate of body roll. That still has a big impact. So you will feel there effects more on corner entry and corner exit. Dampers will not have a big effect on long steady state corners.
Generally we start from full soft and work our way up when tuning (but when setting the adjuster remember to turn to full stiff and adjust back...full stiff "zeroes" the adjuster). Then we fine tune from there.
There is a LOT to say about how each adjustment affects the car in certain situations. Once you get a feel for what compression and rebound does, things start to click and you know what to do about that slight bit of corner entry understeer...
- Andy
CSG Mike (08-06-2014), MINOCIN (08-05-2014)
Old 08-07-2014, 12:50 AM   #1834
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Originally Posted by jvincent View Post
I've actually got both installed .
I'm guessing you had to drop the subframe to insert those?
sittinSideways is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
