#29 |
Drives: 2013 Whiteout Scion FR-S
#30 | |
Drives: Frs
#31 |
Drives: 2015 Raven FRS
Baseline Acceleration Tests
I am using the GTEC-PTO RR meter for my 0 to 60 acceleration tests. http://www.gtechpro.com/rr_fanatic.html On each test I went both directions to account for any wind or elevation change. Air conditioning off and all traction controls off. The 1st conclusion I realized is the car will do lower 0 to 60 times in automatic shifting by it's self over manual mode with me shifting @ 7000 rpm. I couldn't believe it at 1st but after a dozen runs or so The proof was on the clock. Full automatic mode was consistently 1/4 second faster. Loading the converter to 2000 rpm gave me slightly better times than nailing the gas from idle. After several base line runs the best I was able to do was a 8.28 0 to 60 time. This was consistent over several runs. |
#32 |
I have suspected from a long time that the factory OEM AT transmission software tune keeps optimal shift points when you are mashing the throttle versus taking manual mode to 7K or 7200 each shift. I know it sounds strange, but sometimes shifting at the highest RPM point before redline is not the best thing to do. I have no data to support this, and it is counterintuitive... But sometimes when I'm driving in full auto sport on and feeling how this AT actually feels reasonably quick and aggressive, I have been wondering that for a while.
| The Following User Says Thank You to Captain Insano For This Useful Post: | kavanagh (07-07-2014) |
#33 |
Drives: GT86 '13 AT, Supra 3.0i Turbo' 91
Anyone compared single gear ratios and RPM to the dyno curve? Does the factory tune match the power curve after shifting better then redlining?
#34 |
Automatic Hooligan
I haven't really noticed a huge difference between auto and manual mode; I'll have to mess with it a bit more and see. Sport mode definitely doesn't do anything in M.
1st gear in M is extremely short and it's very easy to hit the rev limiter if you aren't paying attention, however. I usually end up going up into 2nd fairly quickly.
#35 |
Fat on Corn Syrup
I'm going to have to do a bigger series of back to back pulls when it cools off. This data is kind of inconclusive in my opinion since I only did a single pull for each different setting, so please don't use it as a basis for any serious decisions. I'm only presenting it to keep conversation going and to show how close the two modes were in my particular testing. I plan to do at least 4 pulls on each setting (48 total pulls) when it cools off here, but for now, here is the data.
I used Dash Command on iPhone with an elm327 wifi dongle to log all results. ![]() Environmental conditions: 112* F ambient air temp, ~153* F intake temp, ~230* F oil temp. ![]() Current car configuration - aFe dry air filter, aluminum air tube with sound generator delete, Berk dual tip muffler delete, e85 tune (this is a test canned tune for a vendor for autos) I've arranged the results in different ways to make different comparisons. Here are my very generic observations which require further testing to validate: 1. Auto mode accounts for more of the quickest times to each interval (0-20, 0-30, 0-40, 0-60) 2. Auto shift mode had less quicker-than-average intervals than manual (n=17, auto; n=21, manual) 3. The single fastest 0-60 was in auto (8.26s) 4. Not enough pulls in each mode to determine how they effect the times I still stand by the 'feel' that auto is faster in 0-60, and it looks like @Lunatic's findings support that feeling as well. Here is an image of the data and an excel file inside a .zip file for anyone that wants to mess with the data. Please feel free to point out any mistakes or opportunities for improvement:
| The Following User Says Thank You to kavanagh For This Useful Post: | Rosticles (07-07-2014) |
#36 | |
Fat on Corn Syrup
But... I could swear that using Sport mode in manual shift mode allows you to downshift at higher RPMs. I need to go validate this, but I seem to recall downshifting into the the +6k rpm range when in Sport mode, and being denied when not in Sport. |
#37 | |
GEARS!!???
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
This vid made me sad
#38 | |
Drives: 2014 whiteout, scion fr-s
#39 |
Fat on Corn Syrup
As far as we know, pedal dance has no effect on acceleration. The only additional thing it does besides traction off, is disable electronic brake distribution (EBD).
| The Following User Says Thank You to kavanagh For This Useful Post: | mizzta21 (08-03-2014) |
#40 |
#41 | |
#42 | |
Fat on Corn Syrup
In automatic I believe it shifted about 7250 rpm and I tried to match that in manual mode. The next time I do the passes I will log each run and then will have solid numbers for what the engine is doing in each gear and for each setting. It just has to cool off here - 110+ ambient is just no good for thrashing about in.
| The Following User Says Thank You to kavanagh For This Useful Post: | mizzta21 (08-04-2014) |
| Manual vs Automatic (Help!) | Mr. J | Engine, Exhaust, Transmission | 177 | 01-04-2021 05:22 PM |
| Is manual louder than automatic? | Ymerej | Engine, Exhaust, Transmission | 15 | 02-04-2017 06:05 PM |
| SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado | huma | BRZ First-Gen (2012+) — General Topics | 15 | 06-14-2012 11:33 AM |
| Automatic vs Manual | Rabble | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 12-05-2011 01:55 PM |
| BRZ manual or automatic? | f1ver | BRZ First-Gen (2012+) — General Topics | 23 | 08-30-2011 09:07 PM |
