Old 07-31-2014, 09:37 PM   #29
86ft.lb
86ft.lb's Avatar
Drives: orange fr-s MT
easy cheap venting for engine bay , unclip the black plastic piece at rear of underside of bonett on drivers side , for me anyway
Thanks for the tip. I guess this would make a difference. Every help counts. Detaching front license plate decreased max cooland temp from 104c to 102c for me. I will update if I have a chance to measure difference.
86ft.lb is offline   Reply With Quote
Old 08-01-2014, 12:08 AM   #30
steve99
Drives: FT86
rainy day can be good for testing .
Old 08-01-2014, 12:52 AM   #31
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Wool tuft testing should suffice.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
DAEMANO (01-29-2016)
Old 08-01-2014, 07:35 PM   #32
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
The engine bay should be slightly pressurized from air coming in through the radiator/condenser. Through our CFD research, it appears that the area around the vents are near ambient air pressure. I would think these vents function.
Well executed. I have been wanting to something like this but my balls aren't nearly large enough to cut into my new car.
eric6 is offline   Reply With Quote
The Following 12 Users Say Thank You to eric6 For This Useful Post:
avishenoy1 (10-14-2015), B-R-Z (08-01-2014), GotBRZ1691 (10-23-2015), Gunman (08-02-2014), Hostile_Kittens (10-22-2016), Hyper4mance2k (05-10-2015), Joveen (11-07-2019), Lonewolf (12-10-2016), mx5 2nr (10-14-2015), sato (04-04-2018), xkalelx (09-15-2016), YamahaR86 (09-21-2014)
Old 08-01-2014, 08:45 PM   #33
retoocs
Why is the grill opening solid in the model? Are the underbody panels in the model?
retoocs is offline   Reply With Quote
Old 08-01-2014, 08:57 PM   #34
eric6
eric6's Avatar
This thread isn't about the CFD model I posted and I do not want to cloud his thread with this information. I just wanted to show that our CFD analysis shows that area as near ambient air pressure, as that is relevant to his thread and may be of some use to OP.
No hard feelings, just wanting to keep the thread on track .
Old 08-02-2014, 01:09 AM   #35
retoocs
The big question is where does the air go from the grill to determine if the side vents would work. I guess your CFD model doesn't address that. Need to know if most of the air go out the bottom or out the trailing edge of the hood?
If most of the air goes out the bottom, the side vents probably won't do anything. If there is a low pressure area behind the trailing edge of the hood, it might just draw through the side vents and straight out the trailing edge of the hood, also making them useless.
The quickest way to determine if the vents work or not is to wire up a couple of thermocouples just on the inside of the vent and also wire up one to measure the outside air temp. If the vent TC measures ambient temp, it's pulling air in. If it is higher than the OAT, then it is venting the engine heat.
Old 08-02-2014, 02:01 PM   #36
raptor87
Drives: 2013 DGM BRZ Ltd
when you stand next to the car you can feel warm air with your hand
raptor87 is offline   Reply With Quote
Old 08-02-2014, 07:47 PM   #37
Lonewolf
Lonewolf's Avatar
Drives: Moped
I don't know if you guys have seen this member's functional vents yet:
http://www.ft86club.com/forums/showthread.php?t=71065
Old 08-16-2014, 09:38 PM   #38
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Well, this is cool.
- The Ancient BRZ Sacrament
by Zaku
Old 09-19-2014, 09:54 PM   #39
J-W
J-W's Avatar
Drives: '13 Subaru BRZ Limited
Just finished one of my fender trim pieces. I don't have much free time, and the fender isn't prepped yet, but here's a picture...Name:  uploadfromtaptalk1411174434678.jpg
J-W is offline   Reply With Quote
The Following 4 Users Say Thank You to J-W For This Useful Post:
Hyper4mance2k (11-07-2015), Lonewolf (09-24-2014), MemphisR (05-08-2017), sato (04-04-2018)
Old 09-20-2014, 01:37 PM   #40
White64Goat
Do you have any pictures of where you cut the metal on the fenders?
Old 09-20-2014, 01:38 PM   #41
J-W
J-W's Avatar
I'm going to be working on that this afternoon when I get home from work. Will have before, after and installed pics.
Old 09-20-2014, 03:11 PM   #42
White64Goat
Want to trade my white Frs fender vents for Brz fender vents White0utFrs Exterior Parts (Aero, Lighting, Etc.) 0 09-23-2013 04:17 AM
Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright ill roller Exterior Parts (Aero, Lighting, Etc.) 6 09-22-2013 11:49 PM
WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents BlueLeader Exterior Parts (Aero, Lighting, Etc.) 0 03-18-2013 03:55 PM
Functional front fender vents JohnATL Cosmetic Modification (Interior/Exterior/Lighting) 10 01-25-2013 12:58 PM
Want to Trade: My Whiteout FRS Fender Vents for the SWP BRZ fender vents DC-FRS Exterior Parts (Aero, Lighting, Etc.) 15 11-02-2012 12:41 AM
