Old 07-31-2014, 10:00 AM   #1
somejace
OFT & Greddy Kit
As title says, I'm about to purchase a greddy kit and my question is...
Is it possible to get a base map/small tune with OFT? I was told that you can. I haven't seen anything and searched around. I believe there's stuff for the other turbo kits. I just want to put the kit on and run safe for a little bit than take it and get it dyno'd.
somejace is offline   Reply With Quote
Old 07-31-2014, 10:53 AM   #2
raven1231
speed by design tune should be pretty compatible the kits are very identical except for the turbo.
Old 07-31-2014, 01:48 PM   #3
somejace
I emailed shiv, we will see what my options are.
The Following User Says Thank You to somejace For This Useful Post:
raven1231 (07-31-2014)
Old 07-31-2014, 03:45 PM   #4
raven1231
good luck! Just out of curiosity where in ohio are you???
Old 07-31-2014, 04:29 PM   #5
somejace
Cleveland.
Old 07-31-2014, 04:39 PM   #6
raven1231
Cleveland.
Damn, I'm in Cincinnati. Would have loved to see the kit! Good luck with everything man
Old 07-31-2014, 04:44 PM   #7
somejace
If there's ever a big 86 meet somewhere down that way..I'd be happy to take a trip.
But thank you! currently talking to shiv, hes doing best he can to help!
Old 07-31-2014, 09:42 PM   #8
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
Yeah, the SBD kit utilizes a TD05H 20G. It's similar but not the same. I wouldn't trust a tune built for a different kit unless it was just to limp it to another tuner.
Unless you've already purchased the Greddy kit, why not take advantage of the SBD deal and get the OFT for free? I guess it's none of my business.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
The Following User Says Thank You to Boss Paco For This Useful Post:
steve99 (07-31-2014)
Old 08-11-2014, 04:06 PM   #9
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
Get the car tuned by a professional right away if you can. This is the only way you will be absolutely safe.
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
Old 08-11-2014, 06:29 PM   #10
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
I know it is not an open source tune, but we do offer an EcuTeK tune for any turbo kit via Speed Density tuning. We have sent our tune our to quite a few Greddy Turbo Kit owners around the world and they are all very happy with the results.
We can also offer FlexFuel, Switchable Maps (through a boost controller) controlled through the Cruise Control and custom Traction Control so when you start sliding from all the power it will help you control the slip.
Cheers,
William Knose
Old 09-23-2017, 03:09 AM   #11
frscory
frscory's Avatar
Drives: 2013 scion frs firestorm red
Hate to bring this thread back to life but is it safe to run the SBD base tune for the greddy kit?! I will be installing the kit tomorrow and have purchased the custom E-tuning for the OFT but still havent even gotten a base tune.
frscory is offline   Reply With Quote
Old 09-23-2017, 04:43 AM   #12
steve99
Drives: FT86
The turbo will build boost differently due different sizing.
you may be able to use the sbd base tune it would be better than stock tune, but you would want to drive very sedately , keep out of boost.
make sure both tune and car are set up for same port injectors , hopefully both are stock injectors
Possibly wedge the waste gate permanently full open to make sure no boost.
Also you would need to be running same MAP (pressure) sensor as the sbd kit or car wont even start
you would only want to be literally transporting car to tuner or home, in a very sedate manner.
Greddy Base Map for FRS Greddy Turbo Kit hiranak Software Tuning 10 10-27-2014 06:55 AM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 06:09 PM
Greddy Evo 3 or sth else?? awang0528 Engine, Exhaust, Transmission 3 02-28-2013 02:44 PM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
