Drives: Subaru
BBK and why you do not need them....yet...
Disclaimer:
This post is assuming: 1. the same stock HP levels for the BRZ/FR-S 2. average DD that will never see the track/race or canyon runs. I AM NOT FACTORING BRAKE FADE OR HEAT ISSUES AS A NORMAL DD WILL NOT ENCOUNTER THESE SITUATIONS. 3. Daily DRIVING CONDITIONS!!!! (just wanted to reiterate) ALSO PLEASE READ TO ENTIRETY BEFORE MAKING UNINTELLIGENT RESPONSES The car has yet to come out and there have been numerous threads regarding TRD BBK, STI brembos, WRX 4 pot-2pot setup. The point that I am trying to make is that the car as it is now does not need more braking yet. Even if you upgraded the power by the modest 50 hp that people are searching for, you still would not need bigger brakes. Here’s why: Many people assume that bigger brakes = better. This is not the case. Before I get flamed by the almighty internet gods, please hear me out. Let’s take two exact similar cars and change only a one aspect about the cars: brakes. CAR A: 173 whp, stock brakes CAR B: 173 whp, STI Brembos, stainless steel brake lines, ATE super blue brake fluid. Take a guess as to which car will stop quicker? Answer: BOTH CARS WILL TRAVEL THE SAME DISTANCE BEFORE COMING TO A COMPLETE STANDSTILL Now some of you are probably saying: “Why is that? What stops cars? “, “What the hell are you smoking?”, etc. My question to you would be “What is the ultimate force that determines what point the traveling vehicle will no longer be traveling?” Answer: Friction. Not the friction between the pads and the rotors, but the friction between the tires and the road. Tires are so crucial to almost all different aspects of a car from cornering to accelerating to stopping. A car can only stop as quickly as the tires will let it until the wheels are locked up by either OEM stock brakes or Brembos. If anything, it's possible the STI brembos or other BBK's would actually have a longer stopping distance due to brake bias and also the increased weight that comes with BBK's. In another post someone said “I'm sure STI engineers would put stuff that "doesn't work" on their cars.....”. The reason why companies put Brembos or other big brakes is purely for YOU, the customer. If manufacturer A puts them on their car and manufacturer B doesn’t, people would be like “What the hell? Why doesn’t my car have them? I’m gonna go with manufacturer A instead”, “Why does my $$$$$$ car not have big brakes but that $ car have them!!!”. At the end of the day, it’s marketing and perception. To continue on, some may argue that they have sat in car X with a ton of money thrown into the brakes and that it's the best stopping car in the world. While upgraded brake calipers offer a better initial bite, they will not decrease the distance needed to stop the car. Stainless steel lines also offer better brake feel and more consistency, but once again they will not decrease the distance traveled. Lasly, it is your money and you can do what you want with it. However, I am trying to educate the masses about the fundamentals behind brakes. Once again this is touching on relatively fundamental concept behind braking and stopping power (not touching topics such as heating issues, fade, etc). Even for the cars that will see autocrosses like mine will not encounter heating issues or fade at an event. If you truly want to stop quicker, invest in TIRES TIRES TIRES!!! That is all. Useful Articles: http://www.modified.com/roadtests/07...t/viewall.html Last edited by engee; 04-25-2012 at 12:53 PM. |
| The Following User Says Thank You to engee For This Useful Post: | czar07 (04-25-2012) |
#2 |
Drives: 01 Toyota Corolla / Porsche 911 C2
static friction has more force than dynamic friction.
You do NOT want to be locking up your wheels. having traction at edge of sliding your wheels is the best way to stop. |
#3 |
Site Moderator
Drives: Stuff
While I agree that people here generally will NOT need a BBK, I would argue that it's possible the STI brembos would actually have a longer stopping distance due to brake bias and the fact that most people who want STI brembos want them for looks and therefore won't address those issues.
I'm really not sure we needed ANOTHER thread for this either.. but.. :shrug:
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#4 | |
Drives: Attitude
#5 |
Wish Nissan made one
Drives: '13 WRB BRZ Premium
The STI Brembos have more surface area and will allow for more friction which would simply allow you to lock up the tires faster before the ABS kicks in. On a track (per your disclaimer) the extra size and cooling capacity would prevent as much brake fade.
The stainless lines help with pedal feel so that you can modulate your braking better.. they won't help you reduce your stopping distance.. but could help your lap time ever so slightly. The Super Blue fluid is more resistant to boiling after heavy braking sessions and will prevent brake failure. The OP is right about the tires having a bigger impact than the brake components in a one-off test of 100-0 brake distances. But, that doesn't mean they are worthless upgrades for people depending on their usage of the vehicle. Personally.. some upgraded pads, fluid and stainless lines and I'll be all set. |
#6 |
Drives: 2007 Focus ZX3, 1972 Buick Skylark
Heres a good read:
http://www.modified.com/roadtests/07...t/viewall.html |
#7 |
First86 / boat thief
Drives: MKIV Supra
Of course you don’t need a BBK for DD no one needs a BBK for DD in any modern car stock car.
A BBK is for brake fade which happens on a track after repeated hard use. BBKs rarely make signal cold stops faster and often make them worse. Maybe I am misreading what you are trying to say, but it sounds like you don’t have the slightest idea what you’re talking about. |
#8 | |||
Drives: Subaru
edited to include points on the BBK's possibly having longer braking distances and tire lock issue and the article.
I guess I was trying to address the masses that are using the car as a DD. Quote:
Furthermore, I will beg to differ and say there are people out there that are entertaining the thought of a BBK for their car but will be using it as a DD. |
#9 |
Señor Member
Drives: white BRZ 6MT
honestly I just intend to upgrade pads and possibly lines if the stock ones aren't stainless
#10 |
So I shouldn't buy these right away?
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#11 |
That Guy
Drives: 2013 asphalt FRS MT
#12 |
This could be dangerous. If you brake too hard your car might flip over on itself.
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
| The Following User Says Thank You to zoomzoomers For This Useful Post: | hmong337 (01-16-2015) |
#13 |
Rocket Surgeon
Drives: PSM GGA OMG
#14 |
Drives: Slowly
