Old 07-30-2014, 04:03 AM   #1
cookiesowns
Drives: WRB BRZ Series.Blue
Worried about 1st track day oil temps
Heyo..
Just recently had a blast at SoW CW. After reading about oil cooling stories, now I'm slightly worried.
Only did 2 sessions with about 3 hot laps and 1 short cool lap each. I was short shifting at 6-6.5k for the long straights, and took everything in 3rd and 4th for the most part.
It was super hot out on Sunday though.. 105F+
Do you guys think I'm fine? I'll be doing an early oil change soon, and thinking about a UOA.
How do you guys log oil temps? Custom data logger? Does the OFT log oil temps?
cookiesowns is offline   Reply With Quote
The Following User Says Thank You to cookiesowns For This Useful Post:
CSG Mike (07-31-2014)
Old 07-30-2014, 09:24 AM   #2
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I was at the same track day with a friend that drives a BRZ. After the track day he sent his oil out to get checked and everything came back fine. You should be OK but an oil cooler would be a great idea if you plan on tracking your car on a regular basis. It is also recommended to change your oil before and after a track day.
If you have an Android phone, download the Torque app, buy the blue tooth OBD2 connector and log from that. The app also comes with a G-meter and you can monitor a lot of other parameters.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 07-30-2014, 09:34 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
I take more of the approach
From the posts I see the engine oil reaches ~270. While I see a lot of people say it's too high I don't see much in the way of why it is too high on a stock engine. DI seal issues aside (which occur on track and also almost brand new street driven cars) what makes 270 really bad?
I'm not saying it isn't bad and I'll probably get an oil cooler in the next year or so but what's the rush? I've done 5 track events so far without a cooler. Pop the hood once I get in the paddock. I dunno, just would like some more info.
Also all 5 days on same oil fill, changing it before and after each event seems overkill?
Old 07-30-2014, 09:54 AM   #4
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
I agree, changing before and after every event is overkill, unless you are using some inferior oil. As far as an oil cooler, you'll be fine without it as a beginner, but it's a good precaution as you get better and start pushing the car harder.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 07-30-2014, 10:37 AM   #5
sluflyer06
Drives: 2014 BRZ Ltd - DGM
I'm impressed you already have that blue series broken in haha.
I've never done a trackday is only getting 6 actual laps in, normal?
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-30-2014, 10:54 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
What do you mean?
Sessions range from 20-30 minutes generally. So divide average lap time. a 2 minute track will get you a number of laps. Then there are usually 4 sessions in a day. So multiply by 4.
There are some basic mods you should do before a track event, I'm not sure oil cooler is one of them. Although if you got the time and $ why not.
Old 07-30-2014, 10:58 AM   #7
jvincent
jvincent's Avatar
6 laps seems kind of short to me unless it was an evening lapping session or there was other stuff going on.
The full day sessions I go to alternate 30 minute sessions between run groups with an hour break for lunch. If I ran every possible session that would be 7 full sessions, with about 8 laps per session.
The track is 5km long and let me tell you it is tiring being out there that long. My last time out I only ran 6 sessions because I could feel I was getting tired and tired + fast driving are not a good combination.
Back on topic, unless your are FI, you should be fine unless you are really pushing the car hard.
If you are lapping a lot then I'd suggest changing it more frequently than the factory maintenance schedule and try to do a change a day or two before you hit the track.
Old 07-30-2014, 01:20 PM   #8
cookiesowns
Thanks for all the responses guys!
I'll get an oil change done and UOA soon. I'll be filling her up with motul I suppose, not 100% decided yet.
Oil cooler is definitely at the top of my mod list, second to brakes & tires.
The reason my sessions were short & low was due to me not wanting to get ahead of myself so I waited for instructors.
Didn't get heel-toe 100% down, so I didn't go into second which would have most likely shaved 3-4 seconds off or even more if I didn't need to point-by a bunch of drivers that were running in blue group with modded S2k's....
I got about 10 laps in, 2 sessions of 4-5 laps each. This is definitely not normal, if you hustle at the grid, you'll get maybe 4-5 sessions of 6-8 laps depending on size of track.
Old 07-30-2014, 01:23 PM   #9
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Doesn't hurt to have a couple of cool down laps during the session here and there.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
The Following User Says Thank You to Tt3Sheppard For This Useful Post:
renfield90 (07-30-2014)
Old 07-30-2014, 01:29 PM   #10
renfield90
The Stig's German cousin
Seriously, this. You don't need to do a quali lap every time!
Old 07-31-2014, 07:40 AM   #11
subielife
Subaru Ambassador
subielife's Avatar
Drives: 13 BRZ 18 Silverado
stop listening to what people say on the internet. you will be fine. I have a P3 gauge, track my car alot ( 40+ days per year) and I am constantly in the 250-260 range and I go about 2500-3000 miles on Castrol Edge 0W30 (German blend). Sent oil out for analysis, nothing wrong.
subielife is offline   Reply With Quote
The Following User Says Thank You to subielife For This Useful Post:
glamcem (09-07-2014)
Old 07-31-2014, 01:25 PM   #12
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I will respectfully disagree with subielife...
Long term running 250-270 oil temps on these cars will cause premature failure of the engines. You ideally want to be running the cars at 215-220 even on track. I've been logging my oil temps in the 260-275 range and for me that is too high.
We are installing the 2015 WRX OEM cooler to see what kind of temp drops we can see with that and then will try a few OTS Coolers that are external to see what they do.
The higher grade your initial oil, the longer it will handle the high temps. So if you are using a high grade synthetic oil perhaps a 0-30 or 5-30 and change it often while tracking, then you may be able to get away with it for a while. For the cost of a cooler, it's not worth it IMO to not do it. Also cooler oil in the 215-220 range will yield 5-6whp compared to running the car at 260-275 range.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following 2 Users Say Thank You to AZP Installs For This Useful Post:
totopo (08-12-2014), ZionsWrath (07-31-2014)
Old 07-31-2014, 02:12 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Two questions:
- How much do you push the car?
- How much money do you have for an engine replacement?
When you go to the track on a regular basis, you need to make investments that will maintain the engine in good running order. Long extended intervals at high temps won't help... but again, if you're not pushing the car hard it will be a tossup.
My last UOA may be helpful:
http://www.ft86club.com/forums/showp...2&postcount=35
Originally Posted by mav1178 View Post
Just got my latest sample back. This interval was 7300+ miles, with really low copper readings.
I also ran 1 track event during this particular oil change interval.
Next reading will be ENEOS Sustina 0W-20, as I got 2 cases for $100 (couldn't pass up that type of a deal!)
Got my UOA from ENEOS Sustina back:
A few notes:
  • 8000+ miles, including a 2100 mile, 4-day road trip.
  • 3 track events
  • Approx. 1/2 quart of oil added
  • Approx. 3000 miles on Cusco oil cooler (same as DIY Forester XT setup)
  • Changed oil filter once (due to Cusco oil filter install)
The high TBN (compared against regular ENEOS previously) is pushing me towards running Sustina beyond this upcoming oil change... this sample was pushed relatively hard with all the driving and track events, and the oil still held up well.
With my Cusco oil cooler I currently see 99-104C daily driving, and 115-123C at the track (depending on ambient temps). All on stock radiator.
-alex
DAEMANO (07-12-2015)
Old 07-31-2014, 02:26 PM   #14
subielife
Subaru Ambassador
subielife's Avatar
-Mike Paisan
Hey I need the motor to blow so I have a reason to give the wife for a rebuild. Honestly if you are a newbie on track you will be fine but if you are getting serious about tracking it is cheap insurance.
I might be able to make it on the 13th, but not looking good.
Should I be worried ? Brooklyn BRZ First-Gen (2012+) — General Topics 8 03-12-2014 01:18 PM
No CEL Should I be worried?? Mr.Jay Issues | Warranty | Recalls / TSB 5 04-05-2013 11:51 AM
a bit worried MontrealFRS Issues | Warranty | Recalls / TSB 7 09-14-2012 07:46 PM
5k oil change, worried about changes.... bloomy116 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-11-2012 09:23 PM
Anyone worried about not fitting in the car? budakajana AUSTRALIA 35 06-27-2012 08:55 AM
