Old 07-27-2014, 08:42 PM   #1177
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Originally Posted by bwthor View Post
Here is the update with CarHome disabled. This was provided to me when I asked support if there was a way to disable it.
IF YOU HAVE DROPBOX, PLEASE USE THE "SAVE TO MY DROPBOX" LINK, RATHER THAN DOWNLOAD. If there are too many downloads, my account could be disabled.
https://www.dropbox.com/s/szq66a8ksk...%20English.zip
From what I can tell, there is only one change between the last official update, and this one. The file is factory.prop located in update-->images-->manufactorycfg
I'm guessing that there is a way to enable/disable it without having to go through the whole restore process, but I'm not the guy to figure it out.
It has been working fine for me, but as soon as I load up Torque Widgets, CarHome crashes on reboot. You get the error Unfortunately CarHome has stopped. Click OK, and you are back on the desktop. I've noticed that if I have the radio open, and reboot, I don't get the CarHome error.
Does anyone have Torque widgets working and staying on the screen after a reboot? I've tried the last official update and it doesn't work.
Also, I'm unable to get my Exchange email account set up. When I enter the account info, it gets to the end, then at the part where it says it needs to change security settings, the settings app crashes with Unfortunately, Settings has stopped. Again, this error is present with the official update.
I've had a few issues of widgets crashing on wake. I've just uninstalled them. It doesn't love the widgets!
86•BRZ is offline   Reply With Quote
Old 07-28-2014, 12:26 AM   #1178
bwthor
Drives: gray
Is there a way to get to the balance/fader controls other than through the radio app?
bwthor is offline   Reply With Quote
Old 07-28-2014, 12:35 AM   #1179
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Do they apply globally? Haven't checked?
Old 07-28-2014, 09:25 AM   #1180
bwthor
Drives: gray
Yeah they are. I made a change, and it was changed in Poweramp.
Old 07-28-2014, 06:40 PM   #1181
Stormalong
Drives: Firestorm FR-S AT
Originally Posted by DC2R View Post
How does that one look? Pics of display and outside view of it installed? I've been looking for one that mounts right through license plate bolt hole with no extra holes needed to run wires.How is lack of night vision working out?
I'll second this camera, I installed it this past weekend. I removed the trunk key lock and this camera fits pretty much perfectly into that hole. No drilling holes or other mods required. You basically just push the camera up into the hole and it stays nicely. I tapped power from the reverse lights in the trunk, and tapped the reverse signal from the drivers side kick panel to connect to the Dashlinq4 reverse wire. Ran the video cable from the trunk up to the Dashlinq4 and done!
As 86-BRZ said, the reverse lights (and license plate lights) provide plenty of illumination.
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
Stormalong is offline   Reply With Quote
The Following User Says Thank You to Stormalong For This Useful Post:
DC2R (07-29-2014)
Old 07-28-2014, 07:00 PM   #1182
Fastbrew
Drives: 2014 Pearl White BRZ
Originally Posted by SPT Legacy View Post
So after so more tweaking with my audio guys....each channel gives signal when hooked up to a test speaker...but when everything is connected, FL, FR, RL, RR..half of the car gets a weak signal..no one can figure it out..@.@
Did you try hooking it up to a full set of test speakers just in case one of the speakers has a short?
Fastbrew is offline   Reply With Quote
Old 07-29-2014, 08:22 AM   #1183
DC2R
Drives: 2014 Scion FR-S
Hmm i guess we cant use the license plate holes huh? Didn't want to use the key hole since I have a habit of trunk junk activating the valet button and loving down access to the trunk. I'd I did that I'd probably see how I could disconnect that switch all together
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 07-29-2014, 10:07 AM   #1184
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Just put it where I did. It's only plastic and there is little mark there for where to fit it just like the OEM one.
Old 07-29-2014, 02:26 PM   #1185
Stormalong
Well, you could go for this one.
http://www.beatsonicusa.com/cameras/bcam7.html
I considered it, but I went with the other one because I think its a little less obtrusive. Also cheaper.
Old 07-29-2014, 05:49 PM   #1186
DC2R
Yeah 150 is way too expensive for what could probably be done with a twenty dollar camera. Need to go look at car and sees of factory location replaces trunk lock cylinder.
Old 07-29-2014, 10:23 PM   #1187
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Whoa you guys are killing it in this thread with more hacks and installs now!
Sorry i haven't been responding everyone, been BUSY BUSY BUSY lately.
I'll catch up this weekend.
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
The Following 2 Users Say Thank You to SHIFTER For This Useful Post:
DC2R (07-29-2014), Deathalo (07-31-2014)
Old 07-30-2014, 05:10 AM   #1188
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Had a crack at button remapping using xposed additions. No go.
Would live to be able to remap the right knob.
The other thing that bothers me is music players stop when the car is turned off. Tried to get media playing with screen on via llama but couldn't get it.
These are the main two things I'd love to change... Has anyone done this?
Old 07-31-2014, 12:35 AM   #1189
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
I would love to fool around with mine more, but I don't feel like sitting in my car in the hot garage for hours.
Prog is offline   Reply With Quote
Old 07-31-2014, 08:50 AM   #1190
DC2R
Ha ha I'm guilty of running ac while messing with radio. Worth the cost vs sweating in 93 temps and high humid/mosquitos
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
