Old 07-28-2014, 09:21 PM   #1331
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Originally Posted by neurokinetik View Post
For the best of both worlds, use the raw data, normalize it to 60 seconds, then see what your delta is compared to your competitors.
I've basically done that, except normalized to 1.000 for the fast time and all slower times are 1 + x.
Originally Posted by vroom4 View Post
Less calculating, more driving. When you take top PAX'd time of day, then you can worry about calculating.
Last year I PAX'ed 2nd in a 91 driver event, with John Heinricy PAXing 15th. Is this close enough?
bimmer635csi is offline   Reply With Quote
Old 07-30-2014, 09:34 AM   #1332
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
since this is the biggest autocross thread...
are pylong penalties paxed? ie, pax time - cone penalty or should it be time - cone pnalty * pax?
Old 07-30-2014, 09:48 AM   #1333
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Everywhere I've competed it is always: (raw_time + penalty) * PAX Index. The SCCA Match Tours do this as well for the portion of those events that rely on PAX Indexes.
jprice130 is offline   Reply With Quote
Old 07-30-2014, 09:55 AM   #1334
bimmer635csi
They tend to add time when I hit a cone, instead of subtract it.
The Following User Says Thank You to bimmer635csi For This Useful Post:
jprice130 (07-30-2014)
Old 07-30-2014, 10:01 AM   #1335
jprice130
AutoX Nut
Ha, ha! Too funny! Fixed now...
Old 08-01-2014, 03:57 PM   #1336
JB86'd
JB86'd's Avatar
Drives: JAWS
Here's my run from the last El Toro event on July 20. Got a new Audio-Technica ATR3350 external mic...I love it. Mounted right above my license plate.
Also first event with OEM camber bolts installed. What a difference, feels so much more confident cornering.
[ame]http://youtu.be/SIk-5lPzA68[/ame]
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Quentin (08-03-2014)
Old 08-03-2014, 10:52 AM   #1337
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Hey guys, 1st post and I had my first autox yesterday in a bone stock BRZ. I traded my 2014 Camaro 1LE for a BRZ
After the first run, I sat there and wondered how something this slow on such crap tires can be so much fun. It was the best, not fastest, car I have autox'ed. I have 215/45/17 r-s3 v2's cn order and I am going to get crash bolts to dial in a nice custom alignment. I did not read through the 60 plus pages, just here and there, but what are peoples recommendations for an aggressive c-street alignment?
Here is the video. C-Street in NNJR is filled with talented drives. I finished 4th out of 4 and was about 2-2.5 seconds off the first 3 guys who were each prepped. 2 rx-8's and a BRZ all in the 37's. Next event I plan i running with them as these tires are awful.
Laloosh is offline   Reply With Quote
Old 08-03-2014, 11:00 AM   #1338
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
As much front camber as possible (which isn't much), 1/16 total toe out up front, 1/8 total toe in out back. Add good front sway bar possibly (I like Strano's)
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-03-2014, 11:47 AM   #1339
chkltcow
Drives: 2013 FRS White w/ cone marks
Bingo!
The Strano bar actually made the car less pushy, shockingly enough. I have almost that exact same setup (Hankook RS3v2 in 215/45/17, Strano bar, OE crash bolts at -1.1 camber up front, 1/16 total toe out front, 1/16 total toe in rear). I've found the fronts are happy around 40psi. May need to go up a psi or two if they're rolling over. Rears I run around 34psi and almost never touch.
And if you're willing to take a little bit of advice.... A) you're not looking far enough ahead, because you almost kept slaloming at that one point Easy fix and you probably already know it.
B) You're double turning in on elements. It's one of those subconscious things that I had to break the habit of too, and I didn't even realize I was doing it until I drove a friend's M3 last year. He rode with me on one of my runs, we finished up, and he said "Dude you're turning in twice for everything. You turn in, reset the wheel a bit, then turn in again."
I went back and watched my videos, and sure enough... I was chopping at the wheel like you're doing in this. Had no clue I was ever doing it. I broke the habit of the double turn in, turned in "confidently" as he stated it... and got faster (in everything I drove).
chkltcow is offline   Reply With Quote
The Following User Says Thank You to chkltcow For This Useful Post:
Old 08-03-2014, 12:07 PM   #1340
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Originally Posted by chkltcow View Post
Bingo!
I noticed that too at second mini slalom. I honestly don't remember doing that but it did seem like I thought for a split second that I wasn't out of the slalom yet. As for turning twice, not exactly sure what you mean as it is impossible to only turn "once" as nothing there was constant radius. Towards the end I did see myself turn in, retract and turn in and I believe that was just me guessing on how much the tires are going to roll over lol. Either way all advice is welcome and thanks! I can't wait for the next event and the kooks.
Old 08-03-2014, 03:16 PM   #1341
TrqlessWonder
Drives: 2014 FR-S
Well, that's a big change. Pretty sure I was gridded next to you at the Jersey Tour. NNJR does have a ton of good drivers, and most of them do multi-duty as instructors as well. Don't be afraid to ask for them to ride along or even instructor run your car. Carmenini in particular will be helpful if you want it to be a C-streeter, and Yatsko/Crea have all been incredibly helpful for me over the years. And not a single one of them will refuse the request if they're available.
The few "double turn-ins" that I saw looked like either the car flat didn't turn in the first time, so you backed off and tried again (not a bad idea) or that the rear felt like it was coming around, so you were trying to catch it or something. In any event, it probably would help if you put some emphasis on smoothing out your inputs, looks to me like more mid-corner corrections than you'd really want. Hard to explain, but you while you want your inputs to be quick, you don't want them jerky. Your traction circle gets a little bigger when you approach the edges, instead of just trying to run directly to (and often through) the outer limits. The best way to get to that is getting ahead on your steering, which requires looking ahead, so a need for a direction change is less of a surprise. For me, getting through a slalom quickly should be mostly about being early so you can let rhythm and muscle memory do most of the work. And you'll have some slack to work with (without needing to slow down) if you fall behind through the slalom.
The all-season tires are undoubtedly low grip. But, there might be some benefit to toughing it out for a few more events on the crap tires, just so you can work on technique a bit before putting on the stickier stuff that might mask driving mistakes. Just my opinion, but, provided you're not in the hunt for season-end trophies, why not use the rest of the season as a series of test and tunes?
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 08-03-2014, 06:20 PM   #1342
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Yea I was at the Jersey Tire Rack Tour. I think that was my 3rd event in the Camaro on stock tires, which simply did not work on day 2. I went from a 1.5 second lead after day one to being 6 seconds slower on the first run of day 2 lol. Thankfully the temps went up and I eeked it out on the last run.
As for Tony, he was the first guy i recognized when I took my Camaro to it's first autox. I started autoxing in 2003 and knew Tony/Jeff/Hurst/Ernie/Perry from back in those days. Chris, I have been bsing with him alot more lately and following his RX-8.
I am def not the "smoothest" driver in the world but I attribute my mistakes to driving a car that is the polar opposite of what I have been running for the past 9 events. I was surprised how early I can get on the power and how light the car felt. These two aspects of the car probably increased my jerkiness as it was "fun" lol. As for the stock tires, they are coming off and being sold. Thanks for the input and maybe we will be at the same event one day.
Old 08-04-2014, 11:41 AM   #1343
engee
Drives: Subaru
Awesome running with you man. I was the other BRZ at the event. I'm glad to see more people with the twins playing in CS. I was sloppy in some sections and if I had cleaned it up, I would have had a better chance chasing Konrad. We gotta take out those rx-8's. haha
Here's my video for comparison:
[ame="https://www.youtube.com/watch?v=7By5cQYUXAQ"]NNJR SCCA 8-2-2014 - YouTube[/ame]
See you at the next event!
engee is offline   Reply With Quote
The Following User Says Thank You to engee For This Useful Post:
JB86'd (08-04-2014)
Old 08-04-2014, 02:18 PM   #1344
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
See you on the 24th. I should have the tires and an alignment by then.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
