#127 | ||
We have an annoying issue to contend with here as for users who deal with cold weather mean colder starts are very difficult when you have 125PSI oil pressures and 10-15 minute oil warmup times to get pressures and temps normal. That rules out "thicker" oils for daily drivers in my opinion. But your findings follow what I am seeing. As temps climb pressures drop. Quote:
My concern is obviously for those who are running higher redlines. I talked with Bill from Delicious and he is running his tuning at 7800RPM redline because the car is making power. How many tuners are really paying attention to pressures as heat climbs. Based on this info and some of yours Phil, I personally would not recommend anyone running FI to be pushing much past 7200RPM on the track as temps get passed 220F running 0w20 or 0w30. It just seems like most failures are tied to bearing skimming. And most users don't understand the factors that can lead to all of this. Whats your feeeling on that?
#128 | |
Drives: Hydra EMS Powered FRS Raven Black
In summary of the basics I wouldn't run 0w20 under any racing conditions and I would step up to 10w30 even for NA applications. For street and NA 0w20 is fine and sure you'll get a touch more power a maybe a little better fuel economy. Don't forget oil viscosity ratings are done at 100c (212F) and not at 240-280F. You need a higher grade if you are going to be running that hot. For cold start there is no issues with up to 50w/20w50 for any of the warmer months. For a Subaru engine 125 psi is the norm for cold start up. There is nothing inside this motor clearance wise that should freak you out about oil viscosity and I know this for fact as building race and high performance boxer engines is our business (we've measured all the internal clearances). In very cold months (sub 40s) I would not run a 20w50 but I wouldn't hesitate to run 10w30. Just run a high quality synthetic as they flow so much better than conventional oils of the same viscosity rating. Everyone should have an oil pressure gauge on this car if modded!!!! I also find these 0 weight oils are just horrible at high temps in terms of viscosity most likely due to the polymers used to get the oil to flow like that. The more you stretch the range the worse it is so a 0w40 is not as good as a 0w20 at staying in grade. Thanks for the oil pressure readings for the various temps. Those pressures are not an issue with a 200 whp car. I would say even up to 300hp those are just adequate. If you start dropping into the 40s, you are in trouble and I've seen it in my own car and I know a few others have reported the same. As you add power you need more oil pressure to keep the oil wedge in the rod bearings. How much oil pressure we need exactly is still a question. I suspect we need more than we use in the EJ motors because the FA20 motor has rod bearings that are narrower (so more pressure per square inch and therefore more force trying to squeeze the oil wedge out). The asymmetrical rod however may reduce some of this force however so it could be a wash in the end. I will say low 50s oil pressure equaled a spun bearing on my car at 400 hp and 8k+ RPM. It's really not all gloom and doom as you NA and low power guys, drop the cooler on there and thicken the oil without a worry. Pump gas supercharged or turbocharged in the sub 300 whp range, same deal. 300-350 is the same but you're on the edge at that point but if you don't have a build motor you should stop there anyway. For 400-600 hp we have a fix with the motor build added. Now racing is going to be the big question mark and I will be the guinea pig to see how well we can hold oil pressure under extreme WOT conditions. Based on my experience in racing our engines I'm going to expect to lose 10-15 psi which is going to drop us into the 60s. This means 400 or so be reliable. If we want to see 500+ reliable we need to stay in the 70s+ all the time. Thanks, Phil Grabow |
| The Following 10 Users Say Thank You to Element Tuning For This Useful Post: | @Art_Mighty (10-16-2014), ATL BRZ (08-20-2014), BatStig (03-18-2015), Calum (07-28-2014), Dezoris (07-29-2014), keen as (07-30-2014), limitedblkwrx (07-28-2014), M1K3 (07-28-2014), MINOCIN (07-29-2014), sato (07-28-2014) |
#129 |
That Guy
Drives: 2013 asphalt FRS MT
Phil,
Have you done any testing to see how much changing the viscosity changes the operating temperature of the motor? Most of my work with oil viscosity has been with hydraulics, granted. But with hydraulics viscosity can have a noticeable affect on operating temperatures. The asymmetrical rod wont have any affect on where the pressures are exerted on the crank journal. They only change how the forces act on the rod bolts. Asymmetrical rod are considerably stronger in tension because they don't put tension directly on the bolts. To my knowledge, strength in compression should be a wash, though. Do you think the increased journal diameter of the FA vs the EJ would be enough to offset the decrease in journal width? Having you calculated the projected areas to compare the two motors? If you have, would you mind stating how they compared? I'm guessing you want to keep your build specs to yourself, but would you mind sharing the OEM bearing clearances? Thanks again! |
#130 | |
Junior
Drives: a car
I know this sounds kind of simplistic; but if 400+ is reliable now (atleast should be @ 60PSI u 70PSI sounds like it would need a larger oil cooler, and bigger oil pan, i have a feeling the oil cooler and subsiquent larger amount of oil could account for an extra 10PSI.
#131 | |
Phil thanks for feedback, on my end really I want to just get an accurate guide put together from experienced people so there is less speculation.
| The Following User Says Thank You to Dezoris For This Useful Post: | Surok (03-22-2018) |
#132 | |
If you can get the oil pressure you need with less viscosity great, but if you can't, thicken it up! Now given the factory car with 0w20 hits 280F on the track, what does that tell you? The viscosity isn't the reason why it's running hot. In terms of the asymmetrical rods and the overall design of the FA vs. the EJ, there is a huge difference. The rod design is used to add stroke to the motor and is offset along with the piston pin. The FA20 crank has larger diameter mains but not rod journals and it's the rod journals that take the pounding. So the rods journals are just thinner and the stroke is longer (86mm vs 79 for the EJ) so that increases the stress on the crank due to higher piston speeds. I'm just not sure the effects of the offset rod and pin and how that directly compares to the EJ in terms of the stress comparison at the rod bearings. Also don't forget the first part of this thread and the differences in the oiling to the journals. |
| The Following 3 Users Say Thank You to Element Tuning For This Useful Post: |
#133 | |
I was doing some further testing today because we have heat and was seeing 48psi at 7k. Very troubling.
#134 | |
We are moving forward with the external oil pump and dry sump setup so we'll have a bolt on solution soon that won't require an Element Tuning engine build. I'm hoping to have this sorted in a couple weeks so we can race the car in September for Global Time Attack. Last edited by Element Tuning; 08-05-2014 at 12:51 PM. |
#135 |
http://instagram.com/p/r5sBnItvc5/
So finally I can really run the Element Tuning Pro Comp motor hard to 9k RPM, run after run. In this video I'm running right at 20-21 psi of boost on E85, FIC 1100cc injectors, DW300 fuel pump, Garrett 60 Trim, Hydra EMS, Perrin 3" cat-back exhaust, internal oiling mods, oil accumulator, and the Perrin Oil Cooler kit. As you can see the oil pressure needle is between 60 and 80 psi running about 72 psi all the way to 9k RPM. This pull was done after many tuning pulls and the ambient temps showed in the 80s. Overall I'm really happy with the oil pressure stability while running as hard as anyone could on the street. I wanted turn up the boost but she's running at 100% injector duty cycle with the 1100cc fuel injectors. I'll probably toss her on the dyno but I'm not sure what the next step should be for fueling so I can keep pushing things. Either a return style fuel system with an external regulator or maybe a jump to 2000cc injectors. Thanks, Phil Grabow |
| The Following 12 Users Say Thank You to Element Tuning For This Useful Post: | ATL BRZ (08-20-2014), AZFA20 (08-21-2014), BatStig (08-21-2014), craigpitts7 (01-24-2016), DarkSunrise (08-20-2014), GhostOp86 (12-19-2014), gramicci101 (08-20-2014), johan (09-16-2014), limitedblkwrx (08-20-2014), PERRIN (08-21-2014), Sportsguy83 (08-20-2014), unsurety (08-20-2014) |
#136 |
Drives: Asphalt FRS
I may or may not have watched that video 10 times in a row...
#137 | |
Drives: toyota mr2/ Toyota GT86
is it just heavier springs to get this safely? or have you done any other mods to the valvetrain? |
#138 |
| The Following 2 Users Say Thank You to Element Tuning For This Useful Post: | MAPerformance (08-20-2014), PERRIN (08-22-2014) |
#139 |
Drives: Car
| The Following User Says Thank You to JasperNoone For This Useful Post: | Element Tuning (08-20-2014) |
#140 | |
![]() Just valve springs alone won't allow the engine to make really good power that high in the RPM. We fit +1mm Ferrea valves, multi-angle machining on the seats, port the bowls, and upgrade the valve springs. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | Sportsguy83 (08-20-2014) |
| FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 02:31 AM |
| FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 05:19 AM |
| Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 12:33 PM |
| FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-17-2013 11:24 PM |
