View Poll Results: Is bigger ALWAYS better??
17in 121 69.94%
18in 49 28.32%
Other 3 1.73%
Voters: 173. You may not vote on this poll
Old 07-25-2014, 04:43 AM   #43
Bongertz
Drives: Brz
Get the new tws, you get the best of both worlds. Looks and it's lighter than most wheels.
18x9.5 at 15.2lbs.
Bongertz is offline   Reply With Quote
Old 07-25-2014, 05:06 AM   #44
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
18x9.5 at 15.2lbs.
And your wallet will also be considerably lighter afterwards! See, weight reduction bro.
At 3K$ in wheels, I'll pass for now. Not that I don't want them, but I couldn't afford them
Mad1723 is offline   Reply With Quote
Old 07-25-2014, 06:16 AM   #45
Bongertz
Drives: Brz
Like what Schumacher said " don't wear underwear before the race.. Because weight reduction"
Old 07-25-2014, 06:25 AM   #46
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
I’m taking a holistic approach to the project and think 17’s are the way to go for me.
- The twins are pretty small to begin with so to me 17’s visually look big enough
- I want to fit the best rubber I can afford, which will be cheaper over the life of the car than larger diameters
- I do want lighter rims, but am worried about protecting them from damage on suspect b roads so the extra rubber / thicker walls will help
- As a daily driver I want the ride to be good and tyres are your secondary shock absorbers after all
Taking all the above and throwing it all together I want to end up with something nice looking, comfortable riding, cost effective (in the long run), handle improving (better grip than stock / less rotational mass) and be able to drive without worrying about hitting the occasional pot hole / choppy road.
Mim is offline   Reply With Quote
Old 07-25-2014, 06:48 AM   #47
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
^ simple....rota titan 17x8
Looks great, affordable, decent quality, and light (just over 7kg). But you'll have to put up with the whole stigma toward that brand.
If cost isn't an issue, then get the real deal TC105N....even lighter.
Fizz is offline   Reply With Quote
Old 07-25-2014, 10:52 PM   #48
KPark
Drives: none
I personally prefer 17in because I cannot afford 18in tires......
KPark is offline   Reply With Quote
Old 07-27-2014, 06:20 PM   #49
Ubersuber
Drives: BRZ Pearl White
Note that even Toyota fits 18 x 7.5 forged rims to its updated TRD kit for the UK.
This chassis doesn't need more than 225 wide tires and 7.5 wide rim is enough.
Ubersuber is offline   Reply With Quote
Old 07-27-2014, 06:26 PM   #50
Dipstik-sportech
Dipstik-sportech's Avatar
It does if you have greater than stock power
WTT: Work Meister SP1 3pc 18in/8.5/+48 JCORP Wheels and Tires 22 03-24-2014 09:56 PM
Forgestar F14(18in 5x100) & Michilin Pilot Super Sports to fit Jared0934 Wheels and Tires 7 09-06-2013 10:43 PM
FS [WA] 17in GTS rims PLUS 17in GTS rim + tyre stevo_12v Australia Classifieds 12 10-20-2012 11:59 AM
