Old 04-18-2012, 03:49 PM   #57
Dark
Elite Padawan
Dark's Avatar
I think faster is generally better, especially given the same volume of flow. But too fast leads to frictional losses that can reduce flow. Plus there is something about sonic choking that I don't understand yet.
Always about compromise.
But overporting chasing a volume flow number (just CFM) with no regard to the velocity is what leads to shitty response on NA motors that don't make power til really high rpm. The trick is to increase flow AND velocity which is what separates the pro porters from amateurs. Or at least increase flow and minimize velocity losses.
Aftermarket domestic porting and motorcycle porting is far more advanced than the typical import performance porting.
But if you need to increase more flow (and velocity), you're going to need more fuel to mix with air. Oh... I got it.
Dark
Dark is offline   Reply With Quote
Old 04-18-2012, 04:01 PM   #58
serialk11r
Drives: '06 AM V8V Coupe
Hmm so pictures I can dig up of the 1LR-GUE seem to indicate that the injectors are quite a bit downstream from the throttle bodies, so it might not be it :/
Old 04-18-2012, 04:51 PM   #59
Levi
Drives: Toyota
What is wrong? I want an LFA but can't afford it. I'll even more want an LFA II but will even less be able to afford it, because I guess they'll sell them only to LFA owners.
But we have GT86, we'll have Supra, LF-LC (called SC), IS-F Coupé. What more can one need? Anyway all those crying about a Supra have not understood that the Twin-Turbo I6 is dead. F*cking hybrid is the future. Even the new Carrera GT, 918 Spyder, is a f*ucking 4WD hybrid. I hate Prius. NA and FI FTW, but only hybrid is waiting for us, just look at the NSX II.
Levi is offline   Reply With Quote
Old 04-18-2012, 05:15 PM   #60
Dark
Elite Padawan
Dark's Avatar
I think hybrid is just a motel we stay on the journey to the future. LOL Electric is the real future here.
Dark
Old 04-18-2012, 05:20 PM   #61
Dimman
Kuruma Otaku
Dimman's Avatar
If this new supercar happens, and is tied into the LeMans car they're running as much as the LFA was tied into F1, it will be hybrid.
The system they are using in LeMans is pure electronic, with capacitors I think rather than batteries, no flywheel system.
Because titanium.
Old 04-18-2012, 05:45 PM   #62
serialk11r
Hell to the yes. Don't want to turn this into an energy argument, but liquid chemical fuel is by far the easiest way to store energy. We already have lithium ion doped ultracapacitors coming to the market soon, at lower cost than more sophisticated graphene and nanotube and what not stuff, which matches the energy density of a lead acid battery and completely blows literally anything else out of the water in terms of power density. Did I mention mechanical heat engines are amazing? Race engines with no waste heat recovery (obviously) have amazingly high thermal efficiencies considering their turbine like power to weight ratio, while being efficient across a vast range of speed.
Just looking at some of the stuff that's coming to market soon, which are easily getting about 0.1MJ/kg, 10kg of ultracapacitors would give you 1MJ storage capacity (enough to get a 1 ton car up to 100mph from a dead stop), and it would be able to discharge quick enough for any sort of electric motor you could throw at it.
A race car uses most of its energy on the brakes, recover some of that, and use the energy to go faster instead! Storage time doesn't matter either, you're using power 90% of the time when you drive or more.
Old 04-18-2012, 05:52 PM   #63
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
Porsche 918 competitor?
quik1987 is offline   Reply With Quote
Old 04-19-2012, 04:55 AM   #64
Levi
Drives: Toyota
If so, they don't need to build the LFA II.
Porsche 918 Spyder < Porsche Carrera GT (best P-car ever)
Old 04-19-2012, 11:05 PM   #65
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by old greg View Post
In the OEM production world, yes very much so. And yes, they use very big hydraulic presses with very expensive dies that wear out and need to be replaced.
In your FSAE analogy, it depends. Fishmouthing the tubes by hand is very time consuming and labor intensive, it's easily a month-long process for an FSAE team under normal circumstances. These days a lot of teams are outsourcing that to companies like Cartesian Tube that CNC bend/fishmouth the tubes based on solid models with about a ~1 week turnaround time if they aren't too busy. Assuming you have all of your jigs ready you could go from the UPS truck to a completed spaceframe in just a day or two.
Way off topic but do A-Mod Specials have a minimum weight? I found track, wheelbase, aero, and B-Mod stuff in the other regs, but nothing on weight...
Because titanium.
Old 04-20-2012, 12:06 AM   #66
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
Well, Toyota should make the car at least be profitable if they decide to sell it for $1M.
iff2mastamatt is offline   Reply With Quote
Old 04-20-2012, 01:12 AM   #67
Dark
Elite Padawan
Dark's Avatar
I think they will be. The development of LFA was 9 years, it took them a lot of money.
Dark
Old 04-20-2012, 02:26 AM   #68
old greg
Rocket Surgeon
Drives: PSM GGA OMG
900lbs w/driver iirc.
old greg is offline   Reply With Quote
Lexus LFA breaks cover before Tokyo unveiling MR2fan Other Vehicles & General Automotive Discussions 403 05-21-2021 03:49 PM
Toyota developing a new turbocharged engine - report quik1987 Other Vehicles & General Automotive Discussions 26 08-21-2012 03:52 PM
1000 dollar deposit first in line for a whiteout FR-S TougeFR-S Scion FR-S / Toyota 86 GT86 General Forum 20 02-20-2012 10:58 AM
3.5 Million dollar Supercar Crash + a Prius WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 17 12-05-2011 05:27 PM
