Drives: 2013 Asphalt FR-S
Headlight Bulb Install
I have the Winjet headlight and a bulb died. I replaced it but the output was horrible. It turns out I hadn't installed it well. Before attaching the retaining cup, I can't get the bulb to stay, orb"lock," in place. What gives? Which direction should the nub on the H7 point?
#2 |
Drives: 2014 FRS - Whiteout - 6spd MT
if you can't figure out how to match 3 knobs from the base of the head light bulb to the 3 knobs to the headlight socket, you should just ask someone else to do it for you. srs
#3 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I believe your thinking on an h11 bulb. As for h7 It should only go one way. I don't have the winjets so I can't confirm
#4 |
Issues resolved: the retainer around the bulb was bent so it wouldn't sit flush.
| Best bulb for reflector headlight? | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 02-08-2014 09:33 AM |
| BRZ and FR-S HID Headlight Bulb Upgrade | BRZ FR-S Video | JPxM0Dz | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 02-08-2014 12:34 AM |
| Headlight bulb housing | SavingManuals | Issues | Warranty | Recalls / TSB | 2 | 11-28-2013 11:00 PM |
| FR-S Headlight Bulb Swap | tennisfreak | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 08-29-2013 02:48 PM |
| 22w LED H11 Headlight Bulb (from AutomationLED) Review | Chewie4299 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-02-2013 06:02 AM |
