#43 |
Drives: Frs
It's neat to see people so intrigued in the design of our cars!
Me, I'm just gonna buy a little cricket sticker and embrace the noise that IMO is just apart of its current character.
-Robert
| The Following 2 Users Say Thank You to Hindi For This Useful Post: | SkullWorks (10-21-2013), strat61caster (10-20-2013) |
#44 | |
Drives: SSM LT MT BRZ
well thank you for the high thoughts. but I had a little more than was available to me in my room at home...I happen to have a full Machine shop and all required inspection equipment to make Aerospace parts for the last 6 decades. (no im not that old) but the shop and it's customers are. |
#45 |
I Love custom Turbo kits
Drives: Limited BRZ
bump this up for education purposes
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | xxBrun0xx (07-23-2014) |
#46 |
Drives: 2013 Scion FR-S - Argento
Nice analysis in the OP, but the elephant in the room is why hasn't Toyota looked into root cause and come up with a remedy? Why is a forum member doing this work?
#47 |
Drives: Moped
| The Following User Says Thank You to Lonewolf For This Useful Post: | Sportsguy83 (07-23-2014) |
#48 | |
Drives: '13 FRS - STX
GDI is noisy and the problem is not unique to Toyota, most manufacturers bury the units under sound deadening and pump manufacturers are still struggling to quiet the system down: http://delphi.com/pdf/techpapers/2013-01-0253.pdf |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Sportsguy83 (07-23-2014), wheelhaus (07-23-2014) |
#49 | |
Drives: 2014 WRB BRZ Limited
#50 | |
Drives: (formerly) 2013 Raven FR-S
![]() Another example is current-gen V6 Camaros. For the 2012 model year, they added sound deadening and re-located the HPFP. They were getting complaints about the noise. Even with the changes, it's still very noticeable at idle when you're next to a wall (like a drive-thru, which is when I normally get mad at my FR-S for the noise). |
| The Following User Says Thank You to malave7567 For This Useful Post: | strat61caster (07-23-2014) |
#51 |
#52 |
Does anyone have any pictures of the pump itself out side of the car? Or, possibly, do you have details on the manufacture/part # of the pump(not the OEM Subaru part #).
My dad just happens to be in the fuel injection world. He has been rebuilding injection pumps(common rail, high pressure, ect) on diesels since before I was born. We were thinking if we had details on the pump we may be able to pull up something thru the manufacture as far as parts breakdowns, diagrams, ect. He thinks this is a very odd sound, granted everything is different, he has not had anything that makes noise like these do. When they rebuild pumps, they often test them on a "test bench"; almost like a dyno for a car. They test output/pressures at designated RPM, all of that kind of stuff and can tune the pumps/computes to match what is needed(according to specs). When on the test bench, he said some of the pumps will get an occasional creek/noise similar to the "crickets"; however, it is a random quick sound and isn't consistent. |
#53 |
Owner and Operator
Drives: FR-S, Yamaha R6, 1972 Camaro
- I too notice that the pump only starts to chirp when temperatures are high.
- The chirp seems to be getting worse with age. Had none until 7000 miles. - I have had the same effect as others, different gas stations make the chirp go away. Question: Do you have to destroy the pump to get it apart? I haven't actually looked at it. Can these be rebuilt?
-Schifko
#54 | |
My car seems to have been getting worse as I have owned it. It was rare, bought it in late May with 6k, I now have 7300ish. Car is going in for a new pump. Maybe I can somehow acquire the old one after it is removed, I'll ask the service writer(good friend of mine). |
#55 |
The Fail Boat
Drives: CWP S.B.
knowledge is power bump~
#56 |
Yes this thread deserves a revival and sticky even though op got banned
| Max NA HP on pump gas as of now? | jadewbj | Engine, Exhaust, Transmission | 128 | 02-17-2016 10:28 AM |
| Engine Internals from CP-Carrillo Now Available! | Infamous Performance | Engine, Exhaust, Bolt-Ons | 108 | 02-13-2014 12:35 PM |
| Engine internals before FI? | Rejor11 | Forced Induction | 14 | 06-04-2013 06:18 PM |
| stronger/forged internals | Tyson | Engine, Exhaust, Transmission | 24 | 03-15-2013 05:38 AM |
| How about them internals | nytfury | Engine, Exhaust, Transmission | 5 | 08-27-2012 08:23 AM |
