Old 07-22-2014, 01:10 PM   #85
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Okay...we got a chance to look at the numbers. I'm still not 100% clear on the actual piston sizes you guys figured out on the calipers being used, so we ran all three scenarios. The disc was held constant at the 317mm diameter. We took a an educated guess on effective radius (which basically means where the center line of the piston is clamping on the disc).
If the piston sizes are 4x30mm or 4x26mm, the bias is way off. That's what caught my eye when I first read the thread. You'd be going from what we calculate as a roughly 67% front bias to a low 50% front bias. I'd definitely say to steer clear of doing such a swap. I would expect longer stopping distances than stock, as well as potential ABS issues.
If the piston sizes are 4x40.45mm (which is the number that was provided later in the thread and sounds more likely given the car from which they're sourced), then yes, the front bias is within a couple % of stock as eikond calculated. I would not expect any issues with ABS integration, etc.
If that's the case, you just have to look at all of the other variables that go along with the swap to see if it makes sense for your needs and goals (as described above).
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following 5 Users Say Thank You to JRitt For This Useful Post:
Calum (07-22-2014), eikond (07-22-2014), finch1750 (07-22-2014), sato (10-21-2014), The Slow One (07-22-2014)
Old 07-22-2014, 01:47 PM   #86
JRitt
JRitt's Avatar
A couple of further points for consideration:
Pads
The OEM front BRZ pad is what Ferodo calls an FCP1639 with the following dimensions (in mm):
137.5 x 50.1 x 17.6
The 300ZX front caliper under discussion uses a smaller pad, which is the FCP986:
119.3 x 49.5 x 14.5
So this one is about 20mm shorter and 2mm thinner. The 300ZX is a little more square though. The 300ZX is going to have a slightly lower overall pad volume and heat capacity, and provides the pistons with less insulation from heat due to the thinner thickness.
Also for reference (and this is an important one), the OEM FT86 pad in Ferodo's top racing pad compound (DS1.11) retails for $250.82. The DS1.11 in the 300ZX shape is $445.37...that's a $200 difference in price on every pad change! So you're going to have less pad material at a considerably higher price. I'm not sure what the pricing structure is for other manufacturers, but it's something to look into, particularly if you were thinking about tracking this setup. The real bugger is figuring out if that larger disc is going to net you any better of a pad wear rate vs. a stock pad on a stock disc, despite the pad having lower overall volume and thickness. Putting a number to that is darn near impossible with so many factors involved.
Discs
Even though the discs do provide a larger heat sink, they aren't providing any greater efficiency (which is one of the primary functions of the disc in a purposefully designed BBK). If you buy a Centric 120.xx blank disc, it's still going to be a pillar vane disc that doesn't necessarily pump much air (see my previous long post above on heat transfer and evacuation). You also don't gain any of the benefits of an aluminum hat with regards to heat transfer or weight reduction.
As eikond mentioned above, you do still have a small net weight loss on the corner, although that is going to be offset by having substantially more rotational mass in the disc (which means it takes more energy/power to accelerate that larger disc vs. an OEM FT86 disc).
An easier pad change is a clear plus. Cosmetics would depend on the condition of the calipers you get your hands on and what you do with them (shave the Nissan off, paint them, etc. as eikond plans to do). If they're beat up from use or sitting in a junkyard, need new seals, etc. the rebuild would add a bit more cost as well.
Overall though, I have to commend eikond for creatively digging into the project and exploring new options.
www.essexparts.com
The Following 2 Users Say Thank You to JRitt For This Useful Post:
Old 07-22-2014, 02:25 PM   #87
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
This is the case.. 4 x 40.45mm. I've found this data in multiple sources online as well as an eyeball with an unexact tape measure in my own garage.
Interesting point on the pad costs.. I hadn't considered this. I did a quick check on the project Mu NS400 pads and found them to be about $100 for Z32 and about $90 for BRZ. Interesting that Ferrodo is such a big difference.. This will probably be luck of the draw.. but something to consider before making any change.
eikond is offline   Reply With Quote
Old 07-22-2014, 02:42 PM   #88
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Pads
137.5 x 50.1 x 17.6
119.3 x 49.5 x 14.5
Discs
Just to give more info. The pricing is very manufacturer dependant it appears. I looked at the pad choices I would choose from and found this (straight from Winmax and Mackin Industries websites).
Project Mu HC+800
Nissan/Subaru 4pot/2pot:
Front - $133
Rear - $89
FRS/BRZ (stock)
Front - $174
Rear - $145
Winmax W3
Front - $145
Rear - $145
FRS/BRZ (stock)
Front - $145
Rear - $145
So as you can see Project Mu is actually significantly cheaper while Winmax is the same price. These are fairly common brake pads used on non-Brembo Skylines (R32,33, and 34), Mitsubishi 3000GT, and basically any Subaru with a 4/2 pot set-up that isn't Brembo.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
eikond (07-22-2014), JRitt (07-23-2014)
Old 07-22-2014, 03:13 PM   #89
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Virtually every Japanese factory 4-pot made by Sumitomo uses this pad.
Also found on S14/15 Silvia K's/Spec-R, among other cars.
-alex
Old 07-22-2014, 03:35 PM   #90
eikond
eikond's Avatar
Just to continue the process of sharing information.. here is a look at the difference in size of the rotors from Stock OEM blank to Stock Leg GT Blank.
Jritt is correct about adding weight to the rotating assembly.. but I can't help but wonder if these do have more cooling capacity than he thinks.. Look at the width.. so much more space in the center cooling channels.. that has to move more air and help cool them better.
Old 07-22-2014, 03:37 PM   #91
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
But its not a FWD car....how much of an issue is adding weight to the front wheels theres less overall weight up front...
Fett4Real is offline   Reply With Quote
Old 07-22-2014, 03:49 PM   #92
eikond
eikond's Avatar
This brake setup actually reduces weight to the front of the car..
The calipers are 6.1 lbs each vs. 14.1 lbs for stock.
The rotors (OEM Leg GT blanks) are 22lbs vs. 17lbs.
So the net weight loss is 6 lbs. The problem with this is that the lost weight is in non-rotating mass, while the weight gain is in rotating mass.. so it may have a detrimental affect to acceleration feel. I doubt it would be very noticeable, but I think from a pure math perspective, that weight is detrimental.
Some day when I'm rich I'll upgrade to set of lightweight 2 piece rotors and then I'll have a lot lower weight and better cooling, etc.. But that's another $800 or so?
Old 07-22-2014, 03:52 PM   #93
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
COULD be made up in the wheel...but again its not FWD so I really dont see the "feel" thing making it into the equation. However hes not running a light wheel at all...
Old 07-22-2014, 04:14 PM   #94
eikond
eikond's Avatar
I see your point I think.. You are saying that the impact of increased rotational mass is less impactful since these are on the front wheels of a rear-whee-drive car.
Also it should be noted that running lighter wheels would/could offset the weight gain from these rotors.
Just an FYI.. I picked up another set of these calipers from a salvage yard. They were $35 each plus shipping.. so $85 overall. The rebuild kits run about $20. Here's an instruction guide on rebuilding them:
http://www.nicoclub.com/archives/reb...-calipers.html
I should re-title my thread.. $500 Big Brake Kit
Old 07-22-2014, 07:32 PM   #95
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
-alex
If you really want to have fun with this, the 94 + 3000GT Twin Turbo also came with these Sumitomo calipers.
40.4x2 + 42.8x2 piston setup in the front (From: Stealth 316)
38.1x2 piston setup in the rear
I don't know how the caliper bolts are spaced, but it's food for thought.
94TT Centric reman calipers for $220 + $100 core charge (From: 3SX)
P@ul is offline   Reply With Quote
Old 07-22-2014, 07:57 PM   #96
mav1178
mav1178's Avatar
https://www.google.com/search?q=sumitomo+4-pot
https://www.google.com/search?q=sumitomo+4+piston
there's a lot out there.
-alex
Old 07-22-2014, 08:49 PM   #97
mike the snake
I'm going tomorrow to see if I can find a set of these calipers.
The ability to change pads by simply pulling some pins is a big win for me.
Old 07-23-2014, 08:43 AM   #98
JRitt
JRitt's Avatar
The LGT disc will definitely have superior cooling vs. the OEM BRZ. I have no doubt of that at all. They have a considerably bigger air gap and far greater surface area. I was talking efficiency. An OEM-style blank will never have the efficiency of a good aftermarket design. You can make the air gap two inches wide, but if the vanes aren't shaped properly you're going to have a lot of turbulence relative to a design built specifically to move air. That's why a considerably smaller racing disc can run much cooler than a larger OEM-style disc.
With big brake kits, most of the kits on the market go about the same thing via two different routes. First would be the brute force method. This is typically the method employed by street BBK's. That means BIG disc and big pads. You use mass to combat heat. The second method would be efficient designs. That is the method used in racing. You use advanced technology and materials to address the heat issue at a far lower size/mass. As in every field, advanced technology is more expensive.
10-4 on the pad pricing info. Ferodo is the main brand we sell, so those are the prices I checked.
www.essexparts.com
The Following User Says Thank You to JRitt For This Useful Post:
ATL BRZ (07-23-2014)
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
