#1653 |
@7thgear,
Good point about just trying it out. I'm still a newbie, so I figured I'd ask here to see if there might be any downsides. @GSG Mike, thanks. Since I'm new, technique is going to be an issue for a while still. I'm still working on hitting my lines consistently well so adding a new variable might not be the best thing yet. |
#1654 | |
Drives: 2023 BRZ
1. It's harder on his car mechanically (minimal) 2. It may affect how smooth he can be in line and footwork 3. It is more difficult to stay right on the edge of control Maybe he just needs a little better alignment and/or tires to carry a tiny bit more speed through the turns and his decision will be easy. Last edited by Pat; 07-22-2014 at 02:31 PM. Reason: adding more info |
#1655 | |
i'm sorry, what?
Drives: Canada
it's just 1 extra gear change.. and area under the curve is area under the curve, if he lands in the powerband and not spinning, he'll always be faster than trying to drive out of a bogged gear (4000rpm is bogged down to me) this just requires better technique because he'll need to change gears into a higher revving engine without clutch kicking the car, but the sooner you learn that the better it will be in the long run. fast and reliable gear changes under extreme conditions is just one of the things that separate the best form the rest
| The Following User Says Thank You to 7thgear For This Useful Post: | CSG Mike (07-22-2014) |
#1656 | |
Points 2 and 3 are the ones that I am a little worried about. I'll have to think about where I'd be upshifting because there are elevation changes and multi-apex corners involved. Good point on the tires. I have been running the stock Primacies while I learn and they have a lot of wear after three full days at that track and a total of probably 80-85 laps. |
#1657 | |
Yes, the shift takes time, but executed well, power is only disrupted on the upshift, and is more than made up for by the extra power in 2nd, if traction is not lost. If it affects how smooth the driver can be, then it is a skill that should be practiced, although if car control and line is the focus, then forgoing the shift is advisable. |
#1658 | |
Drives: FR-S Firestorm 6MT
Keeping T14 in 3rd is better because you can maintain grip and be smoother without shifting down and back up, downside is you have to wait for the power to come on (as you climb the hill too) but chances are high that you can be quite a bit more consistent if you just leave it in 3rd. I have done it both ways with my car and when in 2nd, the car wants to slide out on the off-camber uphill turn. Third gear. Keeping the higher gear also forces YOU to find ways to gain more speed into that corner to make gearing work better. I think @CSGMike has mentioned this a few times in this thread also. I'll post up my vids later tonight in the Calabogie thread. Track map so others understand too.... |
#1659 |
14 is definitely one of the ones I'm curious about, but my question was really more general since I'm curious about the best way to make use of the power band.
Looking at the map I wonder if 17-20 might even benefit from second to hit the front straight faster. |
#1660 |
It's a good question. Until you build up speed, you are kinda stuck between which one is better. But the key is actually finding the right line and speed through these corners so you can stay in 3rd until the straight.
#1661 |
Drives: WR Blue BRZ
The way I always approach gearing is trying to find a gear I don't have to shift out of mid corner. Of course there are exceptions to this rule if you have a long increasing radius corner you might go from 2nd gear speeds to 3rd gear speeds through the corner. If say the car had a power band that started strong at 4500 and I was at 4000 in 3rd I wouldn't worry about trying 2nd for that short bit of better acceleration. However if I was way out of the power band I'd try it and see. The best way to tell is just to try it one way and find some sort of landmark to check your speed at then try it the other way and see if it's better or worse. You can do this with trying different lines and gears etc.
| The Following User Says Thank You to Chillracing For This Useful Post: | juliog (07-22-2014) |
#1662 |
Drives: Raven 6MT
Mike,
This past weekend at VIR, my instructor made some suggestions in regards to my steering inputs. Specifically, he was noting that I was giving too much input on initial turn in and then using the throttle (and some steering) to make my way through the rest of the turn. I believe that this could have been the cause of some understeer on initial turn in as well, but I was on new tires and camber plates for the first time so it could be due to that as well. Tire temps were within 1-2 degrees of each other across the inside, middle and outside and pressures were ~38 hot. I'm on Goodyear Eagle F1's with stock suspension and Raceseng CamCas plates, with ~ -3 degrees of camber up front and -1 in the rears and an extra degree of caster up front. Only other mods are pads, lines and fluid. I wish I had in car video to show you, but my question is how can I work on slowing my inputs down and make my steering more linear, both on and off track? And what might be some signs that I am turning in too much initially (ie loud tires, understeer, etc)? Thanks!
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
| The Following User Says Thank You to THEmailman For This Useful Post: | ZionsWrath (07-22-2014) |
#1663 | |
Thanks
#1664 |
Update from NJMP this past weekend...
Conti Take-offs were amazing. Haven't driven on race tires in about 6 years and forgot how much they make a difference... Still charting the temps on this car as well... Ambient- 80-83F Coolant- 195-203 w/Koyo Racing Rad Oil Temp- 265-275 no cooler, Motul V300 5w30 Engine Oil We will have the OEM 2015 WRX Oil Cooler on this car for our next event so hopefully we can get some hard data for you guys on how much it cools it down. After that we'll be testing out some OTS oil coolers as well. ![]() -Mike Paisan ![]() Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
| The Following 3 Users Say Thank You to AZP Installs For This Useful Post: |
#1665 |
Drives: Raven 6MT
Cool man! Sorry I didn't meet you, but if I remember correctly you had NY plates on the car...? There were quite a few 86's at this event so that was nice. Hopefully Jeff gave you some good instruction as I felt my post was about the only useful thing he did for me.....
#1666 | |
Drives: 2013 Cayenne turbo
I'm not saying that every 5k is too frequent, just that there is such a thing as "changing more often CAN hurt things". This isn't the case on the diff and manual trans because they are just dip-lubed, but for automatics and engines (i.e. things with fluid pump lubricated surfaces), it can be a problem. Also, it increases the risk of getting a cross-threaded plug on any unit because you have a small chance of that happening each time you unplug and replug the pan.
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
