Old 04-18-2012, 12:56 AM   #43
Dimman
Kuruma Otaku
Dimman's Avatar
Well that depends on the timing, right? What the 3 stages can do is to pump up the bottom like we are discussing but also the top end which will reduce the need for as large as ports. Plus probably somewhere in the middle. They can also be timed to jump over the bad waves.
Because titanium.
Old 04-18-2012, 01:35 AM   #44
serialk11r
Drives: '06 AM V8V Coupe
The thing is this, the sound wave does not create a consistent increase in flow at all, it reflects back pretty quickly. The amount of time the valve is open is longer than the time the sound wave hangs around the cylinder.
It would be nice if someone like arghx7 could explain lol.
Old 04-18-2012, 01:45 AM   #45
Dimman
Kuruma Otaku
Dimman's Avatar
He sort of did with a cylinder pressure over time graph. It's not the average pressure that matters but the final pressure as the intake valve closes. Also keep in mind that the pressure waves have a shape/length not just amplitude.
Because titanium.
Old 04-18-2012, 01:52 AM   #46
old greg
Rocket Surgeon
Drives: PSM GGA OMG
How is carbon fiber fabric usually made? I know the layup and stuff is the biggest cost problem with CF, not the material itself.
It's made on a loom, just like any other woven fabric. The fibers themselves are made from Polyacrylonitrile (a string of carbon molecules with some junk hanging off the sides) fibers that are heated in air and then run through an argon filled furnace. It's quite an energy intensive process, so the material costs are actually very high in relation to steel or aluminum. But even with metal, the majority of the final cost comes from manpower and machinery.
I wasn't talking about filling, I was talking about the fact that the ports are very high flow and the valve lift is likely huge, so there's very little charge motion at low rpm.
Since it has drive-by-wire ITBs, it's possible that the throttle map keeps the throttle plates mostly closed at low rpm and high load to generate tumble and localized velocity. With the injectors right below the TBs, this could create pretty effective air/fuel mixing despite the low port velocity.
old greg is offline   Reply With Quote
The Following 2 Users Say Thank You to old greg For This Useful Post:
Dark (04-18-2012), serialk11r (04-18-2012)
Old 04-18-2012, 05:39 AM   #47
Dark
Elite Padawan
Dark's Avatar
Sorry for my noobiness, but I have a question.
Could you explain the differences of high and low port velocity especially in this case?
Dark
Dark is offline   Reply With Quote
Old 04-18-2012, 06:14 AM   #48
serialk11r
Ah, thanks. The assembly process for metal parts is less labor intensive though right? I mean, this weekend I went to FSAE and they said they switched from carbon fiber monocoque to tubular steel frame + CF/aluminum honeycomb panels to save (a lot) of time, and the frame was completely hand assembled of course. I guess stampings for a production car would require expensive machinery though.
And the throttle body fuel mixing sounds plausible, thanks. Do any engines use this for certain though? Seems like motorcycle engines could benefit or something.
Old 04-18-2012, 09:15 AM   #49
SupremeMoFo
Drives: BMW M135i
I just wish Toyota would put some more effort into fixing the handing of the rest of their day to day models... they should take a leaf out of Ford Europe's book.
SupremeMoFo is offline   Reply With Quote
Old 04-18-2012, 10:53 AM   #50
Dimman
Kuruma Otaku
Dimman's Avatar
One analogy that gets used is drinking straws. Compare a big and little straw. With a little straw you don't need a lot of effort to move some water. So it moves faster with less effort. But if you want to drink a lot of water quickly it becomes very hard. In the car case the straw size is the intake port and the effort is (mostly) the piston's downward speed, which is rpm dependent.
So that's sort of how port sizing affects the velocity.
Now for velocity differences you can use a garden hose analogy. An open hose moves a certain amount of water rather smoothly but a little slow. Now if you speed it up by putting your thumb partly over the opening, the water sprays out faster. But the amount of water hasn't changed. In the cylinder head, the higher velocity air entering the combustion chamber moves around more and allows the air and fuel to mix better and burn better when ignited.
(analogy's are imperfect, and so's my full grasp of what the hell's going on, but this is close...)
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
Dark (04-18-2012)
Old 04-18-2012, 10:58 AM   #51
Dimman
Kuruma Otaku
Dimman's Avatar
Motorcycles do do it, some with secondary butterflies controlled by the ECU. (Kind of like a modernized version of the old 4AGE and 3SGE TVIS system.)
Also something to think of about carbon fiber, is that the term is also now applied to short strands of carbon mixed in a resin or castable thermoplastic.
Look up Polymotor (I think). Carbon fiber engine block. But it's not what we think of as the woven stuff.
Because titanium.
Old 04-18-2012, 12:12 PM   #52
old greg
Rocket Surgeon
Drives: PSM GGA OMG
In the OEM production world, yes very much so. And yes, they use very big hydraulic presses with very expensive dies that wear out and need to be replaced.
In your FSAE analogy, it depends. Fishmouthing the tubes by hand is very time consuming and labor intensive, it's easily a month-long process for an FSAE team under normal circumstances. These days a lot of teams are outsourcing that to companies like Cartesian Tube that CNC bend/fishmouth the tubes based on solid models with about a ~1 week turnaround time if they aren't too busy. Assuming you have all of your jigs ready you could go from the UPS truck to a completed spaceframe in just a day or two.
Old 04-18-2012, 03:06 PM   #53
Dark
Elite Padawan
Dark's Avatar
I kinda understand your analogies. Thanks, Dimman.
So you mean the high port velocity doesn't always mean air coming in the combustion camber more, right?
Dark
Old 04-18-2012, 03:12 PM   #54
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
F1 cars have 7 speeds, not 6 :P The V10 is cool though!
[u2b]AScfESzQzIQ[/u2b]
quik1987 is offline   Reply With Quote
Old 04-18-2012, 03:24 PM   #55
Dimman
Kuruma Otaku
Dimman's Avatar
I think faster is generally better, especially given the same volume of flow. But too fast leads to frictional losses that can reduce flow. Plus there is something about sonic choking that I don't understand yet.
Always about compromise.
But overporting chasing a volume flow number (just CFM) with no regard to the velocity is what leads to shitty response on NA motors that don't make power til really high rpm. The trick is to increase flow AND velocity which is what separates the pro porters from amateurs. Or at least increase flow and minimize velocity losses.
Aftermarket domestic porting and motorcycle porting is far more advanced than the typical import performance porting.
Because titanium.
Dark (04-18-2012)
Old 04-18-2012, 03:27 PM   #56
quik1987
quik1987's Avatar
[u2b]dph3oSUzf-I[/u2b]
Lexus LFA breaks cover before Tokyo unveiling MR2fan Other Vehicles & General Automotive Discussions 403 05-21-2021 03:49 PM
Toyota developing a new turbocharged engine - report quik1987 Other Vehicles & General Automotive Discussions 26 08-21-2012 03:52 PM
1000 dollar deposit first in line for a whiteout FR-S TougeFR-S Scion FR-S / Toyota 86 GT86 General Forum 20 02-20-2012 10:58 AM
3.5 Million dollar Supercar Crash + a Prius WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 17 12-05-2011 05:27 PM
