Old 07-21-2014, 07:24 PM   #1
nocwage
MMTT
Drives: 2019 Subaru BRZ
Anyone else kill their battery with the trunk?
Twice now I've walked out to my car, pressed the unlock button and nothing happened.. The first time was like a week after I got the car and I thought "oh shit it's broken already" and then after a ton of checking I noticed the trunk was JUST ever so slightly popped open. (It's surprising how hard it is to tell at a glance)
Well it just happened again, and this time with my fancy LiFePO battery
Here's to see how well they take getting COMPLETELY drained and recharged..
Debating either leaving the trunk disabled OR if I can get away with just removing the bulb from the trunk..
nocwage is offline   Reply With Quote
Old 07-21-2014, 07:29 PM   #2
radroach
Drives: car
Why are you using a LiFePO battery?
Old 07-21-2014, 07:30 PM   #3
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
Had that happen to me. Now I always make sure to check the trunk is securely closed before I walk away.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 07-21-2014, 07:49 PM   #4
nocwage
MMTT
Because unlike other lightweight batteries it cranks like stock.
And it's baller.
The Following User Says Thank You to nocwage For This Useful Post:
radroach (07-21-2014)
Old 07-21-2014, 07:50 PM   #5
nocwage
MMTT
I am popping it with the key, I almost never use the trunk which makes it double annoying when this happens
But then if I disable the trunk it will be annoying not being able to pop it when I do want to..
Old 07-21-2014, 07:56 PM   #6
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Any half assed lithium cell or package should have low voltage protection that does not let it actually drain below a set voltage. Typically when you reach that preset limit it will been the circuit to protect the cell(s). Id ask the manufacturer and also check it with a multimeter.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-21-2014, 08:34 PM   #7
quark
Had this happen to me also.
Swapped out the 5Watt light bulb (437mA) with a low power T10 LED (20mA).
With the LED and dash indicator the current draw is ~80mA, this will allow the light to be on for about 2 weeks with enough power left in the stock battery to start the car.
quark is offline   Reply With Quote
The Following 7 Users Say Thank You to quark For This Useful Post:
BirdTRD (07-21-2014), Busybee (04-21-2019), CruiseZen (07-22-2014), denkigrve (07-22-2014), FRSBRZGT86FAN (07-22-2014), litemup (07-21-2014), nocwage (07-21-2014)
Old 07-21-2014, 10:03 PM   #8
nocwage
MMTT
Awesome where did you order that from?
Old 07-21-2014, 10:06 PM   #9
nocwage
MMTT
Shorai battery, I wish I had bought the earthX one since it HAS the over discharge AND charge controller ON the battery.
If this one is toast I will buy EarthX
The Following 2 Users Say Thank You to nocwage For This Useful Post:
P@ul (07-22-2014), Weasel Soup (07-21-2014)
Old 07-21-2014, 10:24 PM   #10
litemup
Drives: around
Google is your friend. This one's on the autozone website. It's mine now. Get your own.
litemup is offline   Reply With Quote
Old 07-21-2014, 10:50 PM   #11
quark
Got mine from a local electronics store.
The lowest power ones will be ~20mA, you can source from ebay
http://www.ebay.com/itm/Klaxcar-8701...8df2239&_uhb=1
The cre LEDs will be brighter but consume more power ~80mA
Old 07-21-2014, 10:58 PM   #12
litemup
Drives: around
Wait, I didn't read closely enough. If I get the 20mA bulb I can leave my trunk open for 2 months? Damn it!
Old 07-21-2014, 11:14 PM   #13
quark
You will get about 10 days with that LED, (stock battery down to 30% capacity). Much better than stock bulb (totally dead in 4.5 days)
Old 07-21-2014, 11:18 PM   #14
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
Yes
But I just took the bulb out and crushed it
With the Shorai charger it recovered quickly
Lol
Lawnik is offline   Reply With Quote
Relocating Battery to trunk ML Engine, Exhaust, Transmission 35 08-03-2015 12:58 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Fuel or Battery Kill Switch? nabil_frs CANADA 3 03-09-2014 08:43 PM
Battery in the trunk scottman Electronics | Audio | NAV | Infotainment 14 10-06-2012 07:26 PM
Relocating battery to trunk Ess Vee Engine, Exhaust, Transmission 17 10-02-2012 04:32 PM
