Old 07-20-2014, 12:55 PM   #99
Ubersuber
Drives: BRZ Pearl White
My 2 c.
The shifter on these cars is, in effect, already a short shifter. I can't imagine the effort the actual short shift kit might add to changing gears on these cars but it must feel pretty slick on a track when everything is nicely warmed up.
This means you feel just about everything that is going on during the shift, unlike regular cars which have shift leverage possibly up to twice as much as our stock shifters. You just don't feel the shift in a regular car and so you tend to shift with higher forces which only feel "light" because of the extra leverage from that long spindly shift lever. Our cars have short levers.
The first two gears are triple cone synchronized so there will be a difference in the feel when you shift into first or second. You think the 1/2 shift is hard, try shifting into 1 in a cold box at anything above idle speed. You just need to recognize that the shift lever effort in these cars is much higher than on a more normal car, and this affects the cold shift disproportionately more.
3,4,5 and 6 are just regular double cone synchronizers which feel different when shifting.
The 1/2 gear cluster is the largest and heaviest gearset and the box is constant mesh, which means ALL the gears in the box are turning at high speed when in first and second. That second gear synchronizer has to slow down the whole gearset in order for the dogs to engage. The dogs are the "gears" you feel when changing gear, the gears themselves are always fully meshed (except for reverse of course). That clash is not the gear teeth (fortunately) but the much larger and squared off teeth in the dogs which actually engage the selected gearset.
These gearboxes use baulk ring synchronizers invented by Porsche. There is no slippage when the dogs engage because the synchronizers can't allow the dogs to engage until the baulks match the notches in the baulk rings. That buzz or clashing you feel comes from the baulks and the dog teeth and they are designed to take that sort of punishment.
The synchronizers are likely bronze faced (not brass, that is too brittle) and they need to both absorb and hold gear box oil and also press though the lubricating film in order to work but not wear too rapidly. The less time the synchronizers spend slipping the better.
So, in our cold boxes you need to shift slowly and quickly at the same time. This sounds impossible but if you understand what is going on (and you can feel everything through the shift lever in these cars, one of the many delights of driving one) it isn't so tricky.
I learned to drive on cars with old worn out synchronizers because those were cheaper to buy, after a series of incompetent previous drivers had prematurely worn the gear box. I was taught to shift firmly but deliberately in three quickly executed but definitely separate steps (this is the "eggshell" technique described elsewhere in this thread, it isn't really as gentle as described but the concept is the same). When the car is in first and you wish to change gear you select neutral as you lift off, then you pause ever so briefly, shorter pause if the gearbox is warmed up and longer if it is still cold, then you firmly select second gear.
If you do this I guarantee your baulky 1/2 shift will proceed butter smooth even in a very cold box. I routinely drive my BRZ in minus 30C weather with no shifting issues if I use this old clapped out gearbox technique. In truth, if you treat your synchronizers with more respect the box will never wear out and you will never clash a shift again.
You will note that the pause on the upshift is equivalent to the double clutch throttle blip on the downshift, also required if the synchros are worn and recommended even if they are new (though DO NOT double clutch unless you do it correctly as you will wear the synchronizers more if you overspeed the blip).
It is all in the timing on a cold upshift. You will find the exact length of pause (and we are talking multiples of nano seconds here, not one mississippi two mississippi!) that allows the gearcluster to slow down more closely to the second gear speed.
Finally, well built gearboxes need quite lengthy break in periods before they work fully as designed. This is not gentle break in but miles accumulated. Many manual gearboxes aren't fully run in until you have driven 5,000 to 10,000 miles of multiple shifting. How many owners still have trouble with this shift after 10,000 miles? It takes time for the synchronizer faces to wear smoothly and fit exactly into their mating surfaces and for the bronze to absorb the correct amount of lubricant into the pores of the metal for the synchros to work flawlessly. How many of you noticed how notchy the brand new gearbox felt compared to now after a year of ownership?
Ubersuber is offline   Reply With Quote
The Following 8 Users Say Thank You to Ubersuber For This Useful Post:
callisto (04-10-2023), coolaron (07-20-2014), EL_to_TBD (09-15-2014), frsvr4 (07-24-2014), Koa (12-04-2014), SubieNate (11-08-2014), Tcoat (09-15-2014), Thrilled (01-28-2015)
Old 07-20-2014, 04:33 PM   #100
coolaron
AFAIK 3rd gear is also triple-cone synchros for this car.
Originally Posted by Ubersuber View Post
My 2 c.
coolaron is offline   Reply With Quote
The Following User Says Thank You to coolaron For This Useful Post:
Ubersuber (07-20-2014)
Old 07-20-2014, 06:38 PM   #101
Ubersuber
I believe you are correct, triple cone on third gear also.
http://www.hoerbiger.com/upload/file...chronizers.pdf
The Following User Says Thank You to Ubersuber For This Useful Post:
frsvr4 (07-24-2014)
Old 07-24-2014, 03:43 PM   #102
Stratoside
Stratoside's Avatar
Drives: Firestorm red MT FR-S 2013
does it hurt the car if I try to shift it to 2nd (have it all clunky) without waiting for it to get to the right temperature?
cause i've been driving my fr-s like that for like 15months now lol
Stratoside is offline   Reply With Quote
Old 07-24-2014, 06:11 PM   #103
PHLonomenal
PHLonomenal's Avatar
Drives: Whiteout 2014 Scion FR-S
Originally Posted by Dazza View Post
Add manual transmission Ferrari's to your list....not bad company to be in huh?
Add the BMW E9x M3 to that list as well. Common complaint on the forums. Not mine tho.
Sent from my StarTrek communicator using Tapatalk
I had an M3 once...and barely missed it. Barely
"what I'm driving here...is an ending." Jeremy Clarkson
PHLonomenal is offline   Reply With Quote
Old 09-15-2014, 01:44 PM   #104
EL_to_TBD
EL_to_FR-S!
EL_to_TBD's Avatar
Drives: Scion FR-S
My 2 c.
This is probably the most informative post I have read on this issue thus far so thanks for that!
I have a couple questions though:
1. In your "eggshell" shift method, are you releasing the clutch after shifting out of first and before going into 2nd (i.e. double clutching)? I am assuming you are not but want to make sure.
2. I understand your description of breaking in the transmission but last time I had my tranny replaced at Toyota (maybe going for a 2nd soon), there were many metallic shavings in the fluid. I have no doubt there are lots of shavings in there now. Will these shavings not potentially damage the gears/synchros? What is a good point to flush out the fluid and do I have to keep flushing it out more than you would for a typical tranny?
Thanks.
EL_to_TBD is offline   Reply With Quote
Old 11-08-2014, 12:37 AM   #105
Thrilled
Drives: FR-S Whiteout 2013
One year break-in not helping
My 2 c.
I just finished month 13 and have 16.5k mi. As the temperatures are dropping, all of the N-1, 1-2, 3-2, 2-1 shifts are still stiff.
Call me crazy, but it's worse on cold, wet days in the 40F to 50F range compare to nights that drop to 34F. We haven't had any freezing nights yet. Successive cold days makes it worse compare to days that warm up in the afternoon.
Sometimes it feels like it won't enter (I use a light grip and don't force it). When that happens, I actually find two different methods get the gears to mesh: 1. Take it back to N, let clutch up, press down again, shift again. 2. take it back to the gear I am coming from and trying a normal shift again. Absolutely it does not work to skip a gear when down-shifting. Must enter each gear even if not engaging the clutch and only move the lever when clearly in the appropriate speed range (I find multiplying the gear # by 10 is a good indicator of the appropriate speed when cold, though gear 1 can be stiff even when standing still).
Last year when in sub-freezing temps, it would sometimes take a full 30-40min commute before the shifting would start to loosen up. That's a little nuts. Perhaps it needs some sort of electric element to help warm up the trans?
I want to try Pentosin, but I switched Toyota dealers for service and they want to evaluate it in its current condition when it gets consistently cold outside. I appreciate the scientific approach. If the other Toyota dealer (Ardmore) had at least logged the complaint last winter, perhaps somebody would trust me and act on it.
Thrilled is offline   Reply With Quote
Old 11-08-2014, 12:48 AM   #106
Was -1c (ummmm about 30F ?) here this morning and everything was still as smooth as ever for me. Wondering if this is yet another early production issue that the newer cars don't have.
Anybody with a later 14 build have this problem?
Old 11-08-2014, 11:59 AM   #107
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Mine as smooth as butter in both cars with pentosin
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 12-04-2014, 11:56 AM   #108
billyk
billyk's Avatar
Drives: 2014 Argento FR-S
What a great thread! Very informative.
My FR-S is very fickle shifting into 2nd, especially in the am. This thread offers great background on this issue and some good ideas of how to manage it.
I'll try waiting a bit in the shift to 2nd to see if that works.
billyk is offline   Reply With Quote
Old 12-04-2014, 12:25 PM   #109
jdd
Drives: 2015 FR-S (6MT)
Location: Vancouver, BC. not Surrey or Richmond or Burnaby!
We have finally gotten hit with cold weather (0C), and my second gear is horrible. It was always a little stiff, but it has gotten significantly worse with the cold weather.
I drive a 2015 (~3500 km).
jdd is offline   Reply With Quote
The Following User Says Thank You to jdd For This Useful Post:
Tcoat (12-04-2014)
Old 12-04-2014, 12:59 PM   #110
Two weeks into pretty steady cold weather and mine has not changed at all. Still nice and smooth. I must just have got lucky (or mine is broken and I don't know it yet)
Old 12-04-2014, 03:49 PM   #111
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
I had this problem too, but for some reason right after my 1st free dealer oil change it got a lot better. They have no record of anything being done, but I am positive they did something as it was noticeable driving out of the lot. And now with the cold weather it is smooth as snick-snick even right after startup.
Is it possible they adjusted the shift fork? As a TSB or something?
Jond63 is offline   Reply With Quote
Old 12-04-2014, 04:15 PM   #112
sato
sato's Avatar
Drives: Dodge Patitas
I have to change the transmission fluid to see if it improves, but my 2014 has a little bit of difficulty on 2nd gear... slight though.
sato is offline   Reply With Quote
New manual driver - SPEED BUMPS! eifer Engine, Exhaust, Transmission 47 06-16-2015 02:27 PM
FS: Toyota 86 GT! 6 Speed Manual ! Black ! [VIC] os86 Australia Classifieds 0 12-19-2012 06:01 AM
Whiteout 6 speed manual (Raleigh, NC) low trq Southeast 3 10-29-2012 04:57 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
Another reason to buy a manual transmission car... xantonin Off-Topic Lounge [WARNING: NO POLITICS] 4 08-10-2011 12:30 PM
