Old 07-18-2014, 02:04 PM   #1
Andre da gr8
Drives: Asphalt '13 frs mt/ five axis
Should have bought a boat!!!!
So i got off of work and was driving home in the rain. Now its been rain for two days.... So half way through a puddle a lake i mean, my car died. I immediately got out and pushed it through the rest of the way. No water got in my car, but In my freak out i tried to start it, it turned over once then stopped and i haven't tried since. My dad advised me to let it dry then try to start it, I'm not to sure about that, anyone with some advise, knowledge, or input would be much appreciated. Oh and fml.
asphalt frs, 5 piece 5 axis, n1 ti, perrin cold
Coming soon: getting hard to decide!!
"im not that guy everyone wants to be!!, hold ma beer and ill kick his ass tho"
Andre da gr8 is offline   Reply With Quote
Old 07-18-2014, 02:06 PM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
How deep was it?
Sounds like a factory defect if you could open the door without flooding the cabin.
- AdrianG
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
Andre da gr8 (07-18-2014)
Old 07-18-2014, 02:09 PM   #3
connorlug
Drives: #1553 10 Series FRS
take the maf out and make sure its dry, if you really think you sucked in some water you need to pull the spark plugs out and crank it, let it pump the water out.
connorlug is offline   Reply With Quote
The Following User Says Thank You to connorlug For This Useful Post:
Old 07-18-2014, 02:13 PM   #4
Andre da gr8
Thanks for the replies so quick the top of my intake was dry I'm almost positive it didn't make it in the intake but ill check
Old 07-18-2014, 02:26 PM   #5
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
I would have the car towed to a reliable shop to have them give it a good looking over.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
The Following User Says Thank You to CruiseZen For This Useful Post:
Andre da gr8 (07-19-2014)
Old 07-18-2014, 03:50 PM   #6
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
inspect air filter. If the filter is wet you sucked in water.
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
Old 07-18-2014, 03:58 PM   #7
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Strange, The intake is pretty high up in the bumper cover (on a pretty low car). I can't explain how you would have hydrolocked your car.
The Following User Says Thank You to tahdizzle For This Useful Post:
Old 07-18-2014, 04:06 PM   #8
stugray
Drives: 2013 GBS BRZ Limited
If you sucked in water then it "turned over once then stopped" you may have already killed it.
Hydrolock can very easily bend a rod.
Normally you would "Just take the plugs out" as others suggest however on this car to do that you need to lift the engine.
It would be easier to take out the DI injectors....
And if you even think you have water in the cylinders and you are tempted to just crank it, I would suggest this first:
Put the car in 5th gear ebrake off, and very gently push it.
If it turns over more than once you got the water out.
Cranking it with the starter can cause more damage than very gently pushing it in gear.
At least with my push to start button, I cant just "bump it"
The Following User Says Thank You to stugray For This Useful Post:
Old 07-18-2014, 04:08 PM   #9
STV3
Señor Member
STV3's Avatar
Maybe a fuse?
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
Old 07-18-2014, 10:48 PM   #10
iniguez310
Cool Guy
Sorry to say it but it has to be hydrolock man. There is no reason the engine won't crank unless the battery is low on voltage, but that's not a cause since the car was running when it shut off on you.
iniguez310 is offline   Reply With Quote
The Following User Says Thank You to iniguez310 For This Useful Post:
Old 07-19-2014, 12:50 AM   #11
Andre da gr8
ok so big correction! I did try to start it again when I woke up this afternoon (I work nights), and it did not turn over , but this is what it did when it first died in the water, so it has not turned over at all since dyeing!!. There's no way water got in the motor I do have a perrin cai on it, but even things lower in the bay were still dusty and dry on top. I want to think its electronics but everything works, the radio even picked up ma call while I was looking at it earlier(bespoke), so idk I know im taking it to a shop on Monday assuming I can get it on a trailer and ill keep it posted
Old 07-21-2014, 12:29 PM   #12
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
even hydrocked motor, radio works. yeah i would check with shop.
sucks to have this car is difficult to pull out spark plugs.
Japanese Boat spotted off BC Coast Enemies Off-Topic Lounge [WARNING: NO POLITICS] 5 04-02-2016 09:32 PM
FI Guys: Were you more excited when you bought your car, or when you bought boost? husker741 Forced Induction 28 02-25-2014 04:57 PM
Done modding until its lowered...anyone else in the same boat? BlueDubbinTDI Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-10-2013 05:03 PM
How long to Ontario (GTA) once BRZ is on the boat? philosophy CANADA 4 04-28-2013 01:14 AM
Anyone's car also on a boat right now? Trobinson CANADA 4 04-15-2013 02:04 PM
