Old 07-18-2014, 10:53 AM   #351
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by Reaper View Post
im building an oil cooler and have a mishi 19 row. Any quantitative evidence on oil cooler core location? either in between the intercooler and the rad, or in the fog light area. I also thought about on top of the crash beam next to the air filter with a thermostatically controlled fan on it, but im not sure if it will fit.
A lot of people have seen success putting the oil cooler in front of the intercooler (not the best looking but functionality would be unmatched).
I've also seen people put it in front of the fog light area and remove that plastic so air can get in. Passenger side being the preferred side it seems.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-18-2014, 10:57 AM   #352
Synack
Boosted
Synack's Avatar
Drives: Sideways
Like these
The Following User Says Thank You to Synack For This Useful Post:
blackfireball5 (07-18-2014)
Old 07-18-2014, 11:08 AM   #353
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Dat blue car looks sweet. That would be the best way to do it.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
blackfireball5 (07-18-2014), Dipstik-sportech (07-18-2014)
Old 07-18-2014, 11:13 AM   #354
mike the snake
What about laying the oil cooler flat? Cut some of the underbody and laying the oil cooler flat would allow the air to exit down and away instead of into the fenderwell, maybe?
Old 07-18-2014, 11:43 AM   #355
Synack
Boosted
Synack's Avatar
Drives: Sideways
Weld it to the oil pan
Old 07-18-2014, 11:49 AM   #356
Synack
Boosted
Synack's Avatar
Drives: Sideways
Honestly you could probably do whatever you want with it, but in the end I wouldn't want to make the routing of the oil lines much more difficult just to get to the cooler to an optimum location.
Old 07-18-2014, 01:21 PM   #357
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
WELL....i know of all the common places, i even posted about that. Putting the oil cooler in front of the intercooler puts 200 degree heat into your intercooler. Putting it in between the intercooler and the radiator helps, but still restricts air flow to the rad and im running a stock radiator. Putting it in the foglight area seems pretty good minus the airflow out of the area is a little restricted and oil cooler lines get a little bit long. Im almost thinking about a small fan on it in the fog light area.
But after poking around last night there is a rather large area next to my air filter (fullblown kit) that has nothing there above the crash beam so an oil cooler and a fan might fit. I also looked at placing it at an angle BEHIND the radiator in front of the drivers side head laid down with a fan blowing OUT of the engine bay and towards the ground. I currently use no skid plate so i would use a corner of it to aid in mounting it, most likely at some awkward angle. Any thoughts?
Old 07-18-2014, 01:58 PM   #358
Dipstik-sportech
Dipstik-sportech's Avatar
Mine is behind the fog light and I just removed that one light, because racecar
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
protpibe (07-19-2014)
Old 07-18-2014, 05:44 PM   #359
Reaper
Reaper's Avatar
Drives: violent
this but with a fan.
Old 07-18-2014, 06:29 PM   #360
BadBRZ
Drives: Subaru
or get a robispec and not worry about oil cooler placement....
plus it will help heat your oil in the winter
BadBRZ is offline   Reply With Quote
Old 07-18-2014, 07:34 PM   #361
Dephective
Drives: '13 Whiteout FRS
^ Don't quote me, but i've been hearing they've been having issues with the Robispec combo. I've seen a few posts about it now. I would love one though if I could afford it (and it worked, course.)
I think best place for oil cooler is behind fog light area on passenger side with mesh covering it. Cutting/replacing factory crash beam would result in you getting sued in the event that they do any investigating after an accident, you modified safety equipment that is part of integral crumple zones. Also, putting another heat source in front of 3 heat sources already, making a total of 4 makes the subsequent 3 heat exchangers less efficient.
Depending on pipe routing locations in the bay for your FI kits, a bracket suspending a cooler in front of the motor on the passenger side with a shroud directing air flow would be another good option while still maintaining fog light functionality.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
The Following User Says Thank You to Dephective For This Useful Post:
OjiGeorge (07-18-2014)
Old 07-18-2014, 09:36 PM   #362
mike the snake
I was thinking behind the fog light, but laid flat, with the plastic underbody removed. Air would enter the fog light hole, and exit down through the cooler, basically in front of the wheel.
Old 07-19-2014, 12:59 AM   #363
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I have my oil cooler mounted in the passenger fog light area. I just picked up one of these. Gonna mount it to the fender liner as an exhaust vent.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 07-19-2014, 01:00 AM   #364
blackfireball5
Size:  56.4 KBName:  uploadfromtaptalk1405746054344.jpg
Wheelwell Profile
The Following User Says Thank You to blackfireball5 For This Useful Post:
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
