Old 07-04-2014, 01:04 PM   #1
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
DIY loose sidemarker quick fix
So i came up with an idea to hold the side markers in place after the little clip breaks. i know some people are gonna say just buy new ones for another $50 but chances are after i remove the bumper for what ever reason a few times they will break again and poke out.
Tools i used are, small flat head screw driver, small needle nose pliers, a drill, 3/8s drill bit, a really small drill bit the diameter of a paper clip.. and a paper clip
you may have something like this if your clip is broken or loose, both sides looked like this on my car, quite depressing to look at.
i started by drilling out this little rivet for easier access behind it, you will want to use a bit slightly larger then the hole. Something around a 3/8's should do it
this is what it looks like after, just bend it out of the way.
next you will want to pull the rest of the broken clip out of the light for easy drilling. i used the flat head to fold in the locks and the pliers to walk it out. Thats the tiny drill bit for size reference, i pulled it out of a draw full of bits and its too small to read a size on it, sorry idk the size of it
this is were you use the tiny drill bit, aim for the center and go straight through. To make a tighter fit, go closer to the lens side but this may prove install difficulties
bend the paper clip so you can curve it through the newly drill hole
now install it back on the car,slip your paperclip through the hole to hold the lens in. Bend back and re-rivet the support bracket if you'd like. i didn't care that much to rivet mine.
Its not the flashiest way to fix it but its effective and holds the lens steady on the track. Maybe it will help someone else
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 07-04-2014, 02:06 PM   #2
B L U E S L A T E
Drives: BMW E84
Thanks for sharing. I have a feeling many members will be spending the weekend doing this. Haha
B L U E S L A T E is offline   Reply With Quote
Old 07-10-2014, 12:38 AM   #3
Andre da gr8
Drives: Asphalt '13 frs mt/ five axis
Great little write up, I thought about something similar but never got around to playing with it. Rigging that damn thing up tomorrow.
asphalt frs, 5 piece 5 axis, n1 ti, perrin cold
Coming soon: getting hard to decide!!
"im not that guy everyone wants to be!!, hold ma beer and ill kick his ass tho"
Andre da gr8 is offline   Reply With Quote
Old 07-10-2014, 12:59 PM   #4
xxscaxx
Drives: 2013 SWP BRZ
you should use a cotter pin instead of the paperclip
xxscaxx is offline   Reply With Quote
Old 07-10-2014, 08:18 PM   #5
11RApearl
Drives: Scion FR-S
I used 3M double sided tape (left over from my 5axis spoiler) to get the top to stay pushed in on one of mine and it works perfectly. I've had it on there more than a year now. No drilling required for those of who don't want to drill.
11RApearl is offline   Reply With Quote
Old 07-11-2014, 09:15 AM   #6
Grip Ronin
The Mechanic
Grip Ronin's Avatar
thats a good idea. paperclips are just easier to come by sometimes, thats why i used it
i tried double sided tap last year it held for like a month but once it got alittle dirty it kept falling out, you must have found a better location then me lol.
IG-Joey_Soul
Old 07-11-2014, 09:36 AM   #7
thunderlights
ive been driving around with a loose sidemarker for the past 8000kms. Thank you a lot for this!
thunderlights is offline   Reply With Quote
Old 07-18-2014, 10:53 AM   #8
11RApearl
Drives: Scion FR-S
i tried double sided tap last year it held for like a month but once it got alittle dirty it kept falling out, you must have found a better location then me lol.[/QUOTE]
I dont remember exactly where i put it but i believe i did it in two spots, it was the top clip that wouldn't stay in. I put one strip down along the top around where the clip is and then put another layer on top of that one because it didn't have enough thickness with one. Did you just use one layer of 3M tape? Then i believe i put another 2 layers along the inside of the front of the clip (side closest to the front of the car).
Old 07-20-2014, 10:21 PM   #9
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i had two layers just to fill in the gap.
IG-Joey_Soul
Old 10-24-2014, 03:26 PM   #10
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I'll have to do this. Went through the car wash and this happened.
Bg8780 is offline   Reply With Quote
Old 10-30-2014, 06:17 PM   #11
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ouch.. these markers are a bad design. someone should make a delete for them
IG-Joey_Soul
Old 10-31-2014, 08:58 AM   #12
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
I started using 3m tape since mine are alwats coming off but i might try this now. 3m tape is super durable if it sticks on "right"
DavidBob is offline   Reply With Quote
Old 11-14-2014, 02:47 PM   #13
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i tried that first but it didnt hold. Theres too much water and rocks that kick up for tape to hold
IG-Joey_Soul
86 Sidemarker Question Justinyuen16 Cosmetic Modification (Interior/Exterior/Lighting) 13 05-24-2014 02:15 AM
Sidemarker and Sidemarker Light arm broken off while driving. CreinCrein Issues | Warranty | Recalls / TSB 4 05-20-2014 08:49 AM
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 05:59 PM
Quick Release or Quick Lock Steering Wheel and Theft defense too? 1086 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-24-2014 04:50 PM
Sidemarker Alternative OmarGC Cosmetic Modification (Interior/Exterior/Lighting) 15 06-21-2013 05:17 PM
