Old 07-17-2014, 09:08 PM   #43
Hawk77FT
Drives: GTS 86
Originally Posted by peri.Laynz View Post
I like the center intake vent for the sole purpose of forcing cool air into the engine bay so hot air gets forced out of the side vents.
I highly doubt the center vent is forcing the air to exit the side vents and if it does, it will need to happen at very high speeds. For something like that to happen you need a down/up pressure. The issue is relative pressure: air cannot flow into a space unless the air pressure inside is less than the air pressure outside. If too much air is allowed in, the pressure equalises the airflow. The end result is that the engine gets less cool air rather than more.The center vent will create more turbulence under the hood, with no considerable benefit. With that said however, most times exhaust vents alone improve performance better than an air scoop could.
I would rather stick to the vented ones, but each to their own. it looks good though
Hawk77FT is offline   Reply With Quote
Old 07-17-2014, 09:35 PM   #44
peri.Laynz
Drives: 2014 Whiteout M/T
Yeah I figured it may not perform quite how I wanted but it sounds really good in my head
peri.Laynz is offline   Reply With Quote
Old 07-17-2014, 09:51 PM   #45
plucas
plucas's Avatar
Drives: Subaru
I have a few facts on this.
1. Stock radiators are super efficient. Just because it is thin doesn't mean it doesn't work well.
2. All the radiators on the market aren't even half the quality of the factory unit (no offense to any vendor who makes one)
3. You do not need a thick radiator to cool these cars even with a lot of power and at the track. With a quality core, you don't need something super thick. A better core would be something still thin (27mm for example) with a good fin height and fin pitch.
Not knocking on anything out there, just want to inform people of the facts. This comes from my experience engineering radiators and oil coolers for racing and custom applications.
plucas is offline   Reply With Quote
The Following 2 Users Say Thank You to plucas For This Useful Post:
Hawk77FT (10-21-2014), sroby (10-18-2020)
Old 07-17-2014, 09:53 PM   #46
mike the snake
A general rule for venting for aircraft cowlings is you want the outlet vent areas to be at least 2X the inlet size, this gives the needed air exchange.
If we focus on more exhaust venting (vented hood, skidplate mod, fender garnish vents) then the needed air will make it's way through the front grill.
The Following User Says Thank You to mike the snake For This Useful Post:
plucas (07-17-2014)
Old 07-17-2014, 10:19 PM   #47
BadBRZ
Drives: Subaru
We dont need it through the "grill" we need it through the radiator!!!
BadBRZ is offline   Reply With Quote
Old 07-17-2014, 10:54 PM   #48
mike the snake
Grill=radiator=front opening=inlet
If the air dams are in place, the air is going through the radiator.
Without enough exhaust venting area, the air won't enter through the radiator well enough.
plucas (07-17-2014)
Old 07-18-2014, 12:06 AM   #49
jflogerzi
jflogerzi's Avatar
For NA you don't need a new radiator. Much better spending money on an oil cooler.
FBM Dual Pass Radiators FullBlown Forced Induction 23 05-31-2017 01:15 AM
Mishimoto BRZ/FRS Radiators now at MAPerformance! MAPerformance Engine, Exhaust, Bolt-Ons 36 04-27-2016 06:45 PM
FBM Performance Aluminum Radiators FullBlown Engine, Exhaust, Bolt-Ons 2 12-19-2013 04:47 PM
PTUNING FR-S/BRZ Koyo Radiators Now Available! Ken@PTuning Engine, Exhaust, Bolt-Ons 0 07-30-2013 10:58 AM
FBM Performance Aluminum Radiators FullBlown Forced Induction 121 06-17-2013 08:23 PM
