Old 07-15-2014, 08:41 PM   #57
kincaid0890
Drives: 2014 FR-S
Originally Posted by B-R-Z View Post
I've read that's just a temporary fix to trick the ECU, which I don't like too much either. I guess it's not worth it to get this header if I just want the boxer rumble.
Then do what everyone else is telling you to do get a catted header an your problem is solved
kincaid0890 is offline   Reply With Quote
Old 07-15-2014, 10:15 PM   #58
DriftHappens
Drives: '14 FRS White
don't mind the dirt...it rained last night...
DriftHappens is offline   Reply With Quote
Old 07-15-2014, 10:47 PM   #59
invaliduser
Drives: 2017 86
Drift... What is the rest of your exhaust setup?
Sent from my HTC One_M8 using Tapatalk
invaliduser is offline   Reply With Quote
Old 07-15-2014, 11:05 PM   #60
DriftHappens
all tsudo minus the overpipe (which is a DC...poor decision on that i might add)
Old 07-16-2014, 06:53 PM   #61
chimmy
Because BOXER
chimmy's Avatar
Drives: Asphalt FR-S
Are there any other ways to fix a CEL besides a flash? I'm not looking to get a few hp for $500-$1000, all I want is no CEL.
If you still have the factory front pipe with cat on it, you can do what I've done...
Buy this o2 harness extension, it plug fits perfectly to ours [yes, the secondary o2]
http://www.casperselectronics.com/st...oducts_id=1395
Then either buy an o2 bung and weld it to your front pipe after the cat OR have an exhaust shop do it. I did my own, fits perfectly right after the cat, in between the transmission and tunnel. Install your secondary o2 in new position.
I installed the primary o2 in to the position where the secondary would go and bolted in a plug in the other spot. I did this so the primary o2 is getting readings from ALL cylinders and not just one [just like it is on the factory header].
5k miles down, no CEL. Tried the o2 spacer that speedfactory sells, got a CEL with in 200 miles everytime using ALL the inserts. Cheaper than a tune, and plenty rumbles.
chimmy is offline   Reply With Quote
The Following User Says Thank You to chimmy For This Useful Post:
B-R-Z (07-16-2014)
Old 07-16-2014, 10:04 PM   #62
kincaid0890
Drives: 2014 FR-S
Do you have a pic of where you put the 02 bung on the front pipe?
Old 07-16-2014, 10:08 PM   #63
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
So the muffler shop will need to drill a hole into the factory front pipe after the secondary cat? Do I need any other hardware besides extension wire and bung? Where can I get a bung and how long of an extension wire did u get?
And so I get this straight, I am basically arranging the sensors as they are on the primary cat, one before and one after, except on the secondary cat once the new header is in.
The primary after-cat sensor goes after the secondary cat (need a muffler shop to do this), and the primary before-cat sensor goes in the primary after-cat sensor hole which is in place to be before the secondary before-cat location.
How long has this worked successfully for you? No CEL ever with this method? I've heard there's people that use a catted header and still get a CEL so this car seems sensitive.
B-R-Z is offline   Reply With Quote
Old 07-17-2014, 05:58 PM   #64
chimmy
Because BOXER
chimmy's Avatar
I got a 3' extension. I did mine myself. Have driven a tad over 5k miles so far and no CEL. I would think the muffler shop would have o2 bungs, but I don't know for sure. I ordered mine from Amazon.
BUT, I've also read instances where people have used a spacer and haven't gotten a CEL, or used a mini-cat spacer. Those didn't work for me. The only UEL that has a cat that I know of would be Speed-Factory's. They are also using a high flow cat, might explain why they still get a CEL.
New secondary o2 sensor location after secondary cat.
New primary o2 sensor location, in the old secondary o2 port.
Old primary o2 location now plugged.
How its arranged at the harness plugs.
I did it the way I did it to 1. Keep the secondary o2 directly in the exhaust stream. 2. Have the primary o2 get exhaust readings from all four cylinders and not just one. 3. Im sorry to those who find it worth it, but 500 bucks isnt worth 12whp. If I was so worried about getting tiny bits of more power, I wouldn't have gotten this car.
B-R-Z (07-17-2014)
Old 07-17-2014, 06:34 PM   #65
B-R-Z
B-R-Z's Avatar
Thanks for your info and pics chimmy, I might actually get this header now..
So the only parts I need are [1] Uncatted UEL header, [1] 3' extension cable and [1] o2 bung.
Can you give me a link to the o2 bung you used?
What did you use to plug up the old primary o2 hole?
Why does the pic say you moved over the o2 harness, doesnt the extension just extend it from the same spot?
Old 07-17-2014, 06:41 PM   #66
chimmy
Because BOXER
chimmy's Avatar
I used this one, comes with a plug.
[ame="http://www.amazon.com/Bung-Plug-most-Conventional-Sensors/dp/B00FB352HM/ref=sr_1_24?ie=UTF8&qid=1405636739&sr=8-24&keywords=o2+bung+and+plug"]Amazon.com: O2 Bung Plug for most Conventional O2 Sensors: Automotive[/ame]
I only purchased one 3' harness extension. I DID however, had to give the primary wire harness a good tug to pull it over in to its new position. I'm not saying you HAVE to move the primary, but to me, it just makes more sense.
Old 07-17-2014, 07:35 PM   #67
B-R-Z
B-R-Z's Avatar
Did you see any impact on fuel economy after doing this?
The Following User Says Thank You to B-R-Z For This Useful Post:
Four_wheel_drifts (07-03-2018)
Old 07-17-2014, 07:37 PM   #68
chimmy
Because BOXER
chimmy's Avatar
None at all really. Still averaging 29-31mpg about 50/50 mix city and hwy.
Old 07-18-2014, 01:59 AM   #69
akahenry
akahenry's Avatar
Drives: '18 STi
still no sound clips? dafaq
akahenry is offline   Reply With Quote
Old 07-18-2014, 06:52 AM   #70
kincaid0890
Drives: 2014 FR-S
there is 2 sound clips on page 2 and 1 on page 3
Tsudo Header and Overpipe boredom.is.me Engine, Exhaust, Transmission 70 11-04-2014 01:14 AM
For sale: Tsudo UEL header jupillam Engine, Exhaust, Bolt-Ons 10 07-08-2014 12:40 PM
Anyone have the Tsudo header? Iam-Naimless Engine, Exhaust, Transmission 8 07-02-2014 01:55 PM
New Tsudo UEL header Fast_Freddy Engine, Exhaust, Transmission 1 05-11-2014 01:33 AM
Tsudo Header ML Engine, Exhaust, Transmission 7 01-11-2014 01:31 PM
