Old 07-17-2014, 01:52 PM   #29
The Slow One
Track Junkie
Drives: Argento Scion FR-S
I noticed for the brake lines you have to pick between the S13 and S14, which one did you go with?
The Slow One is offline   Reply With Quote
Old 07-17-2014, 02:37 PM   #30
mike the snake
So, since this brake swap is regarding the 300zx calipers which are the same as the WRX calipers, are you saying that doing this swap will not be good?
If this swap does shift the bias rearward, would also going with the WRX rears fix this?
What about running the 300zx calipers with some grippier pads compared to the rear?
The WRX 4 pots suck. Not saying these are comparable but the WRX setup shifts bias towards the back.
You may have meant the STI full setup though
Old 07-17-2014, 03:00 PM   #31
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
The Z32 brakes were good...better than the Z31.
But seriously?
Alright...should be interesting to watch this unfold.
Old 07-17-2014, 03:06 PM   #32
mike the snake
Please, speak up.
I'd like to know everything I can before I jump on this. If there's no real improvement over stock with fluid/pads/SS lines I'd like to know.
But seriously?
Old 07-17-2014, 03:20 PM   #33
dem00n
dem00n's Avatar
Drives: Scion FRS
Originally Posted by mike the snake View Post
Please, speak up.
I'm no expert on the Z32 brakes since i own a Z31. I do know that at one point they changed the brake calipers from aluminum to iron due to heating issues.
But these brakes were engineered 20 years ago, more so 25 years ago. In turth, they are somewhat similar to the Z31 design (front only), in fact it's a common mod to change the front brakes of a Z31 to that of a Z32.
If you guys wanna run brakes from a grand touring car, go ahead. They are meant for a 3100 lb+ grand tourer, so perhaps they are more powerful then our stock brakes. But how will our master cylinder react? I don't know...and personally wouldn't wanna risk it.
Old 07-17-2014, 03:55 PM   #34
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
I got the S14 lines. Good question and thanks for bringing that up.
eikond is offline   Reply With Quote
Old 07-17-2014, 04:33 PM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Are they the same piston sizes? If so, why are adapters made for them to fit a WRX (honest question, doesn't make much sense if they are the same as the WRX ones)? The WRX four pots have less piston area than our OEM calipers, so given the same rear setup (we have LGT rears stock which are bigger than the WRX rears), brake bias will move further back.
If these are the same as WRX, then why run them at all? I'd rather run LGT sliders up front with the LGT rotors instead. The only benefit you'd get is brake feel out of fixed calipers.
I went from curious to maybe against this setup if the piston sizes really are WRX 4 pot sized.
Also, what problem are you trying to fix? If it's heatsink related that's one thing, but this won't increase stopping force. Bias issues are slightly less important now with these too smart ABS systems but too much brake torque on one end can still be an issue, especially if you progress to driving without ABS...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-17-2014, 04:35 PM   #36
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Even designed 20 years ago they are just calipers. Caliper design has changed in terms of strength, materials, weight, etc but the basic design and function likely hasn't changed a great deal.
Our current brakes are from a heavy arse station wagon up front and a heavy arse family sedan in the rear. :shrug:
MC is a valid question, goes back to the piston area.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-17-2014, 04:36 PM   #37
mike the snake
Not trying to fix anything. Just interested in a cheaper alternative if there's performance to gain.
Lookie what I found!
http://forums.nicoclub.com/akebono-1...s-t545946.html
It looks like the Q45 brakes also swap, and might be a better choice for our cars. Apparently they have 25% more braking force, so they might not cause the rearward bias.
http://www.ka24development.com/brake_upgrades.html
Old 07-17-2014, 04:52 PM   #38
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Any bias shift (in either direction) can cause a change in braking. Often, it's longer (not shorter) stopping distances.
If by performance you mean stopping distances, buy stickier tires and move on since the OEM brakes are capable of locking up with R compounds and decent pads.
The only functional reason (outside of feel) to run big brakes is if you need a larger heatsink for repeated high speed braking (ie track use with a fast enough car and driver to fade sintered pads) and to remove unsprung weight, but that's only a benefit IMO if you don't change something else negatively.
Plenty of other reasons for a BBK that are less functional, but you have to pick carefully to benefit. These reasons can include pad choice, pad expense, pad lifespan, rotor expense and rotor lifespan. I run different brakes up front partially for heat reasons when I was tracking the car often and for consumables cost. Pads last so much longer in my setup and are cheaper than the OEM size so over time it pays for itself - IF you track the car a lot.
Most people upgrade brakes for looks, which is fine, but it's worth mentioning that sometimes those upgrades are downgrades functionally...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-17-2014, 04:55 PM   #39
Racecomp Engineering
nm
Old 07-17-2014, 04:58 PM   #40
JasperNoone
Drives: Car
IIRC it was a caliper flexing issue, not heat.
JasperNoone is offline   Reply With Quote
Old 07-17-2014, 05:04 PM   #41
mike the snake
Piston sizes I believe are 30mm.
If the piston area is smaller like it is with suby 4 pots, you are still adding a larger diameter rotor with the LGT rotor. So the brake bias point may be moot. Maybe.
I dunno what the piston sizes are on the Z32 calipers so whatever.
- Andy
Old 07-17-2014, 05:08 PM   #42
eikond
eikond's Avatar
I'll state again for the record that I am not an engineer.. physics was not my strong suit in school. So I'm learning all of this as I go.
I haven't had enough time in the car to determine how much I like the new brakes. I certainly haven't driven it on the track yet.. I've literally driven it like 30 miles.
I will say that during the bedding process it felt like they had more grip and really helped slow the car down faster. But, that was also in a straight line.. So I couldn't feel much in terms of brake bias.
Dave: Where did you read that WRX 4-pots suck? Have you tried them? I've read one review on this forum where the guy said he loved them. Where did you hear that they move the bias toward the rear?
Here's my math:
The stock BRZ calipers have 48mm pistons
if my high school geometry is correct, that would make for a radius of 24mm. Pi x R ^2 = 1810 x 2 pistons = 3620
The Z32 calipers have 40.45mm pistons
same math gets me 1282 x 4 pistons = 5127
So, in theory the Z32 caliper should inpute more clamping force right? So I'm not sure why that would result in moving the brake bias toward the rear?
Again, i'm not a physics expert..
One thing I noticed is that the Z32 pads are slightly smaller surface area than the BRZ stock pads. I don't know how much smaller though.
Does a larger pad surface area increase stopping ability? It seems logical that it would.. but I'm not sure about that.
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
