#29 |
Track Junkie
Drives: Argento Scion FR-S
I noticed for the brake lines you have to pick between the S13 and S14, which one did you go with?
#30 |
So, since this brake swap is regarding the 300zx calipers which are the same as the WRX calipers, are you saying that doing this swap will not be good?
If this swap does shift the bias rearward, would also going with the WRX rears fix this? What about running the 300zx calipers with some grippier pads compared to the rear? |
#31 |
Member of the year - 2016
Drives: Scion FRS
The Z32 brakes were good...better than the Z31.
But seriously? Alright...should be interesting to watch this unfold.
#32 |
Please, speak up.
I'd like to know everything I can before I jump on this. If there's no real improvement over stock with fluid/pads/SS lines I'd like to know. |
#33 | |
Drives: Scion FRS
But these brakes were engineered 20 years ago, more so 25 years ago. In turth, they are somewhat similar to the Z31 design (front only), in fact it's a common mod to change the front brakes of a Z31 to that of a Z32. If you guys wanna run brakes from a grand touring car, go ahead. They are meant for a 3100 lb+ grand tourer, so perhaps they are more powerful then our stock brakes. But how will our master cylinder react? I don't know...and personally wouldn't wanna risk it.
#34 |
Wish Nissan made one
Drives: '13 WRB BRZ Premium
The Following 2 Users Say Thank You to eikond For This Useful Post: | hmong337 (08-27-2014), The Slow One (07-17-2014) |
#35 | |
Site Moderator
Drives: Stuff
Are they the same piston sizes? If so, why are adapters made for them to fit a WRX (honest question, doesn't make much sense if they are the same as the WRX ones)? The WRX four pots have less piston area than our OEM calipers, so given the same rear setup (we have LGT rears stock which are bigger than the WRX rears), brake bias will move further back. If these are the same as WRX, then why run them at all? I'd rather run LGT sliders up front with the LGT rotors instead. The only benefit you'd get is brake feel out of fixed calipers. I went from curious to maybe against this setup if the piston sizes really are WRX 4 pot sized. Also, what problem are you trying to fix? If it's heatsink related that's one thing, but this won't increase stopping force. Bias issues are slightly less important now with these too smart ABS systems but too much brake torque on one end can still be an issue, especially if you progress to driving without ABS...
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#36 | |
Site Moderator
Drives: Stuff
Even designed 20 years ago they are just calipers. Caliper design has changed in terms of strength, materials, weight, etc but the basic design and function likely hasn't changed a great deal. Our current brakes are from a heavy arse station wagon up front and a heavy arse family sedan in the rear. :shrug: MC is a valid question, goes back to the piston area.
-Dave
#37 |
Not trying to fix anything. Just interested in a cheaper alternative if there's performance to gain.
Lookie what I found! http://forums.nicoclub.com/akebono-1...s-t545946.html It looks like the Q45 brakes also swap, and might be a better choice for our cars. Apparently they have 25% more braking force, so they might not cause the rearward bias. http://www.ka24development.com/brake_upgrades.html |
#38 | |
Site Moderator
Drives: Stuff
If by performance you mean stopping distances, buy stickier tires and move on since the OEM brakes are capable of locking up with R compounds and decent pads. The only functional reason (outside of feel) to run big brakes is if you need a larger heatsink for repeated high speed braking (ie track use with a fast enough car and driver to fade sintered pads) and to remove unsprung weight, but that's only a benefit IMO if you don't change something else negatively. Plenty of other reasons for a BBK that are less functional, but you have to pick carefully to benefit. These reasons can include pad choice, pad expense, pad lifespan, rotor expense and rotor lifespan. I run different brakes up front partially for heat reasons when I was tracking the car often and for consumables cost. Pads last so much longer in my setup and are cheaper than the OEM size so over time it pays for itself - IF you track the car a lot. Most people upgrade brakes for looks, which is fine, but it's worth mentioning that sometimes those upgrades are downgrades functionally...
-Dave
The Following User Says Thank You to Dave-ROR For This Useful Post: | JRitt (07-18-2014) |
#39 |
nm
#41 |
Piston sizes I believe are 30mm.
#42 | |
I'll state again for the record that I am not an engineer.. physics was not my strong suit in school. So I'm learning all of this as I go. I haven't had enough time in the car to determine how much I like the new brakes. I certainly haven't driven it on the track yet.. I've literally driven it like 30 miles. I will say that during the bedding process it felt like they had more grip and really helped slow the car down faster. But, that was also in a straight line.. So I couldn't feel much in terms of brake bias. Dave: Where did you read that WRX 4-pots suck? Have you tried them? I've read one review on this forum where the guy said he loved them. Where did you hear that they move the bias toward the rear? Here's my math: The stock BRZ calipers have 48mm pistons if my high school geometry is correct, that would make for a radius of 24mm. Pi x R ^2 = 1810 x 2 pistons = 3620 The Z32 calipers have 40.45mm pistons same math gets me 1282 x 4 pistons = 5127 So, in theory the Z32 caliper should inpute more clamping force right? So I'm not sure why that would result in moving the brake bias toward the rear? Again, i'm not a physics expert.. One thing I noticed is that the Z32 pads are slightly smaller surface area than the BRZ stock pads. I don't know how much smaller though. Does a larger pad surface area increase stopping ability? It seems logical that it would.. but I'm not sure about that. |
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 12:29 PM |
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
