Old 07-17-2014, 08:18 AM   #2059
hattrickey
Drives: Scion FR-S
Originally Posted by teamxplizt View Post
Here are some minor sound clips I made today. Will work on drive by and in cabin sound clips in a bit.
Nice! I see you have the Perrin exhaust. Any other mods? I have full Perrin header back exhaust so I'm trying to get a feel of what mine will sound like when I get it next week.
hattrickey is offline
Old 07-17-2014, 02:54 PM   #2060
teamxplizt
teamxplizt's Avatar
Drives: Seibon Style BRZ
Not much modifications just yet. Still trying to feel out the Subaru market for reputable performance upgrades. So far, I have instilled a great deal of trust in Perrin products. I have a 3" Perrin catback exhaust "Resonated", Perrin CAI, and FT86 UEL catted headers. I am a Honda/Acura enthusiast and pretty much know all of the parts to stay away from and the ones to invest in...I am taking my time with this Subaru build, and I think the magic horsepower number is around 350ish. Thanks for looking and I will be sure to post additional sound clip videos when I get a chance.
Aloha,
Ace
http://66.230.196.147/*teamxplizt.org/httpdocs/images/TXP_BRZ.jpg
teamxplizt is offline
The Following User Says Thank You to teamxplizt For This Useful Post:
hattrickey (07-17-2014)
Old 07-18-2014, 11:39 AM   #2061
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
So just to be totally clear, you DO NOT need a tune with these headers? I can run the for the life of the car with the stock tune and not have to worry?
TONYpepperon1 is offline
Old 07-18-2014, 01:31 PM   #2062
SCharged
Drives: asphalt fr-s
There have been rare occurences of check engine lights coming on for a couple of adopters of theses.. Not yet determined what caused the issue, could very well be an install issue. I think there has been two of those on the forum.
But to answer your question, yes, you may run this for the life of the car witout a tune. Your AFR may be slightly on the rich side, which is not a problem in and of itself.
Anyone care to talk about risks of running rich?? maybe carbon buildup?? or is it the other way around?
SCharged is offline
The Following User Says Thank You to SCharged For This Useful Post:
TONYpepperon1 (07-19-2014)
Old 07-18-2014, 05:16 PM   #2063
Trettiosjuan
Drives: GT86
Had the impression that it was the other way around, a little lean.
With no other mods the header can be run without a tune as per first post. Add other modifications and it becomes more complicated as it is difficult to say anything firm with all the possible combinations...
Trettiosjuan is offline
Old 07-18-2014, 05:24 PM   #2064
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Too rich - carbon buildup, an O2 sensor may go out earlier, reduced MPG
Too lean - higher risk of pre-detonation (knock)
I'd have figured it'd be leaner as well.
Jyn is offline
Old 07-18-2014, 07:40 PM   #2065
hattrickey
Drives: Scion FR-S
Correct. On post #1895, FT86 Speed Factory had this response to a guy who threw a code because he was running lean. "A P2096 is typically be caused by too many mods without a tune IE intake, full exhaust and etc. Too much air and not enough fuel.
The testing and dynos done were done on a stock car with only the header changed in which everything works great. The CEL that this header should not cause after doing our testing is p0420 which is the one relating to the cat itself.
If you have a heavily modified car with full exhaust, intake, and etc a tune should be something to look into. You will extract even more power and resolve the lack of fuel in certain driving situations."
Based off of this advice, I will be getting a tune.
The Following User Says Thank You to hattrickey For This Useful Post:
Trettiosjuan (07-19-2014)
Old 07-21-2014, 05:41 AM   #2066
chas3wba0
chas3wba0's Avatar
Drives: Yes
Ran both OFT Stage 1 and Stage 2 this weekend... it felt less torquey running Stage 2. I ended up flashing back to Stage 1 and it feels better (according to butt dyno).
Header-back exhaust only (catted header, catless FP), stock intake with Perrin tube.
Here's a shoddy log on Stage 2 from today... was just testing out the logging feature so not sure if the data's any good. Hopefully someone can interpret it better than I can.
http://www.datazap.me/u/chas3wba0/st...g=0&data=1-2-9
Will do a log for Stage 1 this week. What's the best way to log? Cruise for a bit then a WOT run?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
The Following User Says Thank You to chas3wba0 For This Useful Post:
kodyo (07-21-2014)
Old 07-21-2014, 06:09 PM   #2067
kodyo
Drives: Scion FR-S
Did tune improve over stock performance with the FT86SF header at all (either stage 1 or stage 2)?
I plan to go with OFT if I get a CEL after install.
kodyo is offline
Old 07-21-2014, 06:27 PM   #2068
chas3wba0
chas3wba0's Avatar
Drives: Yes
Did not test with stock map, as I was already running Stage 1 before I installed the header. OFT Stage 1 was a world of difference from stock (smoother idle and revs, more linear power curve) so I would recommend it whether you get a CEL or not.
The Following 2 Users Say Thank You to chas3wba0 For This Useful Post:
CamryDS (07-31-2014), kodyo (07-21-2014)
Old 07-21-2014, 06:41 PM   #2069
kodyo
Drives: Scion FR-S
Ah, ok. I assume at the very least you noticed a decent power gain with the new header over the stock header on stage 1?
If I can find a good price on an OFT, I may go for it.
kodyo is offline
Old 07-21-2014, 06:59 PM   #2070
chas3wba0
chas3wba0's Avatar
Drives: Yes
Tough to say without getting dyno'd. The graphs on the first post show something like a 6hp gain up top, but even that's hard to tell on a butt dyno alone. Not to mention I had a bunch of other exhaust bits + tune installed already, so I likely already got used to the extra torque/power from those.
I would say the most noticeable things from the header are throttle response, rev-happiness, and SOUND
Edit: I take it back. After a few experiments on freeway on-ramps, the car definitely pulls harder up top as well
kodyo (07-21-2014)
Old 07-21-2014, 07:01 PM   #2071
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
When I installl mine, I'll post the dyno for the new header design. Problem is, I'm not installing til next season. But doesn't look like anyone else is posting dynos for the new ones.
tahdizzle is offline
Old 07-21-2014, 07:19 PM   #2072
Luis_GT
if mine ships this week, I'll have a dyno sheet next week, or the week after.
Luis_GT is offline
The Following 2 Users Say Thank You to Luis_GT For This Useful Post:
tahdizzle (07-21-2014), Turkish (07-24-2014)
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
