Old 07-15-2014, 02:44 PM   #43
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by 69Marshall69 View Post
King Tut if you wouldn't mind showing me a picture of the washers, im going to try and find some tomorrow or machine the proper size (how many did you end up using and what was you vacuum levels at max and idle) thanks!
Here you go bud:
http://www.mcmaster.com/#92661a751/
In nice light weight aluminum as well:
ID 1"
OD 1 1/2"
0.063" Thick (±0.004")
69Marshall69 (07-16-2014)
Old 07-16-2014, 12:44 PM   #44
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
I machined a spacer that seems to be doing the trick tomorrow im getting a tune from Delicious Tuning. I just was wondering how many washers did you end up using to correct the BOV
69Marshall69 is offline   Reply With Quote
Old 07-16-2014, 01:07 PM   #45
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I think I went with two.
Old 07-16-2014, 03:26 PM   #46
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I have an 11psi spring in mine now and it gets some surge at low rpm/low boost. With anything less than the 11psi spring the bov stays open at idle. I may try to shim mine or go with the softer spring and a few washers.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 07-16-2014, 03:45 PM   #47
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It is a real popular technique with the WRX/STI guys even though most use the OEM draw thru MAF so this shouldn't be an issue. I think they like going with a 10 psi and washers normally. I really wouldn't worry about some surge and low rpm/low boost.
Old 07-16-2014, 06:38 PM   #48
evo4g63
evo4g63's Avatar
I agree with you. Low rpm/boost it should be fine. I figure I would play with the bov and see what I may like better.
-2016 Subaru WRX
Bleeder valves CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 06-15-2022 11:38 PM
XXR 527 18X8.75 35 OFFSET - GOLD FINISH - BLOW-OUT-PRICES!!~!~! MIKE@MRTIRESOLUTIONS Wheels and Tires 1 12-12-2012 12:57 PM
Volk Racing/Gram Lights blow out sale Stav Canada Classifieds 9 11-30-2012 04:40 PM
***CUSCO COILOVERS BLOW OUT PRICING*** genometuning Brakes, Suspension, Chassis 11 10-23-2012 05:54 PM
