Old 07-14-2014, 02:26 AM   #183
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by SilverlightPony View Post
Now I just have to decide if I want to attempt installation myself or get some professionals to handle it. :/
Personally I didn't think it was that hard as long as you have the tools. The instructions were pretty good and most difficult part is removing panels. I even did my reference upgrade without instructions (early batch lol).
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-16-2014, 04:02 PM   #184
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Did anyone else who did the installation themselves have trouble getting the green snap connectors behind the driver's kickpanel to release from the body of the car so you could put them back on the panel? I can't get the damn things loose.
SilverlightPony is offline   Reply With Quote
Old 07-16-2014, 07:35 PM   #185
tiny41
Drives: Subaru BRZ Limited
Use automotive trim tools. Cheap ones are around 10-20 dollars.
They're basically mini pry bars for any plastic trims in your car.
tiny41 is offline   Reply With Quote
The Following User Says Thank You to tiny41 For This Useful Post:
oemaudioplus (07-16-2014)
Old 07-16-2014, 07:37 PM   #186
oemaudioplus
oemaudioplus's Avatar
Drives: http://bit.ly/Vantage86
@SilverlightPony
In the absence of a panel clip tool:
You can use your crimp tool to get a grip on the green locking tab and pull away from the vehicle.
Update us on whether or not either of these help. Other then those clips how's the install going?
oemaudioplus is offline   Reply With Quote
Old 07-16-2014, 08:30 PM   #187
SilverlightPony
I have a set of plastic trim panel tools, they weren't working. A friend brought over a metal one that got the job done.
Now we have a new problem: I got the system installed, but I'm not getting any sound.I've checked all the connections and everything looks good, but still no luck.
Mind you, I have a Ca-Fi Dashlinq4 head unit rather than the stock HU.
Old 07-16-2014, 08:32 PM   #188
oemaudioplus
@SilverlightPony give us a call at 855-636-6346 x4
Old 07-16-2014, 08:58 PM   #189
SilverlightPony
Call dropped, but it's working now. Thanks guys!
The Following User Says Thank You to SilverlightPony For This Useful Post:
Old 07-16-2014, 10:33 PM   #190
SilverlightPony
For anyone who's wondering, I had the blue/white Amp Pwr On wire from the HU (which, on the Dashlinq4, is not hooked to a plug, but left loose, to be tapped/spliced into the appropriate harness wire) tapped into the wrong wire. Got that sorted, and it fired right up!
Old 07-22-2014, 04:39 AM   #191
SilverlightPony
Sad to report one minor issue: intermittent crackling from the right front tweeter. Percussive maintenance (smacking the dashboard) "solves" it temporarily. I'll be popping it out to check the plug connection tomorrow afternoon.
Old 07-24-2014, 02:19 AM   #192
ericmpena
ericmpena's Avatar
Just had my OEM Audio Reference installed today. So far it's a little disappointing. I think the company who installed it must have messed something up because the entire audio system sounds very weak and the subwoofer is not working.
I can get decent sound from the tweeters and the door speakers, however the BRZ volume must be set to about 40-45 in order to get an average sound. Anything in the 30's will sound like background music that sounds close to the stock system's volume of 15-20.
I'll be taking my car back to the installer tomorrow and having them check the system out again. I highly doubt that the issue is with the OEM Audio system itself. So many good reviews could not possibly be towards what I'm hearing in my car.
I'm hoping the installer finds the issue and can fix it without me having to pull it out and do a warranty claim. I'll update tomorrow.
FYI: With the fade set all the way to rear all I can hear is weak back seat speakers and absolutely zero subwoofer. I know that the rear seat speakers are still factory so I don't see any reason why those should sound weak as well, unless it's some installation error.
ericmpena is offline   Reply With Quote
Old 07-24-2014, 02:33 AM   #193
oemaudioplus
@SilverlightPony, please keep us updated on this thread or via PM regarding your situation. We want to ensure nothing interrupts your listening experience.
The Following User Says Thank You to oemaudioplus For This Useful Post:
SilverlightPony (07-24-2014)
Old 07-24-2014, 02:39 AM   #194
oemaudioplus
@ericmpena, thank you for providing this update on your install. Agreed, it sounds like something is not installed correctly. Our System Integration team will contact you first thing in the morning (PDT) to further gather feedback regarding what you are experiencing.
Ensuring you experience the O+ signature sound is our top priority and we'll do everything in our power to ensure this process is expedited. Typically we can assess what's going on in the course of a call.
We'll be in touch in the morning. Let us know if anything between now and then.
The Following 2 Users Say Thank You to oemaudioplus For This Useful Post:
ericmpena (07-24-2014), Fastbrew (07-24-2014)
Old 07-24-2014, 07:13 PM   #195
SilverlightPony
I checked the connection and it didn't seem to be loose. To be on the safe side, I swapped the tweeters with each other and made sure the connections were firmly seated. Crackling hasn't returned yet, but I've only driven it for the short commute to work since. Will monitor over the next week or so and keep you posted.
oemaudioplus (07-24-2014)
Old 07-24-2014, 11:24 PM   #196
ericmpena
ericmpena's Avatar
Thanks to OEM Audio for being very quick to respond to my issue. Unfortunately we're still trying to figure out what's going on with my system.
I received a decibel test track as well as a bass test track from OEM Audio. With my stereo set at 30 I was getting 69db from the driver seat. Eq was flat and fade was centered. I got the same peak db of 69 the 3 times that I ran the test.
As for the subwoofer, playing their bass tester track proved that the subwoofer appears to be working properly. The bass was very solid during that test track. The only problem is that unless I'm listening to a bass tester track...the rest of my music sounds very thin.
I took my car to the installer and they verified that they've connected everything correctly as well.
Well, now I have a new issue. As I was driving home today from work my Nav has started shutting itself off every few minutes. Here's a video of what's happening now: [ame="https://www.youtube.com/watch?v=OMXOOZ5G3H0"]BRZ Nav shutting off randomly - YouTube[/ame]
Could it be that there is just a lack of power somewhere that could be making the subwoofer weak and now causing the Nav to shut down? I don't think it's a loose cable because even going over speed bumps harshly I was unable to trigger the shut down of the Nav. It shut down mainly on the highway with smooth driving. I'm going to take my car to the installer one more time tomorrow to see if they can resolve this new issue and triple check all connections.
OEM Audio has been a huge help and although my issue hasn't been determined yet, I have extreme confidence that they will not leave me unsatisfied.
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
Perrin Pulley review? Invidia Q300 exhaust review? ScionFrsFan Engine, Exhaust, Transmission 4 12-10-2012 08:27 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
EVO magazine review of GT86/BRZ review out TheRoadWarrior Scion FR-S / Toyota 86 GT86 General Forum 6 01-05-2012 08:26 PM
AutoExpress BRZ Review - Follow up to the GT86 Review Zgrinch BRZ First-Gen (2012+) — General Topics 3 12-13-2011 08:03 AM
