Old 07-16-2014, 02:24 PM   #911
AVOturboworld
Illustration of the hose routing with our breather tank:
The left port on intake manifold is where the line goes to the OEM pcv - an upgraded pcv needs to be fitted in that line.
Old 07-16-2014, 02:31 PM   #912
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Yes, that is the PCV and you need to install a check valve to prevent pressurizing crank.
Based on Paul's reply as well I assume you meant the hose I pictured. I will look into acquiring and installing a check valve.
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 07-16-2014, 02:36 PM   #913
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, I meant the hose you pictured.
Old 07-16-2014, 03:54 PM   #914
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Personally, I would install the check valve in the hose that goes from the back of the intake manifold to the center of your Crawford AOS right under Perf part of Performance. Then you can leave the line going to the PCV alone.
Sportsguy83 (07-16-2014)
Old 07-16-2014, 04:10 PM   #915
Zenith/Nadir
Drives: 2013 GBS BRZ Limited
Exactly what I was trying to describe to him earlier. My question is where to put the oil reservoir breather. AVO's diagram does not show it, supporting my theory that they run it straight to the oil cap. Should I attempt to do something along those lines, or tee it into the crank breather the Crawford already uses as a drain back? Will that drain enough to support the overflow AVO is warning us about under extended high rpm conditions?
Zenith/Nadir is offline   Reply With Quote
Old 07-16-2014, 04:14 PM   #916
Sportsguy83
Drives: Limited BRZ
I second this.
I believe the reservior breather tees into the breather or PCV line?
Old 07-17-2014, 05:27 PM   #917
nataku
Negative Mass
nataku's Avatar
I can try. Something tells me that run is going to end up being made entirely of hose clamps. I don't know how big check valves usually are but it's only 5" of PCV hose sticking on to a couple of bungs that are probably 1" each.
Old 07-17-2014, 05:31 PM   #918
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
They're quite small, just make sure they're pointed with flow being allowed to go from PCV to Intake Manifold
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
nataku (07-17-2014)
Old 07-17-2014, 05:47 PM   #919
nataku
Negative Mass
nataku's Avatar
Is that the kinda thing my local auto parts store is gonna have lying around? Browsing the internet gives me all kinds of check valves unrelated to vacuum system in a car.
Old 07-17-2014, 05:55 PM   #920
protpibe
protpibe's Avatar
Depends on the auto parts store I guess lol. I just ordered it online because it's easier
http://www.ebay.ca/itm/3-8-10mm-One-...vxp=mtr&_uhb=1
nataku (07-17-2014)
Old 07-17-2014, 05:56 PM   #921
nataku
Negative Mass
nataku's Avatar
Thanks that helped me get the right keywords lol. The one way part was pretty mandatory.
Old 07-17-2014, 05:57 PM   #922
protpibe
protpibe's Avatar
I'm pretty sure 3/8" is the right size, you may want to double check before ordering
Old 07-17-2014, 05:58 PM   #923
nataku
Negative Mass
nataku's Avatar
When I picked up additional PCV hose at NAPA they said it was 1/2" when I showed them what came with the Crawford. With a tight clamp the 1/8" difference might not matter but I'll try to find 1/2" first.
Old 07-17-2014, 06:01 PM   #924
protpibe
protpibe's Avatar
I just ordered 2 of each to be on the safe side lol
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
