Old 07-15-2014, 12:50 PM   #29
Namuna
Namuna's Avatar
Originally Posted by Malt View Post
The OFT as delivered from Vishnu will auto detect your ECU CalID and load up the various stages available. As far as I know the crawford BPM map is still in beta and is NOT part of the maps that are auto generated.
Once you have done your initial scan of your ECU you will need to choose the appropriate map from the list of options to load on to your ECU. The OFT wont automatically choose the right one for you as it has no way of knowing what you have done to your car.
So the OFT gives you a list of tune files based on ECU CalID (not any kind of smart detection of stock/after-market add-ons), got it.
So then it's still a matter of trial-n-error to pick a tune file closest to your actual config, load it onto the ECU and test, then choose another that's close to your config, load THAT onto the ECR and test again...Repeat as necessary until you find the one that works best for you. Is that right?
Namuna is offline   Reply With Quote
Old 07-15-2014, 01:00 PM   #30
Malt
Drives: 2015 WRX
Sortof. It shouldn't be trial and error at all. The "stages" are pretty well defined by Shiv. There are different versions of the stage 2 maps based on if you have EL or UEL headers.
OTS Map Requirements:
Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel only.
Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel only.
Stage 1 tunes are for essentially stock vehicles with maybe a high flow panel filter.
Stage 2 are for vehicles with catless headers and there are UEL and EL map versions.
Stage 2 E85 tunes are for vehicles with catless headers and those running E85 ONLY and there are UEL and EL map versions.
Cat back exhausts/overpipes/front pipes dont really matter for the purposes of choosing maps.
The only exception to this rule is if you have a stock vehicle and plan on running E85 fuel, the Stage 2 E85 EL map has been tested as safe for stock vehicles. Just remember that you can ONLY run E85 with the E85 maps. If you need/want to swap back to 91 or 93 octane then you'll have to flash back to a non-E85 map.
All of this gets slightly more complicated once Shiv releases the v2.0 maps. Then there will also be 91 octane and 93 octane versions of each map.
So essentially you'll pick the one that matches your car and load that to your ECU and that's it.
EDIT:Just saw that you have Crawford BPB's. You'll have to download the beta map off http://openflashtablet.com/products/...ads/index.html for the BPB's and manually load up the map for that onto your OFT. Make sure you load the correct CalID and choose the correct fuel map. Then you'll flash that to your ECU.
Malt is offline   Reply With Quote
Old 07-16-2014, 09:02 AM   #31
Liebot
Liebot's Avatar
Is the OFT any different than how the COBB AP works? I loved the hell out of my AP.
Liebot is offline   Reply With Quote
Old 07-16-2014, 09:41 AM   #32
steve99
Drives: FT86
Never had a Cobb AP but looking at their web site
Probably pretty close, maybe missing a couple of features and screen not as hi res, but basicly same idea and same basic functionality
suggest you look at www.openflashtablet.com
Old 07-16-2014, 11:52 AM   #33
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Conceptually, the are the same. That is, a handheld device that doesn't require a laptop to flash your ECU and that can be uninstalled and then re-sold if needed. The differences boil down to details such as:
OFT provides unencrypted ROM format vs encrypted AP
OFT provides mode data display options (more channels simultaneously)
OFT is touchscreen vs AP buttons
If you like the AP, you will like the OFT
Cheers,
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 07-16-2014, 12:13 PM   #34
steve99
Drives: FT86
Cheers,
Shiv
+1000 on the unencrypted ROM's
anyhow back to work on V2.0 and stop posting
Old 07-16-2014, 10:09 PM   #35
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
Does the stage 1 map for stock vehicles increase the hp or torque at all? If so by how much?
FatFree is offline   Reply With Quote
Old 07-16-2014, 11:15 PM   #36
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Read this
http://www.ft86club.com/forums/showthread.php?t=29340
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 07-17-2014, 09:47 AM   #37
lucid215
i will be getting my oft today or tomorrow. from what i have heard from @shiv is i can run the stage 2 el since i have full exhast and intake bolt ons. i will run this map and watch to make sure everything is in line. once i recieve my headers i will be running the stage 2 uel map then switching to e85. cant wait
lucid215 is offline   Reply With Quote
Old 07-17-2014, 10:03 AM   #38
steve99
Drives: FT86
Untill you get your headers installed run the Stage 1 maps for Petrol
You can run Stage 2 E85 EL map with stock headers but only on E85
When you get headers you can run stage 2 petrol maps (EL oe UEL depending on headers)
see post by @Malt above http://www.ft86club.com/forums/showp...8&postcount=30
Old 07-17-2014, 10:05 AM   #39
raven1231
He said Shiv said it would be fine ??
Old 07-17-2014, 10:11 AM   #40
Malt
Drives: 2015 WRX
Not sure where he got that information but unless something has changed that I've missed, unless you are running E85 then the Stage 2 maps are strictly for cars with catless headers.
This isn't the first time I've seen people ask about running the stage 2 maps on cars with stock headers. Not sure why they would want to do so. The stage 1 maps offer a pretty nice bump in power and running stage 2 maps with stock headers and 91/93 octane doesn't sound like a smart idea to me. Then again, I've always erred on the side of caution. Personally I'd run the maps like they were intended to be ran and if I wanted more power I'd just buy what was recommended to run the more aggressively tuned maps. You're not going to get the claimed power output of the Stage 2 maps with that stock cat in place, so why risk it?
Old 07-17-2014, 10:13 AM   #41
steve99
Drives: FT86
If you have hi-flow main cat (front pipe) and stock headers its a bit of a toss up between stage1 and 2 maps , yes you could probably get away with stage 2 but probably safer on stage 1 map as it runs less timing advance than stg2 designed for catless headers. (Stage 1 also runns a bit less fuel up top as well, OL fuel table is a bit leaner))
But you would want to look for knock and check AFR at higher rpm if you want to try the stage 2 map with stock headers and hi flow cat. The remainder of the exhaust makes little difference to tuning
Old 07-17-2014, 10:18 AM   #42
raven1231
I agree with the both of you, just figured Shiv would know better than all of us is all. I would recommend running the stage 1 map as well, no point in risking detonation for a potential few hp difference.
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
VISHNU OpenFlash Tablet: Add Up To 20HP With Improved Drivability Garrett@Openflash Engine, Exhaust, Bolt-Ons 7 01-24-2014 01:33 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
FS: Vishnu OpenFlash Tablet - Unused, Mint Condition AyJay Engine, Exhaust, Bolt-Ons 6 11-09-2013 11:45 AM
