Old 07-15-2014, 05:07 PM   #617
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by kombatlion View Post
Thanks, I only want it to know an estimate, just to compare my gains.
We really prefer not to tune with methanol, as we have found the systems to be generally unreliable and cumbersome. The alternative we do offer is E85 tuning.
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
kombatlion (07-15-2014)
Old 07-15-2014, 07:11 PM   #618
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Sincerely,
Zach
Cool thanks, there is no e-85 in PR... but thanks for the info!
kombatlion is offline   Reply With Quote
The Following User Says Thank You to kombatlion For This Useful Post:
Old 07-16-2014, 01:17 AM   #619
Ethan
Drives: Subaru BRZ
Originally Posted by xjohnx View Post
Motor setup:
  • Innovate SC (with intercooler)
  • 70MM Pulley
  • FlexFuel (E71 or so in this video)
  • Nameless Performance Header/Overpipe/Downpipe/Axleback
  • Perrin 3" CAI
  • Perrin Oil Cooler
  • Stock Injectors, Stock MAP/MAF sensor.
  • ECUTek Tuned by @DeliciousTuning (8.59)
Xjohnx, sorry if this is a lame question, but are running the stock mid-pipe? I ask because I think Nameless said they saw no gains with replacing it. I am running Nameless too, but replaced the midpipe with a Worx's 2.5 inch pipe just because I am anal that way and wanted the diameters of the system to match. Also, how much louder is the nameless header over stock? I have the stock header still.
Ethan is offline   Reply With Quote
Old 07-16-2014, 09:40 AM   #620
xjohnx
Grip>Slip
xjohnx's Avatar
Stock midpipe. The nameless header is a good bit louder than stock, although with the stock axleback on, it sounds VERY quiet.
Old 07-23-2014, 10:12 AM   #621
acro
Drives: GT-86
Can you check your email/pm please
acro is offline   Reply With Quote
The Following User Says Thank You to acro For This Useful Post:
xxscaxx (07-23-2014)
Old 07-23-2014, 12:32 PM   #622
xxscaxx
Drives: 2013 SWP BRZ
Sent a bunch of emails over the last few weeks...still waiting for an updated tune (8.59) on my Innovate. Just figured i'd drop a message on here.
xxscaxx is offline   Reply With Quote
Old 07-24-2014, 04:36 PM   #623
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I recently put in an order with Delicious to update my tune to account for larger injectors and a 3 BAR map sensor. In the same order I also requested that a 4th map @ 15psi be added. Bill could of done everything at once, but instead suggested that we use the original tune to scale and tune the injectors/MAP so that we knew it was running correctly prior to upgrading. It was an "extra step" in the process, but a smart one. After a few flashes and logs, everything was 100%. Later that afternoon I had the newest revision of the SD tune with my new 15psi map. All in all, another good experience with @DeliciousTuning
As for the higher boost setting, holy crap. The car was a beast @ 10psi, but now it's even crazier. It fights for traction all the way through 2nd and then flies through 3rd like it does 2nd gear on the lower boost setting. I'll be putting it on the dyno next week to see actual numbers
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
onzippy (07-24-2014)
Old 07-24-2014, 06:47 PM   #624
onzippy
Drives: 2014 FRS
Originally Posted by protpibe View Post
... my new 15psi map.
I remember when you thought 11psi was a lot..
MORE POWER
It's addictive.
onzippy is offline   Reply With Quote
The Following User Says Thank You to onzippy For This Useful Post:
Old 07-24-2014, 10:09 PM   #625
DeliciousTuning
We are getting to all the updates slowly and surely. None of you have been forgotten about. If I were actually able to create updates and not just Bill, they'd get done twice as fast. Alas, this is not the case. I would ask everyone waiting for an update to remain patient as we are sending out updates every day, it just takes awhile to get to everyone.
Sincerely,
Old 07-25-2014, 03:01 PM   #626
xxscaxx
Sincerely,
Zach
No problem...but its been about a month since I've heard anything, and that isn't normal. So figured i'd ask on here.
Old 07-25-2014, 03:05 PM   #627
protpibe
protpibe's Avatar
@sales@delicioustuning.com @DeliciousTuning.com Did you guys update the Auto-Blip on the new version? It seems like the throttle duration varies slightly depending on which gear you're in
Old 07-25-2014, 09:31 PM   #628
DeliciousTuning
Can you pm me your email address, delicious user id and dongle id just in case? The list is pretty full right now, as you can imagine with every single one of our Innovate customers wanting the update at once. Just wanna make sure you're in there with the rest.
Sincerely,
Old 08-02-2014, 12:25 AM   #629
Ethan
Drives: Subaru BRZ
Flex fuel set up
Zach or Bill: I want to convert to a flex fuel set up. A while back, Bill mentioned that he may put out his own kit. Any progress on that? If not, whose kit would you guys recommend? It is not a huge rush, so if you guys are going to put one out, I can wait a bit longer. Of course, I will use your tune. Thanks.
The Following User Says Thank You to Ethan For This Useful Post:
texasbound972 (08-02-2014)
Old 08-02-2014, 12:38 AM   #630
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Need flex fuel kit!!! Oh, and a e85 safe fuel pump!
texasbound972 is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
