| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 | |
Drives: 4 Wheels Auto
I am not sure if overtorque the nut could result warped rotors. I have the warped rotors twice on an automatic car. I thought that was because with auto you always need to press brake during stopping so the rotor warp easily. On my manual daily now I do not get that problem. |
#30 |
Drives: Attitude
"Warped" rotors are just pad deposits left on the rotor. It has more to do with proper bed in of pads than anything else.
#31 | |
Drives: TBD
#32 |
First 86
Drives: Whiteout MT FR-S
Always use jack stands. They take seconds to put in place. If jack fails, there is great potential to damage the car and yourself. Every time I think about not using them I think, "I'd miss my foot if it were gone." Then I take the 30 second to grab the stands and put them in.
Re Harbor Freight: my approach with them is to never use anything from them that my safety depends on. No safety glasses, no harnesses, and no jack stands. Brett
Don't shop, adopt!
#33 | |
First 86
Brett
Don't shop, adopt!
#34 | |
Drives: TBD
FYI: from the BRZ manual: Tightening torque: 89 ft•lb Looking at the manual, it appears there are special notches built into the side rails that are specifically fitted to the provided jack. Good news, it should make the provided jack adequately safe for using for winter tire changes. They do recommend use of blocks, but only call for jack stands if you are getting underneath the car. Last edited by Sport-Tech; 04-17-2012 at 11:11 AM. |
#35 | |
In short, I am questioning whether that mechanic said is correct. Even though the impact torque wrench can have up to 350 lb-ft torque, that does not mean the lug can take it up to that level. If you over-torque, the lug would break into pieces first before your wheel or rotor is damaged.
#36 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Wheel shop should never use impact wrench to put the lugs on, ever. But they do.
I change both my cars at least 2 sometimes 4 times a year. It's a 15 min job - should be no problem doing that in a parking lot. They just don't want long repairs/oil and crap. I also label the wheels with duct tape so I can rotate the front/back each time. Check air as well (have a compressor). Sometimes do oil if it's the right time. Save the dealer for the nasty stuff.
#37 |
First 86
#38 |
FWES racer, R FT drifter
Drives: BMW, Chevy, Soon to be FR-S
What we do here for our regular cars and race car is:
1 we loosen them slighty (release the pressure, the pop at first, use the breaker bar) 2 jack the car up (one corner at a time, and on the reinforced point for jacking, and we have a 4 ton floor jack) 3 finish loosening the lugs and take them off 4 remove the wheel(sometimes if they havent been changed in a long time the rim will stick to the rotor, not safe but we knock on the tire to break it loose) 5 place the other wheel on 6 put the lugs on, hand tighten first then tighten in a star pattern (tip: you can actually spin the tire with the wrench on to speed up the process, but not very fast and only after you have put all the lugs on and hand tightend) 7 lower slowly to the ground and remove jack 8 torque then repeat for next wheel the spinning the wheel only for about 3 of the lugs if you use this to take the lugs off |
#39 | |
Drives: TBD
^ Thanks Droopy - copied for reference.
From Tire Rack on over-torquing: Quote:
| total noob with boxer engine | NickDude84 | Engine, Exhaust, Transmission | 35 | 04-27-2012 08:51 PM |
| [Noob Question]Will you be able to swap BRZ and 86 headlights? | Slide | Cosmetic Modification (Interior/Exterior/Lighting) | 41 | 02-18-2012 01:26 AM |
| Plus 0 tire sizing | Brzer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 01-30-2012 08:15 PM |
| Noob to the forum! | Altezza_86 | Off-Topic Lounge [WARNING: NO POLITICS] | 14 | 12-19-2011 05:34 PM |
